Question about Microtek ScanMaker 6100 Pro Flatbed Scanner
Open to Clean Glass
How do you open the 6100 Pro to clean the glass?
  • Paul Dickler May 06, 2007
    After opening the hinge-side clips, I was able to snake a bent coat-hanger wire down each side and open the side-clips easily.
    And yes, my next scanner will be mmore user-friendly.
This is a pain; MicroTek offers no instructions; proceed at your own risk, etc. Before you start, get some high-quality optics cleaning kit ready to go, and clean the outer glass perfectly, so you don't have to keep guessing whether remaining smudges are on the inside or out. Remove lid by simply lifting to 90 degree angle and then lifting upwards. Remove all cords, so lid is not connected anymore. You need a thick, strong paper clip. Unfold it so one part functions as a handle, leaving a short length suitable for poking into holes. Lock the chassis on your scanner (underside, coin in red button, turn to locked position). Now sit in chair in front of desk. Put scanner with buttons on your lap, glass towards you. Hold hinge side of scanner with left hand. Notice that there is a pin hole just to the outside of each hinge slot. Now comes the hard, you -might-break-something part. Use right hand to insert paper clip into rightmost hole. With left hand, put a fingernail in the gap where the lid is gonna come off. Press firmly (pretty darn hard, in my experience) with the paper clip to release the tab that holds the top in place while pulling with your fingernail. With luck, a slight pop and that side is done. Repeat on the other side. Note: don't let paper clip angle down towards bottom, slip past retaining tab, and poke into something vital. There is also a third clip dead center, but it seems to pop out with little effort. Unfortunately, you're still not done. There are two more clips about halfway down each side, and no visible way to depress them. You just have to lift up with a frightening amount of force until they make a big "pop" and hopefully don't break. Now the darn thing is still hooked at the front (where all the front panel buttons are). You want to kinda lift the back end up, jiggle, and then pull up and back (I busted one of my front hooks before I got it off). Now the top is still connected via a ribbon cable, but you can put the edge of the top into the lip of the bottom, hold the back of the top at a 90 degree angle, and clean that glass with your left hand. Get it perfect, because you don't want to have to be doing this again. I kept a very bright LED flashlight at hand so I could shine it at oblique angles to scan for smudges. Of course, your scanning element is more vulnerable to dust during this whole process, so try to do this in a relatively clean room, and try to get done quick without dumping any dust on the innards. Good luck, and join me in saying "I'll never buy another scanner that isn't designed to let me clean the inside glass!"
Posted on Apr 18, 2007
My fireplace glass is cloudy and won't come clean?
this is all i can find out.
How to clean the glass of your Direct Vent Gas Fireplace
  1. Following the instructions in your manual, turn off the fireplace including the pilot light, and open the glass front.
  2. Leave the glass front on its hinges if on hinges. ...
  3. Use a cream cleanser like Imperial Gas Fireplace Glass Cleaner.
More items...
How to clean the glass on your Direct Vent Gas Fireplace - Napoleon ...
napoleonfireplaces.com/clean-glass-direct-vent-gas-fireplace/.
or go to this link might help you.
how to clean cloudy gas fireplace glass Google Search
Oct 30, 2017 | Dishwashers
How do I clean the inside of the glass of the fireplace?
Crumple up newspaper, use it like a rag, scrubbing the glass. Not abrasive enough to scratch the glass but enough to clean soot deposits.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to clean your Fireplace Glass
Gas Fireplace Repair Dirty Glass My Gas Fireplace Repair
How To Clean Your Wood Stove Fireplace Glass
Cleaning glass on woodburner
Mar 02, 2016 | Heating & Cooling
Removal of inner glass door.. how.??
Open door to about 15~20 degree angle, pull up on door and totally remove from stove. Lay face down on flat surface. Now can access all screws to separate the inner and outer panels and to replace the glass. To return to stove, use locking pliers to pull the door hinge stubs out to their 15 degree open position, slide door on and close.
