Question about Sanyo VPC-HD1010 Camcorder
Connection to a TV
Mine is an ordinary TV. I just bought a new 1010 from Japan ( DMX-HD1010 which is the type name specified there but is no doubt the same thing as the VPC-HD1010) and took good photos with it. Photo size has been set to 8M 3264X2448. These photos have been successfully displayed in my computer by method as instructed in a manual for the VPC-HD1000 version. Then i tried to display them on my TV(Toshiba CT-90034). Firstly i set the TV output: TV system as NTSC, the TV Style as 4:3 or 16:9. My camcorder was put on the Dock Station and the S/AV cable included in the package was used to connect to the TV imput , first by the yellow plug and then the S-terminal was tried alternatively. The camcorder was put in the play mode, but nothing was dislayed, neither in the record mode. i don't know what is wrong, since i think I have done every thing understood from the manual which, nevertheless i believe, didn't explain fully every thing in their instructions about the TV playback issues. Unfortunately i am unable to communicate with the Japanese maker on account of language and other problems. Would you gentlemen help me?
Sinecerely yours
Z.L.Yang
  • mlrosier Jan 06, 2009
    I have the same problem. I have my HD1010 connected to my Dell HDTV via the Component Cables. I placed the camcorder in Playback mode, set it in the dock, and push the button on the dock to turn it on. Nothing is outputted to my TV. I've tried both connections for Component on my TV. Nothing. What am I doing wrong?
  • 21 Answers
SOURCE: Sanyo XACTI HD1 Camera-No Pictures / Videos captured.
I have intermittent problems of this type too. Occasionally I get a blank screen in the display mode.
Does the red light on the back of your camera flash while the screen is dark? Mine does.
It is beginning to bug me a lot. It may be because I got my camera wet in the past (and hence I have broken my camera), but I doubt that would result in a partial failure.
I think that the Xacti HD1/HD2 has issues a bit like a blue screen of death on an old Windows computer when faced with storage problems.
I.e. it works but crashes sometimes when it cannot store to its storage medium.
These things work for me
1) Turning the power on and off via the button underneath the screen.
2) Removing and re-inserting the SD card.
3) Turning the power on and off by removing the battery.
4) Using a different (and faster?) SD card.
I am still using my HD2, but I am finding that I must attempt solutions 1-3 about once a day.
It could be because the card I have been using recently is not fast enough. The HD2 accepts both SD and SDHC cards. My SDHC card (which is newer) seems to result in fewer problems, either because the SDHC format is more suited to the Xacti HD2 or becaues the SDHC card I have is faster that then SD card I have. I suspect problems with the speed of the card. I am using cheap SD cards.
Posted on Jan 04, 2009
  • 21 Answers
SOURCE: Xacti VPC-HD1000 "Problem with SD card" "FORMAT / FULL FORMAT"
What was the speed of the second card? Scandisk are good cards. I think that the only important difference between cards is the speed.
>the process stopped 2h30 latter with the batt low level... (2 times),
You could try formatting with the camera in connected to the recharging shoe thing.
Posted on Jan 05, 2009
  • 21 Answers
SOURCE: Sanyo Xacti VPC-HD1- doesn't do anything in record mode
As I have been writing on other HD1/2 problems, sometimes it can be the card which is an issue. If the card is too slow or perhaps corrupted then the device can find it difficult to record.
This and other soft faults (that are reperable by turning the power on and off, changing or reinserting the card, removing the battery) are often indicated by a flashing red recording light.
Posted on Jan 06, 2009
pabloloco
  • 2335 Answers
SOURCE: good day.i just received a present and it's a
Here is a screen shot of the menu you should see when you turn it on set it to normal mode and press the menu button, in english instead of the japanese you are seeing. I am hoping for your sake the menus are laid out the same way and only the words or characters are different.
Scroll down to the second wrench, select the second from the bottom, and press SET. English should be the first option at the top of the next screen. Highlight the first option and press SET.
I uploaded the manual of this camera to fixya, though it may not turn up for a day or two due to processing.
Look through my other posts for this camera and you will find the link to the cameras manual online elsewhere.
I hope that helps.
Posted on Oct 11, 2009
tbreeze47
  • 3083 Answers
SOURCE: Buzz on internal microphone setting. Audio still
I agree that you're having a grounding problem concerning the built in mic. This could be caused by a cracked or broken solder joint on the circuit board, or ribbon connector, if used, but usually condenser mics are wired. You'll have to get in there and look around carefully for the problem, or workaround it by using the external mic.
One more thing to check is that the jack for the external mic is good, and it's solder connections, since in it's "open state", the contacts have to be short-circuited to the internal jack assembly.
Anyway, it's probably some physical problem, versus software, so keep investigating that route.
Good luck, and hope this helps.
Posted on Jan 12, 2011
Kyocera fs-1010 printing problem
Specify the type of paper you are using in driver preferences.
Oct 14, 2015 | Kyocera Mita FS 1010 Laser Printer
Setting apn
Open the main menu and touch "Tools & Settings". Touch "More" and select "Connection". Select "Access Points" and touch "Add profile". Type the settings for the connection. Enter a name for the connection in the "Connection Name" field. Verify the Bearer field is set to "GPRS." Set the "Authentication" setting to the type specified by your carrier. Type the username and password in the specified fields. Enter the access point name in the APN field. Touch "Save" to confirm.
