Question about Electronics - Others
Portable Generator doesnt generate any AC Current
I have a Companion 10 HP 5500 Watt gasoline powered portable generator The motor runs great and was generating power then suddenly no power Ive disasembled the generator head it looks simple enough. all wires look good not broken or burnt any where. all connections are good Under the cover plate is a little round canister I believe is a copasiter. Ive tryed a couple other used ones and still no AC current is being put out. I live in Washington State 20 miles from the cost and we are having a bad storm front and I wish I had it running just in case of power outage Thanks for your time
  • 15,935 Answers
Is there a manual reset circuit breaker somewhere?
Posted on Dec 22, 2008
What means P50 ryobi generator 5500
Ryobi 5,500-Watt Gasoline Powered Portable Generator
Watts = E (voltage) * I (current) The manual will give 120 vac load limit as well as 220 volt load limit.
https://www.homedepot.com/catalog/pdfimages/39/39ebfc9d-52e6-4acb-8205-fa94c1347e04.pdf
Nov 30, 2017 | Electrical Supplies
Starts runs great turn off the it won't start again
Generator runs then shuts off - YouTube
? 8:17
https://www.youtube.com/watch?v=6esHkPyygWw
Sep 6, 2011 - Uploaded by mainblind
How to make Generac generator run bypassing the low oil sensor and ... Great video on low pressure warning switch removal and ...Pulled off the shroud over the sensor. ... It wouldn't start so I replaced the spark plug, gas, and oil - then it did as yours. ... 1200 Watt Generator Won't start - Duration: 14:49.
gasoline engine on portable generator won't start what do I ...
answers.angieslist.com/gasoline-engine-portable-generator-won-start-I-d...
Apr 16, 2014 - gasoline engine on portable generator won't start what do I need to do ... PULL, Take OUT the spark Plug , make certain it is clean and DRY and then start allover again. ... start then when talking pulling rope use electric starter - if won't ...several times till starts, moving choke to OFF or RUN position once it ...
How To Fix A Portable Generator That Won't Start ' My ...
blog.mygenerator.com.au/how-to-fix-a-portable-generator/
Jan 21, 2016 | Electrical Supplies
Where can I find an operator's manual for powerboss model 030359
https://www.briggsandstratton.com/us/en/generators/portable-generators/products/5500-watt-portable-generator-us
Dec 07, 2015 | Briggs & Stratton Power Products 5,550...
Where is the fuse on the onan 5500 built in generator?
Try under the bench seats around the table, near the heater.
Jul 14, 2014 | Onan Marquis Gold Quiet Gas Generator 5500...
North Star Generator Parts
Hi, you can find them on amazon. Take a look here: Portable Generators from Briggs Stratton. I hope this was helpful. Cheers
Oct 08, 2012 | Northstar Generator 9 Hp, 5500 Watt,...
We have a Valsi 5500 watt generator that isn't putting enough voltage out to run everything in out small travel trailer. It runs the lights but doesnt push out enough voltage to carry the A/C, microwave,...
How long have you had this generator?
Has the generator worked on all of these loads before?
Model 5500 is a 5500 Watt generator which could easily be 5500 watts (Peak) and not continuous.
Your AC is an inductive load.
Your lights are resistive loads
An inductive load can cause issues when starting due to an increased current demand at start up that some generators cringe under. Do the lights flicker or are they stable? I'd say your diodes on your stator are working if you have light stability but you haven't provided nearly enough information for a detailed solution.
I'm sure you have enough voltage but you aren't getting enough current to run specific loads. How many watts is your AC? How many watts for your microwave? Both of these units demand a great deal of energy to run and when you place too much demand on your generator, it will choke it out and eventually, will cause damage to the generator. You may consider getting a beefier generator with a greater amount of wattage output.
Seeing these specs online and noting what you are trying to run, you have an undersized generator and need to get one that can produce a greater amount of running wattage (as well as peak wattage).
Apr 12, 2011 | Watts Onan Portable Generator - 4000 ,...
ENGINE RUNS GREAT DOES NOT PRODUCE ANY AC CURRENT
It seems that the "generator is burn".The generator is one thing and the gen. is other.
Oct 13, 2010 | Briggs & Stratton Briggs Stratton 6200...
Briggs and stratton generator keeps throwing the circuit breaker
Power tools CAN draw heavy loads if the voltage or frequency is off. Both of those CAN be a fault of the generator.
Check the frequency by plugging in a clock with a moving second hand and time it for 10 minutes against a quartz clock. ALSO do a voltage check with another voltmeter.
The 5500 Watt generator should hold 40 amps. Power tools with induction motors like some table saws take a large starting load near this value AND would be sensitive to low voltage AND especially low frequency, both of which will cause much higher current draw.
One MIGHT have to resort to put an oscilloscope on the output to make sure the waveform of the AC output is normal..
Apr 03, 2010 | Briggs & Stratton Power Products 5,550...
Northstar 5500 - no power output, but motor runs fine
Is the Output switch in the "ON" position...the switch is normally on the Outlet manel
Jul 01, 2009 | Northstar Generator 9 Hp, 5500 Watt,...
Electronics - Others Logo
290 people viewed this question
Top Electronics - Others Experts
Are you an Electronics - Other Expert? Answer questions, earn points and help others
