Question about Mercury P4VM800M7 Motherboard
Mercury smps not switching on in the cup often fuse opened
How to solve these problem
  • venkateshs May 11, 2010
    check fuse &power supply
  • 44 Answers
Pls don't use mercury smps!!!!!! me and my frns faced problems due to the smps..... that ******* smps damaged my harddisk twice....... pls change the smps...... buy cooler master or corsair..... a bit expensive but good performance and long lasting ones.........
Posted on Jul 03, 2010
Where is fuse for 1997 mercury wagon for windshield wipers
1997 mercury wagon ? Sable ? VISUAL INSPECTION CHART-WINDSHIELD WIPER AND WASHER SYSTEMS Mechanical Electrical
  • Windshield wiper blade missing or damaged.
  • Binding windshield wiper pivot arm.
  • Binding windshield wiper mounting arm and pivot shaft.
  • Empty windshield washer reservoir.
  • Kinked or broken windshield washer hoses.
  • Open fuse junction panel Fuses:
    • 8 (5A)
    • 12 (5A)
    • 20 (5A)
    • 23 (5A)
  • Damaged windshield wiper motor.
  • Damaged windshield washer pump.
  • Open connectors.
  • Corroded connectors.
  • Inoperative multi-function switch.
  • Open thermal breaker internal to the wiper motor
Which are not working , front , back or all ?
I/P Fuse Panel C225
Under left corner of instrument cluster
Feb 05, 2017 | Mercury Cars & Trucks
When i press on power button to open my pc no thing open as no electricity contact with it please help me it seems to be aproblemin board
You will check the SMPS. Unpluge two dc socket from *********** board.
Ensure the smps perfet or not Follw the link it will present with picture
Just click on http://www.jestineyong.com/?p=267
http://www.ucertify.com/article/switch-mode-power-supply-smps.html
If you connected to sort the smps,helping with the pic.soon your Smps Fan will run.
For text all the voltage, use multi meter for more knowledge, click here http://www.smpspowersupply.com/connectors-pinouts.html
After testing the SMPS
If your smps bad no harm to open the cover to repair ,just check the fuse inter the SMPS or can go nearest technician.NOTE IT IS VERY DANGEROUS, BECAUSE, YOU CAN GET HEAVY SHOCK. Better to hand over, to any Technicians .
IF YOUR SMPS RUNS WELL
Follow bellow the instruction.
Unpluge the AC power cable
Remove the CMOS Battery.
Hold on or press the on off switch for 40 seconds
Install the CMOS Battery.
Go to BIOS setup, for set up bios.
Follow the link
http://www.pcbuyerbeware.co.uk/BIOS.htm
If you can do just set load fail save default.
Or you can make with detail set the BIOS.
http://www.ybet.be/en-hardware-1-23/bios-setup.htm
I will tell you very simple way to set bios just do load fail save default
and set boot priority
!st boot =CD/DVD
2nd boot =HDD.
And press F10 >yes or hit.
I hope *********** board will run soon ,because 80% mother board can solve with this system.
Hope it will help you.
Dec 28, 2010 | Gigabyte GA-945P-S3 Motherboard
Mother board fault
NO problem about..... the mb..
its ok.. The problem may be with SMPS or motherboard...
Contact the from where you buyed your PC..
May 30, 2010 | Mercury P4VM800M7 Motherboard
No power to blinker switch
should be big silver flasher fuse located in the fuse box replace this. Its hard to tell if its bad.
Feb 16, 2010 | 1997 Mercury Sable
Rear windows stuck in open position on 1996 mercury grand marquis
Check all fuses. If fuses are good replace the master window switch on the drivers door. Good luck
Mar 30, 2009 | 1996 Mercury Grand Marquis
Detergent dispenser problem
Is it new? Even if it was or wasn't, I strongly feel that you probably didn't set something properly. Read the manual it came with, particularly the troubleshooting section. Not a big problem. Let me know how it goes. :)
Jun 29, 2008 | Bosch 24 in. SHE44C02UC / SHE44C06UC /...
CPU is not getting started
In SMPS 20 pin Connector please short the green and black wire with a twisterand on the smps. if the fan is rotating then the smps is ok
Jun 19, 2008 | Intel D845GVSR Motherboard
Tablet door dosn't open during cycle
It sound like a detergent cup issue (the door doesn't open at time) A very simple test for it is to place a tablet on the bottom of the dishwasher for a full cycle and to see what happen to the tablet. In case the tablet will be dissolved : - The detergent cup can become clogged with old dried detergent that prevents it from opening at time. Sometimes just cleaning the cup takes care of the problem. - The detergent cup opened by a bi-metal switch or a wax motor located inside your dishwasher door(behind the detergent cup). If cup's cleaning will not solve the problem, you should replace the bi-metal switch or the wax motor (depend which of them is used in your machine). Good luck !
Jul 02, 2006 | Hoover 24 in. DT999 Free-Standing...
Detergent dispenser doesnt open
The detergent cup can become clogged with old dried detergent that prevents it from opening at time. Sometimes just cleaning the cup takes care of the problem. The detergent cup opened by a bi-metal switch or a wax motor located inside your dishwasher door(behind the detergent cup). If cup's cleaning will not solve the problem, you should replace the bi-metal switch or the wax motor (depend which of them is used in your machine). Another option is just to place the detergent tablet on washer's bottom before starting its cycle. Good luck !
Jun 20, 2006 | Maytag PDB3600A Built-in Dishwasher
ZANUSSI 695 Integrated Dishwasher
May 26, 2006 | Zanussi 23 in. ZDT6252 Built-in Dishwasher
Mercury P4VM800M7 Motherboard Logo
334 people viewed this question
Top Mercury Computers & Internet Experts
Mark Gough
Abhinandan  Patil
Abhinandan Patil
Alun Cox
Are you a Mercury Computer and Internet Expert? Answer questions, earn points and help others