Mar 12, 2014 | LG Encore Gt550 Unlocked At&t Touch Screen...
Recording from DMX 6fire distorted
try isolating the usb that you are using by removing all unnecessary items like extra headphones, cellphones, speakers, battery backup usb connection, you name it. More than likely the static is from that. or try a different usb port if you have removed these items
hope this helps
Feb 19, 2014 | TerraTec Electronic Terratec DMX 6fire...
Roku sees network but can't connect...error code 014
I actually bought mine used for the living room after getting one for our bedroom new. Had no problem with the first one and this one is driving me nuts. I put it up for a few days and brought it back out tonight. I tried to use my code under the right connection and nothing but 014 error. I then used the code for a neighbors connection and it lite green for the first 2 then failed. Then I tried mine 1 more time with showing my connection code and it worked. I don't know why, but, it did. Good Luck!!!
Jun 11, 2012 | NetGear Computers & Internet
I have mine on the dmx setting for it to turn constantly and it's stopping and starting irratically flashing on and off so I'm getting hardly any effect from it at all I'm thinking it's a problem with the...
I am not sure if you are using a DMX controller or a standalone setting. If on standalone, sound triggers a random reversing, stopping and flashing mode. I am NOT sure that a stationary mode is available without being commanded by a DMX controller. If you are using a DMX controller get back to me and we will analyze what the problem is. If using a DMX controller, tell what address you are using and the length of the control cable.
May 01, 2011 | Chauvet 2) Chauvet Double Derby X Dmx Led...
Our DMX-DVD stopped playing dvds. How do we fix this?
Hello
If your DVD player not recogonize DVDs only and it plays audio CDs and MP3 CDs, there is no doubt that its laser pickup unit has damaged and should be replaced sith identical both in type and number. insist on orginal replacement, as Sony uses special type laser units for their EVD drives. Never use a substitute. Its number and other details will be there on its bodey, either laser printed or on a sticker. OK.
Mar 15, 2011 | Sony DMX-DVD Player
I`m in japan and have no idea what this front load ic card does on my sony DRC-MFV1/MID-X KD-28HD600. Any info at all would be helpful . thank you so much for your time mchael
There are two slots on my 42 inch version. One is behind the front access panel and is for the subscription TV service called BS/CS and the other is for a Sony Memory stick to directly display pictures on the TV in a slide show.
I had cable TV in Japan so didn't need the BS/CS service. My TV was bought in 2003 so is a bit old now - not sure if yours has the same features. Model of mine is DRC-MFV1/MID-X MBD-HXIP
Feb 28, 2011 | Televison & Video
My file reads DMX my computer reads "un able to open" does"t know what program created it. any help
Ive just read that DMX is a file type to control stage lighting. I doubt very much windows can open that file type. You must have had software installed to open that type of file or youve downloaded that file type.
Mar 04, 2010 | Dell Microsoft Windows XP Home Edition
Can you plug a DVD player into a Grundig P37 - 1010(B)?
Yes, connection via Scart outlet at back of TV set. Just connected mine today, works perfectly.
Feb 22, 2010 | Grundig GF70-600 TV
I am trying to get gwr614 router netgear to work on echolink need to open ports how can i do this
Problem: var js_3;function initPsDisplay(){js_3 = new PsDisplay({"info":{"controller_name":"PsDisplay","name":"PsDisplay_3","type":"FormField","w_id":3},"attrs":{"label":"","tabindex":"","field_name":"description","cf_id":"","table":"answers","highlight":0},"js":null});js_3.init();}YAHOO.util.Event.onDOMReady(initPsDisplay);
Workaround: var js_4;function initPsDisplay(){js_4 = new PsDisplay({"info":{"controller_name":"PsDisplay","name":"PsDisplay_4","type":"FormField","w_id":4},"attrs":{"label":"","tabindex":"","field_name":"solution","cf_id":"","table":"answers","highlight":0},"js":null});js_4.init();}YAHOO.util.Event.onDOMReady(initPsDisplay); Port Triggering is an advanced feature that can be used for gaming and other Internet applications. It allows you to do port forwarding without setting a fixed PC.
Steps to be followed
  1. Open a browser and type in the following URL: http://www.routerlogin.com or http://192.168.1.1 (depending on the model number of the router)
  2. Type the User Name as “admin” and the Password as “password” and Click OK.
  3. Click on Port Triggering under Advanced menu.
  4. Change the value of Port Triggering Timeout as 20
  5. Click on Add Service
  6. Specify a Unique/User Defined name under Service Name
    Ex: Mails, VPN
  7. Specify the Service User as Any (if all the computers in the network are port triggered or if a single computer on a network is port triggered specify the IP address of the computer)
  8. Select the Service Type of the port to be triggered
    Ex: TCP
  9. Specify the Trigger Port (The port to be triggered)
    Ex: 25
  10. Select the Connection Type of Inbound Connection
    Ex: TCP
Specify the Starting and Ending Port for Inbound Connection
Ex: 113
Jun 19, 2009 | Westell Wirespeed VersaLink...
Sanyo VPC-HD1010 Camcorder Logo
50 people viewed this question
Top Sanyo Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Mark Magill
Mark Magill
Nicola Conroy
Are you a Sanyo Video Camera Expert? Answer questions, earn points and help others
