We have just purchased the TH-50PX80A and can't seem to turn it on! When you press the on switch on the TV it flickers green, the screen flickers and then it goes into a flashing red sequence. It won't respond to either the remote or the -/V buttons under the lift door panel on the TV. What do you suggest?
    An expert who has answered 20 or more questions within one hour.
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 150 Answers
Return it for another one and cross fingers.
Posted on Dec 21, 2008
My panasonic th-42pwd8uk tv wont power on. When I press power it clicks to turn on then clicks again and the screen never shows up. No red lights no blinking lights just a solid green light.
Check the capacitors and replace the power components. It is an easy fix if handy with soldering electronics. Tv Repairman may charge less than $100.00 bucks to fix it !
Good luck
Sep 21, 2012 | Panasonic TH-42PWD8UK 42 in. EDTV-Ready...
Green and black screen when I use turn Direct TV box
Try changing the input device to something you are sure, works such as a DVD player.
Switch off TV manually, switch off power, remove plug and retry after 48 hours.
If problem persists, please refer it to a qualified service technician.
Aug 02, 2012 | Panasonic Viera TH-42PX80U Plasma TV
My TH-50PX70A Plasma TV, has lost its picture and only has sound. When you turn it only the green power light flickers on and off rapidly (approx 15-20 times) the TV switches on to a dull black and the...
The most likely issue is that the Power Supply has burnt out, you were able to let it cool at get it to work for a while, but perhaps part of the board has melted enough to cause a short. Repairs will cost approx. $300-500.
Jan 13, 2011 | Panasonic TH-50PX70 50 in. Plasma TV
Intermittent 3 inch green vertical line-5 inches from right side
it you have a repair skills you need to open the TV and make sure all the ribon connectors around the circuit boards are proper connected
and if all seems to be ok, the DG board will need to be replaced.
If you dont have any repair skills I would recommend you to take you TV to a repair shop since this is complex repair
Jun 16, 2009 | Panasonic TH-37PX60U 37 in. Plasma HDTV
Just a Black screen
needs a Y-Sustain board, about a 300 dollar part, unless you have a warinty, also try turning the tv on, after you get a green light, unplug the tv, after 15 seconds plug it back in, sometimes will make tv come back on
Jan 09, 2009 | Panasonic TH-42PD50U 42 in. Plasma EDTV
Sony Trinitron Colour TV Stopped showing and switch light flicker
The vertical output IC has failed/Power to the vertical IC is out/ or there is bad solder on the pins of the vertical output IC.
Dec 01, 2008 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Green Screen
Turn Tv off by power point unplug even for 30 or 45 minutes then turn back on. that way the tv has time to reset back to normal
Sep 07, 2008 | Panasonic TH-50PX60U 50 in. Plasma HDTV
Suddenly no picture
It's doubtful your dog caused the problem; this model has seemed less reliable than most Sanyo products, there are many threads to be found detailing a number of different failures.
The problem is most likely related to the power supply but its behavior could be caused by protective circuits and a failure in the high voltage section.
You may have trouble having the set repaired for less than the cost of replacement. Parts specific to models over 4-5 years of age may be tough to find and you may be without TV for weeks if you choose to repair it.
Feb 25, 2008 | Sanyo HT32744 32" TV
My New LCD TV just turns off
It is most likely a microprocessor issue or a power supply failure. It is easier to let them handle the repair since you have the warranty.
Mar 01, 2007 | Panasonic TC-32LX50 32 in. HD-Ready LCD...
Televison & Video Logo
107 people viewed this question
Top Televison & Video Experts
