Question about Pioneer SD-P5795W 57" Rear Projection Television
PROJECTION TUBE (BLUE) PERFORATION
The blue tube(part n. AWI 1393) developed a perforation and it was replaced. After the unit was turned ON the problem occurred again instantly with the newly replaced tube. I?m afraid of going for a 2nd replacement and have the same problem again. Can anyone give me a clue on what is going on?
  • 1 more comment
  • Luiz Fernand Apr 05, 2007
    The unit arrived with a perforated tube and it was replaced in my lab. Immediately after turning set ON the tube was also perforated.
    I need a clue on what could be causing this problem because my loss with the replacement tube is really high.
  • Luiz Fernand Apr 06, 2007
    It?s a true perforation so symmetrical, that seems to have been made with a drill, laser beam or a high speed steel bullet.
    The implosion issue did not occur because of the glass thickness. I do have pics, but the blog has no upload option.
    President:
  • 1,284 Answers
I would think there would be a warranty on your repair. Sounds like the first repair wasn't done correctly.
Posted on Apr 05, 2007
  • Don
    Don Apr 06, 2007
    what do you mean by "perforated"? A line horizontal or a vertical line burned into the CRT? If so then fix that issue first such as a possible bad deflection yoke on the blue CRT since it seems to be the only CRT with a burm in it.
Turns on for 30 sec then goes bright blue and goes back into standby. turn back on it does it agian
This is blue CRT problem in tv as it is rear projection tv that has three CRTs red-green-blue inside to project color picture on front screen.
Blue CRT (tube) will be replaced to fix the issue and it is job of Pro because lots of adjustments are required after replacement of tube.
Local tv repair shop will help you for that.
Thanks
Oct 02, 2010 | Sony KP-51WS500 51" Rear Projection...
I have a KP-51HW40. Everything works fine but the screen stays blue. What could the problem be?
if blue picture tube is blooming with retrace lines? it's because it developed internal short. you might try to turn down screen on blue picture tube. always mark with fingernail polish so you can return to starting position. J.D.W.
Jun 24, 2010 | Sony KP-51HW40 51" Rear Projection...
Turn tv on screen is light blue then picture fades then, screen shuts off???
Blue tube is bad need to replace blue tube.. Tube no longer avail will need to be special ordered and my run from 350.00 up to replace part.
Feb 04, 2010 | Sony KP-57HW40 57" Rear Projection...
When tv is turned on the screen fades to blue
I think its Sony rear projection TV that has 3 picture tubes.
If that's true then Blue Tube seems bad and requires to be replaced.
Let me know exact model of TV to find out blue tube price info.
Nov 04, 2009 | Sony Televison & Video
Blue shadow
The blue tube if fine
you need to replace two convergance
chips or have a shop do it.99.9% shure
the chips are cheap around 20.00-30.00
etch and even less for the generics 10.00-16.00 ,so dont let the shop charge you
to much for the dirt cheap parts.
Knolage is Power
Jul 01, 2009 | Toshiba TheaterWide 62HM84 62" Rear...
Blue screen
The blue picture tube has gone bad. Sadly they are no longer availible for that unit. But the blue tube assembly can be sent back to a company called Video Display. They rebuild the tube for a very reasonable price. The hitch is that it takes a professional tv tech to reinstall and align the rebuilt tube. Most respectable shops will do this work but the repair is spendy. Usually around $450 to $500 or more.
May 13, 2009 | Sony KP-51WS500 51" Rear Projection...
Blurry picture
The CRT fluid in the blue and green tube are most likely clouded. The set is still good. You just need to replace the fluid. Check with the site www.TvRepairkits.com - they are working on developing a fluid kit that includes a photo instuction quide.
Nov 12, 2008 | Philips 9P5034C 50" Rear Projection...
Blue Screen
You have a bad blue picture tube. If you replace it the red and green will be weak and probably go sooner than you think. Everytime I had to replace a tube in a sony projo tv i had to replace all 3 picture tubes at the same time. It's very expensive if you don't have any type of warranty coverage.
C-Dog
Feb 10, 2008 | Sony KP-65WV700 65" Rear Projection HDTV
KP-51HW40
the unit needs either a screen control or a new blue tube.If it needs a tube,sony is aware of many units with manufacture defective tubes
Mar 05, 2007 | Sony KP-51HW40 51" Rear Projection...
Pioneer SD-P5795W 57" Rear Projection Television Logo
Top Pioneer Televison & Video Experts
Jaime Hernandez
Marvin
Marvin
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
