Question about Philips Magic3Voice PPF585 Printer
Philips Magic 5
I cant get a signal from my hands free unit can anyone help
  • 4 Answers
SOURCE: philips magic 5 classic
it comes without a card and only enough roll to "get you started" when you buy a new roll it has a new card with it
Posted on Sep 09, 2009
0 characters
1 Points
HP LaserJet P3005dn cartridge stuck
If the cartridge is stuck then the only real way to resolve is going to be to force the cartridge out. Sometimes the shutter on the cartridge comes lose or the drive unit jams (would be right side in that case). There is no magic fix, typically brute force is the answer.
Sep 05, 2016 | HP LaserJet P3005dn Printer
Philips magic 5 classic
Jul 31, 2009 | Philips Magic3Voice PPF585 Printer
Language has initially set to German.
Each settable feature of the machine is resettable by OK # # OK and explained on page 19 of the User Manual.
Feb 18, 2009 | Philips Magic3Voice PPF585 Printer
Philips i-jet series vista driver
I had all sorts of Vista incompatibility issue and most were sorted directly at or maybe a sniff at help & support/downloads, if no joy a trusty site that never fails me is
Good Luck!
Press the Blue Button please for my Free Advice/effort,
Thank You!
Paul 'W'
Feb 06, 2009 | Philips MF-Jet 450 All-In-One InkJet...
Does not send faxes
Nope, it's just a big telephone answering machine that prints.
Check the phone line with a regular phone.
Listen for a dial-tone.
Feb 05, 2009 | Philips Magic3Voice PPF585 Printer
Ink for Magic 5 classic
This is the best I could find for you I hope it helps Thank You. I think the first link is you best bet. Good Luck.
Jan 16, 2009 | Philips Magic3Voice PPF585 Printer
E071 0003
E-071 0003: There is an error in the rising edge timing of the signal plate detected by the C sensor.
The transfer drum isnt rotating or the machine "thinks" the drum isnt rotating. Check for mechanical interferance and check the drawer connectors for paper and debris
As for the guest with the E-803 error, thats not really the same thing at all. I guess both error codes have a "3" in it but thats about all.
E-803: During operation the CPU does not detect a 24V output for 5 sec while the transfer unit, the left door, and the delivery door are closed.
Check the aformentioned doors and switches but most likely it is the power cut relay that is faulty. The relay is located on the lower left hand side beside the main power supply. The relay contacts become pitted and burnt over time.
Apr 15, 2008 | Canon CLC 1120 Color Copier
You need to set the machine to receive faxes manually. In my instruction book it's on page 14.
Jan 15, 2008 | Philips Magic3Voice PPF585 Printer
Philips Magic3Voice PPF585 Printer Logo
18 people viewed this question
Top Philips Printers & Copiers Experts
Mark Schmit
Mark Schmit
Are you a Philips Printer and Copier Expert? Answer questions, earn points and help others
