Question about Tappan 30IN ELEC IGNa Oven
Oven does not light
When turned on the ignitor turns orange but it does not ignite, you are able to light oven manually and it works fine. If ignitor turns orange and heats up why does it not light oven?
  • kmxp Jan 02, 2009
    oven smells like gas, eventually heats up what is wrong?
  • Anonymous Feb 16, 2009
    tried suggestion and it didn't help. nothing in the path of the gas and the heating element heats up right away. i
    moved the heating element closer to the gas and nothing. the gas seems to take about 5 minutes before i can smell anything and the over will eventually heat up after a noticeable ignition.
    President:
  • 2,692 Answers
Try this:  . See if the ignitor is in the direct path of the gas. If not move it slightly to be closer to that path. Maybe something his it and it is out of position. Gas + Glow(together) = Fire The other possibility is that somethng in in the path of the gas leading to the glow coil.
Posted on Jan 07, 2009
Oven will not light ,broiler and top of range light fine
the ignitor is not working its bad,you should see a bright orange glow below the oven base just as when you start the broiler look up at the top of the oven and watch this ignitor glow before ignition,the bottom should do the same,you can also see this from the back side of the range at the base,if you don't use the broiler you can use that ignitor for the oven ignitor as these ignitors are identical,but then you will have no broiler
May 11, 2012 | Frigidaire Ovens
How to test oven igniter
The best way to test the igintor is with an amp meter. Connect a clamp on amp probe to one of wires going to the ignitor (either one is fine) turn the oven on, match the current you get from the amp probe to the rating on the gas valve to see if you have enough current. (typically you need 3.2 amps for most systems).
As ignitors get weak the resistance in them gets higher causing the amp draw to go down.
You can also get 'a feel' for the strength of the ignitor by how bright it glows, when working right, the orange will be bright almost whiteish in color. As it ages and weakens it will be more of a dull orange.
As a rule of thumb, if the ignitor is glowing and the burner will not come on the ignitor is bad.
I hope this helps
May 05, 2010 | Frigidaire FGB24T3A Gas Single Oven
My Kenmore gas oven does not light.
Remove the oven Racks. Remove the oven base plate. Turn the oven on. You can then see the oven ignitor next to the oven burner. If the oven ignitor does not glow a bright orange,replace it. About a $90 part.
Oct 05, 2009 | Kenmore 30464 / 30465 / 30469 Gas Single...
My oven won't light but I don't get the orange glow .
Make sure you have 120 volts to the oven wiring terminal. Could be a completely broken ignitor this time. Disconnect the ignitor wires and attach a volt meter to the incoming ignitor wires. Turn the oven on. If you read 120 volts the ignitor is bad. If you read no voltage the oven control is bad.
Jul 22, 2009 | Ovens
Stove works just fine/oven does not warm up - pilot light is on, but turning on oven does nothing but make the pilot light glow a little bigger. Oven will not ignite.
Hi, The ignitor is getting weak and will not open the gas valve. Replace the ignitor and you will be back in business. This is a very common problem with the gas ovens.
Please let me know if I can assist you further.
Vic
May 29, 2009 | Ovens
Ge xl44 oven not igniting but burners ignite
The most common failure for a nobake on this type of oven is the bake ignitor. turn unit on and look at the bottom of the oven, you should after about 30-45 seconds see an ORANGE glow, if you do not, chances are you have a failed ignitor.Remove lower part of oven and if you have a meter, place one lead on each terminal and check for continuity( a closed circuit)
If you have an "open" circuit, the ignitor is bad
Feb 26, 2009 | GE JGRP17 Gas Single Oven
GE XL44 oven not working, but the broiler is...???
CHECK THE IGNITOR, IT SHOULD BE GLOWING ORANGE BEFORE GAS IGNITES. IF NO GLOW, REPLACE IGNITOR.
Jan 28, 2009 | GE JGRP17 Gas Single Oven
Oven will not lite
Unplug the unit, change the igniter maybe it does not draw enough ampage.
or check the gas control knob if somebody mistakenly turned it to off position. the ON position should be inline with the gas pipe.
Dec 18, 2008 | Frigidaire FGB24S5A Gas Single Oven
Top oven bake igniter comes on, but gas does not.
Check the voltage on the 2 wires going to the oven gas valve. If you get 120v when the ignitor is on with no gas coming out, you have a bad gas valve. If you get voltage, but it is not much, it is the ignitor. The ignitors don't burn out completely on the ovens, they just get a little dim and no longer ignite the gas and eventually will not turn on the gas valve
Dec 19, 2007 | Amana AOGD2750 Gas Double Oven
GE Oven does not light - no gas smell and no electronic ignition clicking sound
It probably needs an oven igniter. Remove oven racks. Remove oven floor. Usually 2 screws towards back. Remove flame spreader if it has one. You can see long tube with holes in sides and igniter with 2 wires from rear. Now try oven. See if igniter glows. If it does but doesn't light within 1 minute, replace igniter.
If it doesn't glow, you need to check for power to igniter. Should be about 100 volts. If not may need ERC, "Electronic Range Control".
Nov 19, 2007 | GE JGRP17 Gas Single Oven
Tappan 30IN ELEC IGNa Oven Logo
254 people viewed this question
Top Tappan Ovens Experts
Craig Butler
Craig Butler
john h
Ezewudo Onyekachi
Ezewudo Onyekachi
Are you a Tappan Oven Expert? Answer questions, earn points and help others
