My bosch classixx 1000 express wont take the fabric softener
When I put the fabric softener in the machine every time the washing machine cycle leaves it behind. I have tried several cycles and they are all the same. Could you please tell me is there an easy solution to this or do I need to get an engineer
    Problem Solver:
  • 12 Answers
Take out the soap drawer and clean it there will b a blockage in the softener nozzle this will clear the problem
Posted on Dec 21, 2008
Softener won't empty in Bosch Classixx 1000
take out the soap drawer clean in hot water inside the machine where you took the soap drawer out at the top look for the hole where the water runs out it may be blocked with mildew dettox mildew spray is very good at breaking all that down spray in leave for a while put soap draw back in and do a wash without clothing as spray contains bleach
Mar 30, 2010 | Bosch Classixx WFL 2066 Front Load Washer
My washing machine isnt accepting fabric conditioner
have you lifted up the conditioner flap on the drawer, you would of seen a long plastic tube sticking up, this tube gets blocked from time to time resulting in the softner not going into the machine. if you have cleaned this tube when you took the drawer out, then the only other cause is the solonoid vavle is the fault. this is easily replaced.
if you have any difficulties, you may if you wish, email me at appliancesdav@hotmail.com
pallesappliancerepairs.com
Feb 03, 2010 | Bosch Classixx WFL 2066 Front Load Washer
Conditioner drawer not emptying
Do you use a thicker type of softener? When I had this problem with my washer I added water to the softener to thin it out, as it just seems like it leaves a build up that clogs repeatedly otherwise. hope that helps
Jun 19, 2009 | Bosch Classixx WFL 2066 Front Load Washer
Fabric softener dispenser no longer works on my Bosch, the dispenser remains full of fabric softener, all else ok Bosch classixx 1200 express
Remove soap drawer completely from washer, and thoroughly clean all parts of it, paticularly the conditioner compartment..
Get a piece of stiff wire, and make a right angled bend in the end of it, then poke the wire into all the holes in the top of the soap drawer compartment to clear any possible blockage.
This should solve the prob.
Please rate my solution.
Thankyou.
May 20, 2009 | Bosch Washing Machines
A mold smell from my washing machine
IMPORTANT: Read thoroughly. DO NOT add detergent or other laundry products to this cycle.
1. Remove all items from the washer.
2. Open the dispenser drawer and 2/3 cup (160 mL) of liquid chlorine bleach to the bleach compartment. DO NOT use more than 2/3 cup (160mL) of bleach per cycle as this will lead to product damage.
3. Close the washer door and dispenser drawer.
4. Select the Clean Washer cycle or a full wash cotton 104 F wash (40 C). DO NOT use any higher temperature as this will cause unnecessary fumes
5. Press Start and allow cycle to complete.
6. If the bad odour persists, repeat the procedure 1 or 2 more times. This may be necessary if this is the first time you have run this cycle.
7. After the cycle is complete, leave the door open slightly to allow ventilation and drying of the washer interior.
8. Repeat the cleaning procedure monthly.
To maintain the washer freshness:
1. Use only HE High Efficiency detergent.
2. Leave the door open after each cycle to for better ventilation and drying of the washer interior.
3. Use warm / hot water in your machine unless the fabric you are washing requires cold.
4. Use the correct amount of fabric softener.
5. If your laundry room is damp, use a dehumidifier.
6. Clean the door seal of visible residue.
Dec 28, 2008 | Bosch Classixx WFO 2466 Front Load Washer
Bosch Classixx 1200 Express wont spin!!!! HELP
Make sure that all the water has drained from the washer, if it has a filter, remove and clean, it is located behind a removable plastic panel at the front of the m/c, if it still does not spin, suggest you remove motor and check the brushes for wear, this is often the reason it won't spin, but will wash o/k.
Plz rate my solution.
Thanks
Dec 22, 2008 | Bosch Classixx WFC 2465 Front Load Washer
Fabric softener stays in drawre
I had this same problem to
If you take out the drawer of the washing machine and look upwards there are 4 very very small holes get a pipe cleaner and giver them a jolly good clean.
This should then solve the problem
Jul 07, 2008 | Bosch Classixx WFL 2066 Front Load Washer
Washing Machines Logo
372 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
paul
paul
