Question about Logitech Cordless Mouse
When ever i press left click on mouse some time it doesn't do it ??
    Problem Solver:
  • 12 Answers
It is broken throw it out and buy a new one, it is boxing day
Posted on Dec 26, 2008
How to open unlock mouse pad
Click the Windows "Start" button in the bottom-left corner of your desktop.
Scroll up and click "Control Panel."
Choose the "Mouse" icon or type "Mouse" in the field in the upper-right corner.
Click the "Enter" button and then click the "Mouse" link.
Press the "Hardware" tab or the tab to the right of it that specifies the type of touch pad you have.
If you are under the "Hardware" tab, highlight the touch pad in the list of devices and click the "Enable" button.
If you are under the touch pad tab, click the enable button.
Click the "Apply" button and then click the "OK" button
or
Locate the function key on your keyboard (F1 through F12) that has an icon of a touchpad. This is often a rectangle with two smaller rectangles below it, representing the touchpad and its two buttons.
Press and hold the "Fn" key, usually found in the lower left area of your keyboard.
Press the touchpad function key and then release both keys. If this does not enable your touchpad, try holding the "Fn" key down and pressing the touchpad function key twice in a row.
Shortcut Key Method
Press the Windows icon key on your keyboard and hold it down until the Start menu pops up. If your keyboard doesn't have a Windows icon, press "Ctrl-Esc" at the same time.
Use your arrow keys to locate the Control Panel and press "Enter."
Navigate to "Mouse" with your arrow keys and press "Enter" to open the mouse control dialog box.
Then, press "Alt-F" together to access the tabs at the top of this box.
Navigate using the arrow keys to "Device Settings" or "Touchpad" or the similar option on your system and press "Enter."
Press the "Tab" key until the "Enable" option or a check box next to it highlights and then press "Enter." Press "Tab" again until you are highlighting "OK," and press "Enter." Your touchpad will be re-enabled.
hope this helps
Sep 22, 2012 | Computers & Internet
Sigmaplot 9 will not run with windows 7
1. Click the RIGHT mouse button on the icon for "SIGMAPLOT 9"
2. On the menu that appears click "PROPERTIES" with the left mouse button. This will give you a properties window.
3. Click on the "COMPATIBILITY" tab at the top right of the properties window with the left mouse button.
4. Tick the box "RUN THIS PROGRAM IN COMPATIBILITY MODE FOR:"
5. Click the drop down arrow and select the version of windows it ran in before or try "Windows XP Service Pack 3" and click APPLY.
If that doesn't solve the problem repeat steps 1 to 4 and this time select windows 2000. This should solve the problem.
Apr 20, 2012 | Systat SigmaPlot 9.0 (000053608314) for PC
The left mouse button doesnt work every 4th press...
I believe the switch inside the left mouse button has worn out or broken that made you think after pressing 4 times you were able to trigger the switch and make the mouse to work. You may open your mouse carefully to see if this is the case. If not please follow the below steps as you might need to configure the mouse double click speed.
Open control panel>Double click on the mouse icon>Button Tab>Double Click section>Adjust your double click speed.
Jul 19, 2011 | Computers & Internet
How do i change the mouse buttons on a compaq 6735s
Are trying to switch to lefthanded settings?
Converting to Left Hand Mouse for Windows XP Users:
  • Call up the Start menu by clicking on the Start button or by pressing the Windows logo key (located between the Ctrl and Alt keys). Alternatively, you can press Ctrl + Esc
  • Click on Settings and select Control Panel.
  • Double click on the Mouse icon to display the Mouse Properties
  • Select the Buttons tab and click on the check box marked Switch primary and secondary buttons to set the mouse buttons up for left-handed use.
  • Click OK or press Enter to confirm your choice and exit the mouse properties (note: you should be using the mouse’s right button now to make selection)
http://www.tipandtrick.net/2009/customizing-the-mouse-for-left-handed-users-in-windows-xp/
Jan 02, 2010 | HP Compaq 6735s Notebook
Toshiba Satellite ?Vista home?Start button not working
> clicking on START has no response.
Have you tried a different mouse, just in case that the LEFT button on the mouse is malfunctioning?
Does pressing the "Windows-flag" key on your keyboard (between CTRL and ALT, on the left) cause the same effect as clicking the START button?
Start Internet Explorer.
Click Tools.
Click Internet Options.
Click Connections
Check that your PPoE entry is present and is set to "automatic".
Nov 19, 2009 | Microsoft Windows Vista Home Premium with...
"sticky" mouse on compaq laptop
Unless your left mouse button has been severely damaged, it is unlikely that a loose button is the cause of your problem. More likely, it is your touchpad. Chances are your touchpad is set to click when tapped. Oversensitive touchpads can click randomly when you're dragging your finger across the touchpad.
To test this, position your cursor over a link (or other button) but don't press the left mouse button. Instead, lightly tap the touchpad itself. If the link or button is clicked, go to your Control Panel and adjust the Mouse options so your touchpad no longer clicks when tapped. It's usually a setting titled "tap to click" or something along those lines.
Regards,
Javabytes
Nov 07, 2007 | HP Compaq Presario V2000 Notebook
Left mouse button keeps clicking
could be the inside button that is defective and causing false contacts try to open the mouse and check that button
Jun 02, 2007 | Belkin F8E825 USB Mini Wireless Optical...
Left click button not working correctly
Afraid it sounds like the mouse is the problem you can go into control panel, mouse, and change it round so u press the right mouse button to do the same thing. Sorry cant help anymore.. John
Sep 12, 2006 | Targus Kaleidoscope AMU0301 (AMU0301US)...
Logitech Cordless Mouse Logo
27 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