If glass not broken, just can't see through, no need to remove door or glass. Use glass cooktop cleaner, apply and let soak 3 minutes, then use new single edge razor in holder to shave off the baked on grease. May have to repeat 3x then switch to glass cleaner and clean again 3x, should be quite clean and clear unless seal has failed on the double pane thermal glass and internally obscured in which case the only cure is to replace the glass... return to paragraph 1.
Sep 20, 2015 | Ovens
Remove glass door on kitchen aid stove, to clean
I'm wondering if you really need to remove the door to clean it. Just open the door and clean the inside of glass.
Jun 22, 2014 | Computers & Internet
Officejet 9600: vertical lines (4) in center of page when copying using ADF. No lines when copying from glass. I tried the cleaning procedures on your trouble shooting pages. They did not help. How ca
John:
When using the ADF, the scanner doesn't move. The long rectangular platen glass on the left side of the machine is used, not the large glass. I believe that if you clean the long, thin piece of glass on the left side of the platen, your lines will disappear.
May 21, 2014 | HP Officejet Pro 8600 e-All-in-One -...
C0620
Minor motor failure Under the big glass is motor that drive certain mirrors on the right hand side under the glass something is jammed or the motor is bad be careful do and damage to the mirrors will mess up image Open close there are also two sensors clean and check them black look like half "H"
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Nov 28, 2013 | Minolta EP4000/5000 CS/PRO Copier
The sove oven doar had a spill the spill went through glass and now in between the glass and i cannot get to it to clean.HOW CAN I GET THIS GLASS TO CLEAN I DONT NO HOW TO OPEN THE DOAR
The glass in oven doors is not designed to be removed and cleaned. Although theoretically possible, it is not practical to do so.
Nov 15, 2013 | Kitchen Ranges
Copying from upper tray - line on the copy - good copy but has a solid thin line, about the size of the roller.. -- copying from glass is fine..--if it is the roller ! how do I clean upper roller and etc....
hello, you said this was a copy, have you tried making copy from the glass, and not thru the doc feed, just to see if the output us the same. if not, open up the doc feed area, and clean the **** glass. now if your prints from the computer are the same as the copies, then its possible that the problem is pressure rollers above the ashpalt grey platten roller. alittle harder to clean but can be cleaned off.
Oct 11, 2010 | HP Officejet Pro 8500 Wireless All-In-One...
The screen says the Paten glass needs to be cleaned. What is the paten glass? Also when copies are made a black line is showing up on the edge of the copy.
platen glass means that you need to clean the copy glass - glass where you put the originals for copying.
If you have an auto document cleaner there is also small glass on left side of "platen glass" wich is seen when you open the copy machine cover or dadf.
The black line is probably from dirt on copy glass, I pressume because courectour liquid ( most common ). use some stronger detergent or wd-40 to disolve the dirt and clean with glass detergent and dry it.
If you still have the black line try to print something from machine.If you do not have it on print its the copy glass problem - clean it - again.
Pls.rate
May 09, 2010 | Canon imageRUNNER 1023iF Black and White...
C0f22 error code
Atomatic Intensity Density Cotrol sensor malfunction.
Clean the optical parts:lens,mirrors and original glass.Remove the OPC unit clean the AIDC sensor under drum in the rear side,use the vacuun cleaner for remove the used toner under cleaning blade,reasamly the unit.Clean the transfer and separator corona holders and wires and perform the F5.Enter in the service mode Stop key-0-Stop-1 Function menu ,place A3 sheets in the original glass place and perform F5.See the F code history and reset it.This code reset if you open and close the front door.
Sep 09, 2009 | Minolta EP4000/5000 CS/PRO Copier
Microtek ScanMaker 6100 Pro Flatbed Scanner Logo
195 people viewed this question
Top Microtek Office Equipment & Supplies Experts
Alun Cox
Michael
Are you a Microtek Office Equipment and Supply Expert? Answer questions, earn points and help others
