Question about StarTech.com StarView SV211K 2-port KVM Switch
Looking for new code for box (x in red)
The name is the box, the x is in red writing
C0 f6 61 87 91 f9 67 57 e8 c9 e5 6e b0 49 53 f5 this is the code for 54 01 as of the 21 dec
Posted on Dec 21, 2008
Looking for code for my sylvania tv for my one for all access 4 u remote
Hello
Universal remote codes for Sylvania TV with One for all URC - 3300 remote control are:
0054, 0030, 0171
Turn on a desired device (e.g.,VCR or DVD player) and, if
applicable, insert media (e.g., cassette or disc).
NOTE: Please read steps 2 through 4 completely before proceeding.
Highlight or write down the codes and device you wish to program
before starting step 2.
On the remote control,press a device key once (i.e., DVD/VCR,
CBL/SAT,or TV).
NOTE: To program control of a VCR, PVR (or DVR),TV/VCR Combo,
or TV/VCR/DVD Player Combo press DVD/VCR once.After programming
a VCR Combo device, you will be able to control channel selection,
volume, and VCR functions.
NOTE: To program control of a DVD Player,DVD Player/VCR
Combo, or TV/DVD Player Combo, press DVD/VCR once.After programming
a DVD Combo device, you will be able to control channel
selection, volume, and DVD functions.
NOTE: To program control of a Cable Box, Cable Box/PVR (or DVR)
Combo, Satellite Receiver, or a Satellite Receiver/PVR (or DVR)
Combo, press CBL/SAT once.
Press and hold SET until the LED (red light) blinks twice,
then release SET.
4. Use the Manufacturer's Codes (starting on page 18) to
locate the type of device and brand name and then enter
the first four-digit code for your device. If performed correctly,
the LED will blink twice.
NOTE: If the LED did not blink twice, repeat steps 2 through 4 and enter
the same code again.
Aim the remote control at the device and press POWER
once.The device should turn off. If it does not, repeat
steps 2 through 5, trying each code for your brand until
you find one that works. If it still doesn't work, try
Searching For Your Code on next page.
NOTE: If the device does not have a POWER key, press PLAY
Repeat steps 1 through 5 for each device you want to control.
For future reference,write down each working device
code in the following boxes
OK.
Jul 13, 2011 | One For All URC-3300 Remote Control
How do i connect it to my wireless connection in my house!!!!?
See: http://digitalgadgets.com/netbooks/support-7in-netbook.htm for a detail of how to connect. If that does not work then see my how to at: http://www.fixya.com/support/r7350901-fix_synet07526_wifi_flashing
You may also see:
Wait for the little computer icon in the lower right corner to show two radiating side waves with a red X under the icon. The red X indicates that the WiFi has not connected. double click on the Computer icon and a window opens up with RT28701 as the header, with all zeros in the fields.Click on the tab Wireless Information. and a new window opens up. Look for the name of your home wireless network, and double click on that name. another window will open up called Network Properties and you will see some entries, with the name of your network as the SSID. go down to the key box that says The key is provided automatically, and uncheck that box. At the long box that says Network Key type in your code for the network key. This code was assigned when your network was set up to prevent someone else from accessing your network. When you finish, check the box The key is provided automatically and from then on your machine will connect automatically because it will remember your key.
Dec 19, 2010 | Sylvania G-Netbook
My 7in sylvania will connect to other connection away from home, but won't connect to my wireless at home
You have to click on the WiFi button and make sure that you turn it on, and what is left is Turn Off button.
Wait for the little computer icon in the lower right corner to show two radiating side waves with a red X under the icon. The red X indicates that the WiFi has not connected. double click on the Computer icon and a window opens up with RT28701 as the header, with all zeros in the fields.Click on the tab Wireless Information. and a new window opens up. Look for the name of your home wireless network, and double click on that name. another window will open up called Network Properties and you will see some entries, with the name of your network as the SSID. go down to the key box that says The key is provided automatically, and uncheck that box. At the long box that says Network Key type in your code for the network key. This code was assigned when your network was set up to prevent someone else from accessing your network. When you finish, check the box The key is provided automatically and from then on your machine will connect automatically because it will remember your key. See:
http://digitalgadgets.com/netbooks/support-7in-netbook.htm for the same information.
My netbook will not connect by wifi. If i do get it to connect then i cannot get on the internet what do i need to do?
You may also see:
Why do i keep losing internet connection?
You may also see:
Also the strength of the built in WiFi receiver is not strong, and you may need to be closer to your network router
Dec 18, 2010 | Sylvania G-Netbook
Bought daughter a 7" Sylvania netbook for X-mas,
You may also see:
Can't connect to wireless internet
You may also see:
Exbox 360 4 red ligths
4 red light is a problem with your AV cable.
THINGS TO TRY
  1. Make sure that the AV cable is correctly connected to the xbox 360
  2. Disconnect the AV cable from the Xbox 360 console, and then reconnect the AV cable to the Xbox 360 console.
  3. If the four flashing red lights continue to flash, try wiping the metal area of the AV pack with a dry cloth. The metal area is the end that plugs into the console. Wipe the metal area thoroughly, and then try the AV Pack again.
  4. If the AV cable is correctly connected but the four red lights are still flashing, substitute a different AV cable if you have one available.
    You can also check to see what the error code is yourself if your not sure whats wrong with it.
    To do this, you turn your x-box on, press the Connect button on the console itself and hold it in. Now press the DVD eject button to and look at the lights. it should be flashing 1 light, 2 lights, 3 lights, or 4 lights. grab a piece of paper and write down how many lights are showing. While still holding the connect button, press the eject button again. Write down how many lights are showing again. Then press eject again, and write it down. Then do it one more time and write it down. After you do this, then come back on fixya.com and let me know what error code it is.
    1 Red light = 1
    2 Red lights = 2
    3 Red lights = 3
    4 red lights = 0
    so an example of what you might write down would be:
    0
0
0
which would be 0001.
If you figure out the error, you can also visit the following website and determine what it is and if you can fix it yourself:
http://www.llamma.com/xbox360/repair/Xbox-360-error-codes.htm
Feb 24, 2008 | Microsoft Xbox 360 Console
Red picture
Hi, looks like a "Shop" job to me... ask for a "Quote" B4 ya proceede. If it's a CRT screen then ya have "Lost" one or more of ya colour "Guns" if LCD then the Driver circuitry has gone faulty. Either way it's not an easy fix.. for a home job.
Jul 31, 2007 | RCA TruFlat 27F520T 27" TV
StarTech.com StarView SV211K 2-port KVM Switch Logo
20 people viewed this question
Top StarTech.com Computers & Internet Experts
Alun Cox
mbowen171
mbowen171
Are you a StarTech.com Computer and Internet Expert? Answer questions, earn points and help others
