Question about Gateway 200 ARC Notebook
I have a gateway 200arc notebook,after i formatted it the two usd drive are not working again when i try to use it
You have to go into setup to turn them on
Posted on Dec 21, 2008
Replace CmosBattery in A Gateway 200arc
1) you must open the computer
2) unppluged it
3)use the wristrap a connect the side to ground
4) use some a little screwdriver + long pliers for to remove
5) clean the base of batteries with cotton swab +ethylic alcohol
6) proceed in reverse order.
God bless you
Oct 02, 2012 | Computers & Internet
How do I nremove the cover on a Gateway 200arc to replace the DVD drive..... Thanx
Looking at it from the bottom with the dvd drive to your right look for a screw about five and a half inches or so from the right hand side will either be in the middle line of the dvd drive or offset to oneside or the other. remove it and gently pull on the dvd drive or use an old credit card to pry it out till the connectors release. Then slide the replacement drive into place, and put the screw you removed back in.
Jul 28, 2011 | Gateway 200 ARC Notebook
No operating system found, gateway 200arc
Presuming its not the worst (your hard disk has failed) quite often this is the simplest of things...like you have left a USB stick in...these are often bootable and so the computer tries to boot from them fist, and then doesnt bother trying your propper hard disk next..hence fail.
also check if you mahine has a floppy disk drive there is none in it.
other than that.
check that your bios recognises it.
by which I mean usualy on startup it offers you an option to go into setup.
[f1] or sometime [del] or whatever.
go into there ensure that your HDD is recognised by the system and check its listed in boot order also (only change these if its not one of the simpler problems above)
HTH
Richard
Mar 19, 2011 | Gateway 200 ARC Notebook
My Gateway laptop model MX6453 wireless adapter is shut off and I'm unable to find how to turn it back on
Frequently Asked Questions
Q: How do I turn my notebook's wireless on and off?
A: Most Gateway® notebooks have a designated multi-function button or function key to turn your wireless on and off. This information is located in your notebook's user guide. The user guides for the Gateway® branded notebooks are installed on your hard drive. To access your user's guide, from the Start menu, point to All Programs, and then click Gateway Documentation. User guides are also located on the Gateway® Web site. To download or view a copy of the user's guide from Gateway.com, select your notebook type from our Notebook User Guides support page. http://support.gateway.com/support/manlib/Notebooks/notebook.shtml Another source of reference for networking your computer is the Gateway Notebook Networking Guide. http://support.gateway.com/s/Mobile/Gateway/M250/8510650.pdf Quick reference:
  • Gateway® M675 - Multi-function button (last on right)
  • Gateway® 200ARC - Multi-function button (last on right)
  • Gateway® M505 - Multi-function button (first on top)
  • Gateway® M500 - Multi-function button (first on top)
  • The Gateway® M275 notebook uses the system keys FN+F7
  • Most other notebooks use FN+F2
Dec 08, 2010 | Gateway MX6453 Notebook
How do I enable the wireless switch on a Gateway mx8711
HI there,
The user guides for the Gateway® branded notebooks are installed on your hard drive. To access your user's guide, from the Start menu, point to All Programs, and then click Gateway Documentation. User guides are also located on the Gateway® Web site. To download or view a copy of the user's guide from Gateway.com, select your notebook type from the Notebook User Guides support page. Another source of reference for networking your computer is the Gateway Notebook Networking Guide. Quick reference:
Hope this helps you out.
TheSelkie
Jul 21, 2010 | Gateway MX8711 Notebook
This is built into a gateway 200arc notebook. when the wireless is turned on the system can't even get through a win xp boot up. turn is off and system boots all the way. turn on the wireless whil in...
Try starting the OS in safe mode (hit F8 immediately after the BIOS screen until you see a menu) and replace the driver with the newest available driver. Try the gateway provided driver first, but if that doesn't work, you can always try to download the newest driver direct from Intel.
Oct 20, 2009 | Intel 2200BG 802.11g/b (wm3b2200bgmwwb)...
Gateway 200ARC goes to "Last Known Good Configuration" screen
try reseating the dvd drive and then go into the BIOS to be sure that the drive is being recognized. Actually go into the area of the BIOS that shows the name of the dvd drive that it recognizes.
It it does recognize the dvd drive properly then try other boot cd's. It still may not recognize them.
If so try another known good dvd drive in the laptop and if you have the same problem then take out the hard drive and then see if the system will boot up off of the dvd drive then. If it still doesn't boot then the motherboard is bad.
If it does boot then that means the new hard drive is bad and shorting out the dvd drive controller on the motherboard and the hard drive would need to be replaced.
Hope this helps clear up things for you and sorry for not responding sooner.
Ben
May 18, 2009 | Gateway 200 ARC Notebook
Gateway 200arc motherboard problem
If there are two wires running from the power button on your case to the motherboard, take them off and try jumpering those two terminals with a jumper or something that will make contact for just a second and them take back off. Your power button may have fried along with the power supply.
May 18, 2009 | Gateway Refurbished $30 P1 TO USA - BOARD...
My 200ARC notebook/laptop will not power-up I have replaced the battery but it just won't turn on HELP!
If you replaced the battery and still no go it's probably your motherboard. You can try reseating the memory but if you're not getting any life out of the machine then for sure it's the motherboard.
Feb 21, 2009 | Gateway 200 ARC Notebook
Gateway 200arc broken hinges
Solution #1 is not accurate. You can find a good number of replacement hinges on Ebay for around $40. The repair is not difficult and can be done yourself :)
http://shop.ebay.com/?_from=R40&_trksid=p3907.m38.l1313&_nkw=gateway+200arc+hinges&_sacat=See-All-Categories
Dec 15, 2008 | Gateway 200 ARC Notebook
Gateway 200 ARC Notebook Logo
98 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Steve Allison
Steve Allison
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
