Question about Zanussi 24 in. DE6965 Built-in Dishwasher
Electrolux ESL 6115 dishwasher won't switch on
My integral dishwasher just won't switch on - no lights and no action! Have replaced fuse but no joy - help ! Am washing up by hand which wont make for a very happy christmas...
  • cobblers 1 May 15, 2009
    my disheasher will not come on i have checked fuse
5 Suggested Answers
  • 1314 Answers
SOURCE: Electrolux ESL 6225
before you operate the dishwasher get your water as hot at the sink as you can this will prevent filling the dish washer with cold water and i would use powder or liquid now if you not sure of your heating element turn your washer to dry close the door for about 2-3 minutes get a glass of cold water open the door and pour water on the element if it sizzles its working
Posted on Feb 12, 2008
rylee_smith
  • 8619 Answers
SOURCE: My electrolux 6115 dishwasher will not drain, it
Hi
Thanks for using FixYa. Dishwasher not draining properly or not draining at all issues can arise due to different reasons. Usually, these issues are related to kinked hoses, knocked out disposer unit (if connected with the dishwasher drain hose) & clogged drain pump & filter.
Also note that dishwashers do not drain completely after a finished cycle and this is normal. Dishwashers are designed to leave some water in the unit to ensure that the heating element doesn’t overheat. If you suddenly begin to experience a large amount of water being retained in your dishwasher, you have a problem. Some of the most common reasons include that the drain hose isn’t working properly, the drain pump isn’t working correctly, or possibly there is a plumbing problem in your home’s drain lines.
First check whether the drain is not clogged or blocked and the line is not kinked. Check all the hoses for blockages & also clean the air gap. Has the disposer been replaced recently? If so, chances are the knockout is still in place. Simply remove the drain hose from the disposer, and knock out the plug. If the disposer has not been replaced, try removing the drain hose from the disposer and use a wet-dry vacuum (prepared for water, of course) to **** any water (and hopefully anything else) from the drain line. Then reconnect the hose, and test the unit. If you have checked the air gap and the drain hose and can’t locate the problem, then it is an issue with the drain pump of the dishwasher.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Posted on Dec 11, 2009
  • 44 Answers
SOURCE: Water is not draining away
Best off to call a certified repair company such as Sears.
Posted on Oct 16, 2010
  • 57 Answers
SOURCE: I have an Electrolux ESL
Assuming that power is being supplied to the unit. Unplug door switch. If display comes on. Replace switch.
Posted on Mar 28, 2011
How to fix electrolux el 6115 door latch is faulty and doesn't click shut
It happens to skip latch and is no longer possible to close the door and turn on the dishwasher. The latch is in plastic material in which a system of levers provides the mechanical action.
Solution: Remove control panel and put latch back into normal position with the slot forward. Look the picture.
Dado
Jul 09, 2014 | Electrolux Dishwashers
Electrolux esl 6226 not working beeping sound and light flashing
Hello Eamonn, I am happy to assist you!
Let's try resetting the dishwasher by either unplugging it or flipping the household circuit breaker to the off position. It is important to wait roughly ten minutes and then turn dishwasher back on. Confirm that the door is properly latched and try selecting a cycle. If resetting the power does not correct the issue, it could potentially mean a number of things: a potential wiring failure, faulty door latch assembly or control board. Because it could be a number of any one of several underlying causes, I would recommend contacting a professional to properly diagnose and repair the appliance.
Oct 12, 2013 | Electrolux EWDW6505GS Fully Integrated...
Electrolux dishwasher esl 6114 door does not lock
Hi Peter Gumbrell - Often when the dishwasher door does not lock, it is because the of door lock assembly. The door lock or latch may either be faulty or damaged. If I was in your position, I would personally recommend consulting a professional to accurately diagnose the dishwasher to determine the root cause to reduce the risk of unnecessary parts.
Mar 20, 2013 | Electrolux Dishwashers
Electrolux d/w esl 6115,drains then fills and pumps straight and 50 degree light flashes all the time
NCORRECT PRODUCT CATEGORY
I'm sorry but you have this posted in the wrong product category. Please re-post the question in the proper category
Jun 29, 2012 | Vacuums
Electrolux esl 6115 dosent seem to be getting hot, filling with water but not cleaning the dishes, cleaned the filters.
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher Spray Arms not Spinning
How to Buy Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
Asker
Sep 30, 2010 | Microwave Ovens
Hi, I have an Electrolux ESL 4115. It seems to be stuck on 50 degrees but wont start as usual when I close the door, the on/off button works and lights functioning as normal but that's all. Thanks
I had a similar problem - seemingly stuck or locked with a solid light showing (in my case on the 65 degree wash). Nothing seemed to unlock it. But when I closed it and went away to think about what to do next - some 5 minutes later - it made its end-of-cycle peeps. It now works fine. All I can think of is that I must have interrupted the previous wash cycle l was using before it had ended, and had left the door ajar. all it needed was the door closing for the cycle to finish. Does that help?
Sep 22, 2010 | Electrolux 24 in. ESI6220X Free-standing...
Dishwasher not working properly
I have trouble with only the top not cleaning properly and have found blockages in the spinning jets at the top, may be worth checking
Mar 02, 2008 | Electrolux 23 in. ESL624 Built-in...
Electrolux ESL 6225
Feb 12, 2008 | Electrolux 23 in. ESL624 Built-in...
Zanussi 24 in. DE6965 Built-in Dishwasher Logo
893 people viewed this question
Top Zanussi Dishwashers Experts
Paul Carew
Charles T Nevin
Charles T Nevin
Are you a Zanussi Dishwasher Expert? Answer questions, earn points and help others
