Whoops it slipped!!!
I dropped my sanyo 27 inch tv from a height of about 3-4 feet and now when i turn it on it seems to switch between channels on its own like its stuck in a loop. but when you change the channel it goes to that channel and then it starts bliping through 2-3 channels either way from the channel i am on.
3 Suggested Answers
rulds2008
  • 3866 Answers
SOURCE: i have a 27 inch sanyo tv with out the original
You can try the Channel up/down but if that does not work it looks like a trip to your local radioshack or store with universals. Also there is another solution actually two..
Hook a good old VCR up to that baby and hook the cable to the VCR put the vcr on 3 and bingo or www.remotes.com for your orginal factory remote.
Hope this helps please be considerate when you leaving you vota and feedback.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Posted on May 29, 2010
SOURCE: Sony Trinitiron 27 inch. It's stuck on channel 27
go to menu then channel turn off channel fix that might help ya
Posted on May 31, 2010
Need to fill a 132ft long ditch that is 2 ft wide and 18in high with rock. how many yards do I need
We need to convert everything to a common unit, so let's convert the 18 inches into 1.5 feet.
Volume is length times width times height.
v= 132 x 2 x 1.5
v= 396 cubic feet
To convert to cubic yards, imagine a yard cube. It is 3 feet by 3 feet by 3 feet for a total of 27 cubic feet.
v1 = 396 cubic feet/27 cubic feet per yard
v1 = 14 2/3 cubic yards
So 15 cubic yards should do it.
Good luck.
Paul
Apr 27, 2016 | Office Equipment & Supplies
I have a 58 inch Sanyo flat screen TV, I turn it on everything works fine, shuts down in about 10 minutes! Sound stays on though. If I shut it off and turn it back on it does the same thing!
Easiest TV repair - How to Fix Power [TV turns off, freezes ...
? 6:44
https://www.youtube.com/watch?v=OKklZpTGBGU
Apr 27, 2014 - Uploaded by Keith Fox
I demonstrate in this video how to repair a Sanyo by swap out the... the Sanyo DP47460 that I'm having an issue with. after ~ 40minutes of watching, if I attempt to change the channel or adjust the volume, the picture/screen freezes. ... After ~ 20 seconds, theTV will automatically shut off, then turn back on.
SAMSUNG TV REPAIR- TURNS OFF RANDOMLY - YouTube
? 9:24
https://www.youtube.com/watch?v=7Rj22VNhKXg
Jun 25, 2012 - Uploaded by Tampatec
EASY HOW TO FIX SAMSUNG TV- TURNS OFF RANDOMLY Clicking ... Hi, I've got a Samsung LED TV that switches off after20 seconds and remains off. .... after about couple of minutes, is this the same problem with the tv in the video? .... 10:32. How to repair a Samsung LCD TV with a flashing standby ...
TV Turns On, Backlight Inverter Immediately Turns Off TV ..
Dec 17, 2015 | Televison & Video
How many cu yards to cover 196 sq ft to a depth of 2 1/2"
Hi Bob:
1 cubic yard is 3ft by 3 ft by 3 ft.
3 times 3 times 3 equals 27, so
1 cubic yard equals 27 cubic feet.
2 1/2 inches divided by 12 inches equals .2083333 feet
196 square feet times .208333 feet equals 40.83333 cubic feet
40.83333 cubic ft divided by 27 cubic ft equals 1.5123456 cu yards.
Ta Da!!!!
May 01, 2015 | Refrigerators
I am lying rock in my back yard so for me buy rock I Need to change feet into cubic feet
60 x 4 x .33 = 79.2 cubic feet. 27 cubic ft = 1cubic yard. 79.3 / 27 = 2.9 cubic yards
Mar 18, 2015 | Office Equipment & Supplies
How do I find the capacity of a grain bin
Do you want to find the cubic inches or feet..take lenth times width times height that will give you cubic inches if measuring in inches or cubic feet if measured in feet. If want square yards device that number by 27 " there are 27 square feet in a square yard " from they you must find out how many square feet are in a bushel etc. Hope this helps good luck...
Oct 13, 2014 | Garden
How to calculate cubic feet ?
Calculating the cubic feet of a space requires multiplying the area of the bottom times the average height. You get the bottom area by multiplying the length times the width. Remember, to get cubic feet, you need all your measurements in feet to start with.
Here is your formula:
VOLUME (in cubic feet) = Length (in feet) X Width (in feet) X Height (in feet)
If it's a rectangular room you're working with, it is all straightforward. If there are irregular walls, it may be necessary to divide up the room into rectangular sections and then add together their individual volumes. If the ceiling is sloped, you need to use the height that has the same ceiling area above it as below it. Good luck! Truly.
Jul 25, 2014 | Building Materials
The width of my refrigerator is 27. Inches. What is the cubic feet
That depends on how high and how deep the refrigerator is.
For example, if the height and depth are both 27 inches then the volume is about 11.39 cubic feet. If the height is 36 inches and the depth is 27 inches then the volume is about 15.19 cubic feet.
May 25, 2014 | Refrigerators
Is my apex tv AT2702 high def??
According to apex its not and does not have a digital tuner the only way this can be high def would be 720P meaning 720 lines progressive scan.
Your aspec Ratio is 4:3 this indeed is a standard TV without a digital tuner so you will need a digital setop box or a digital tuner.
High DEF is not considered digital its conidered how many lines are displayed on the TV. For example 720p, 1080p .
  • Silver, 27-inch monaural television; 29.6 x 23.2 x 18.7 inches (W x H x D)
  • Front-panel audio/video input accommodates a camcorder, VCR, or gaming console
  • 3 rear AV inputs (including 1 S-video input), 1 RF antenna input
  • Channel scan, channel recall, closed-caption display
  • Offers V-Chip parental control, sleep timer, auto-off, and a full-function remote control
Technical Details
  • Brand Name: Apex
  • Model: AT2702
  • Display Technology: CRT
  • Display Size: 27 inches
  • Image Aspect Ratio: 4:3
  • Speakers Included: 2 speakers
  • Height: 18.7 inches
  • Width: 29.5 inches
  • Depth: 23.2 inches
  • Weight: 88.2 pounds
Jan 27, 2011 | Apex Digital AT2702 27" TV
I have a 27 inch sanyo tv with out the original remote,,,the tv is stuck in video mode how do i get to the channel settings so i can watch cable on it
May 29, 2010 | Sanyo DS31520 31" TV
May 24, 2010 | Sony FD Trinitron WEGA KV-27HS420 27" TV
Televison & Video Logo
54 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
