Question about HP DesignJet 500ps (42 in.) InkJet Printer
81.01 Error in HP DesignJet 800
The plotter is initializing and coming ready mode. While giving the print, it's showing the 81.01 error in control pannel. can i know the exact problem and how can i solve it?
    New Friend:
  • 20 Answers
Replace Paper Motor
Posted on Sep 11, 2009
    Scholar:
  • 96 Answers
System Error: 81:01
Problem
Description:
Paper-Axis shutdown.
Corrective Action: If this error code appeared but was NOT caused by a paper jam, then
try the following:
 Perform the Paper Advance Test → Page 4-10.
this is the error code direct from the service manual. if this nerror is not caused by a paper jam then you may need to replace the paper axis motor.
Posted on Oct 01, 2009
    Novelist:
  • HP Expert
  • 297 Answers
Description:Paper-Axis shutdown.
Corrective Action:
If this error code appeared but was NOT caused by a paper jam, then try the following:
Perform the Paper Advance Test.
If the problem persists, replace the Encoder Disk Assembly
Posted on Sep 12, 2013
    Scholar:
  • HP Expert
  • 123 Answers
The error is a paper axis shut down. There may be abnormal friction in the paper motion mechanism. Check for seized needle rollers or anything that would stress the paper motion motor. The problem could be the paper motion motor itself. If you remove the motor, you should be able to turn the motor freely. It is a stepper motor and you will feel the effects of the permanent magnets in the motor and will feel like it has a crunchy bearing. That is normal. If it requires a lot of force to move the motor shaft, replace the motor. If all seems normal, run the PAPER ADVANCE calibration. All this stuff is in the manual which can be downloaded at: www.lpscomputer.com/ec/manuals.htm
Parts are available at: http://www.lpscomputer.com/c-622-designjet-5000-5500.aspx
Posted on Apr 15, 2010
Hp designjet error message 5.10
The 04C*** error is an internal data bus error. The hard disk drive and the Jetdirect card share this bus. With the power off, disconnect the HDD and remove the Jetdirect card. Power up and see if the error goes away and the plotter goes to ready. If it does, put the HDD and Jetdirect card back into the plotter one at a time and power up again to identify the failing part. If the error continues with the HDD and Jetdirect card removed, the bus controller has died and the main logic board needs to be replaced. Any of these parts can be ordered from: http://www.lpscomputer.com/c-654-designjet-1050c-1055cm.aspx
I can also be reached at 800-959-1575 to answer questions.
Apr 24, 2014 | HP DesignJet 500ps InkJet Printer
I bought a used HP Design Jet 450 C...But its showing the cartridge and data solid orange light and ready light is constantly green. I brought a new black cartridge, the printer takes in the paper and...
I think the problem is not the computer. You shoud check the plotter by running the test print without the computer. When plotter's power is on, press Setup and Cancel keys simultaneously. If it does not print, then the plotter need repair.
According to your descriptions, there is System Error Code shown on your control panel. when the lights on for Ready+Cartridges+Data (DKL), it may have 9 possible causes referred by Service Manual page 2-7. You can check all these 9 items to see which one causes the problem.
Dec 17, 2010 | HP DesignJet 450c InkJet Printer
Hp plotter designjet 1055 CM plus plotter produces system error
one of the printheads is bad.....check the error code again,because 060308 does not exist in hp designjet 1055cm plotter.
Jul 31, 2009 | HP Office Equipment & Supplies
Cant do EEROM setup coz severe error:0x4010008 occured
restart the plotter in service mode using following method
1 power off the plotter
2 press Up Arrow + Enter Button ( green buton) and while pressing both buttons switch on the plotter
3 when u see service test /Service utilities release keys & select service utilities & then perform eerom setup there , put the actual model number ( c7780b/c ) and it wil resole the issue
Mar 30, 2009 | HP DESIGNJET 800 42IN 1200DPI 96MB PAR USB...
HP Designjet 800 with a 'system error 81:01'
i have hp dnj Plotter 500 Printer Is Redy But Self Test & Computer Print Than Error 81:01 Papar Jam
Feb 23, 2009 | HP Office Equipment & Supplies
Hp designjet 430
This usually is solved by removing and reinstalling the ink cartridges...make sure the electrical contacts are clean (use a dry paper towel) on both the print cartridge and the carriage.
If the error still happens then the carriage or trailing cable are bad and will need replaced.
Nov 28, 2007 | HP DesignJet 430 InkJet Printer
HP DesignJet 500ps (42 in.) InkJet Printer Logo
5,085 people viewed this question
Clive
Clive
