Hoover washing machine keeps tripping electric?
    Problem Solver:
  • 12 Answers
The heater element going to earth or motor going to earth also check fof hole in door seal water could b dripping onto electrics if non of these work get mains filter inside machine checked
Posted on Dec 21, 2008
  • 135 Answers
SOURCE: Hotpoint WM51 Washing Machine keeps tripping the electric
Ok that rules out the heating element. There are a number of possible causes so bear with me while i go through them.
Can you open the door? If so leave it open then turn on the machine. Does it trip?
Posted on Jan 23, 2009
  • 193 Answers
SOURCE: error code E03 on washing machine
eo3 water not draining,check for kinked drain hose,check that drain filter is clean
Posted on Sep 28, 2009
dmftrucker
  • 1922 Answers
SOURCE: why does my washing machine trip the electric
run the machine, after it trips, unplug and carefully touch the motor,it may have a bad capacitor, or dry bearings causing it to draw excessive current,if these 2 things are not it, then look for a bare wire that may be touching case during this part of the cycle,and if you can get an "Amprobe" it reads current and check machines current draw during the start to trip current
Posted on Oct 28, 2009
MakeupWizard
  • 39 Answers
SOURCE: washing machine keeps tripping electric switch
Hiya,
there is a few things that will do this to your electics 1st & formost if your trip switch is tripping off remember this is a safty device to prevent fire so ignoring the problem & switching the power back on to try again could run the risk of fire!!
when the power trips you will need to know at what point in the wash this happens if its when the machine is emptying then it would be a pump issue if the machine is emptying no problem then the issue is more likely to be the motor either of which would need to be replaced if you are having these problems.
on rare ocasions you can spring a leak & if water gets on the electrics this will also trip the power but this is 1 of the least likely posabilatys.. rest assured if the power is tripping off then your home electrics are working fine & to confirm all sockets run from 1 main fuse all lights run from a second main fuse then there is a few other bits that run on there on fuses too i.e. cooker, power shower etc.. remember always get a qualified electrician to work on your electrics to ensure the job is carried out correctly
Hope this helps
Posted on Apr 22, 2010
SOURCE: My Hoover Optima OPH 714 D washing machine won't start
Hi, the lights are coming on, but the door lights keep flashing and then nothing happens
Posted on May 09, 2010
My hoover optima washing machine is tripping my electricity supply. Have tried disconnecting heating element and looking for damaged wires.
Ian if the circuit breaker is a rcd it will trip off the supply if it
normally detects a very small leakage or unbalance of around 35 m /amps this could be a small water leak onto live parts in the machine or a minute short to earth on one component ,make sure all parts are dry / is it tripping when you switch power on to machine or does it trip when machine is in cycle mode.
1. its as first suggestion 2. it's a component like pump or drive motor that;s causing problem. hope this is of some help,g.luck
Nov 11, 2016 | Hoover Washing Machines
Washing machine keeps tripping electric when the door locks
Washing machine tripping or fusing electrics
www.whitegoodshelp.co.uk > ... > DIY Washing Machine Repair Help
Jun 26, 2013 - A Washing machine tripping or fusing electrics is a fault you can't really deal with unless ... If washer has tripped the RCD or fused the plug but now won't work properly. ... Here's an article on Washing Machine Door Will Not Open ... If youkeep resetting it without fixing the cause of the tripping it can blow ...
6 common washing machine problems and how to solve them
www.appliancesonlineblog.com.au/.../6-common-washing-machine-prob...
Feb 10, 2014 - As mentioned earlier, front loader doors lock during the cycle to prevent the water from ... The washing machine keeps tripping the power!
Maytag ,Whirlpool Washer Diagnostic - Breaker tripped and ...
? 7:00
https://www.youtube.com/watch?v=dx2vCzO8828
Jun 13, 2013 - Uploaded by ApplianceVideo.com
Yeah, keep it ... Maytag ,Whirlpool Washer Diagnostic - Breaker tripped and will not always run - .... TROUBLESHOOTING Top Loading Washing Machines in ... Maytag Neptune Door Locked but No Spin - R11 is not burnt ...
Washing Machine keeps tripping the electrics -
Dec 29, 2015 | Washing Machines
My electricity trips when I plug in washing machine. What could be the cause
SHORT IN UR MACHINE, WIRED WRONG FROM REPAIR JOB? OR SHORT IN UR BREAKER AND NEEDS REPLACING, DOES OR IS THE BREAKER THE RIGHT AMPERAGE FOR THE BOX?
Sep 26, 2014 | Hoover Washing Machines
Hoover ac 120 washing machine trips power
Have you tested the actual path from the breaker box? Meaning have you made sure that you have the amp breaker? Have you put an ohm meter on the "dead wire" (make sure there is no power on the leads and test the copper)? Have you made sure that the power neutral and power ground are not swapped (there is a test plug that is cheaply bought at the hardware store)? Have you check the wiring diagram for the machine and made sure the machine is wired right (found online usually)?
Feb 25, 2014 | Hoover Washing Machines
Hoover primera washing machine keeps tripping electrics when tured on.
Possible that there is higher current drain which trips off the circuit. This can be due to moisture or dampness in the circuit , coils or the motor. You need to remove the top panel and dry using a dryer. check the connectors, check the main line , the motor circuit. Isolation of the motor or the heater can confirm the short if the circuit stays. Check the main power to the panel and allied circuit for possible capacitor leak or short.
Mar 16, 2013 | Washing Machines
Hoover primera keeps tripping electrics when i turn it on
Short circuit in m/c. If happens when turned on at wall socket, probably mains filter, if when turned on at front, could be a lot of things, basically anything inside, would need it opened up to track
Mar 16, 2013 | Hoover Washing Machines
Hoover nextra keeps tripping electric when put on
disconect motor and try again if still trips try pump,if trips again disconnect heater.This is prosess of elimination.
Oct 09, 2008 | Hoover Washing Machines
DISWASHER KEEPS BLOWING THE MAINS TRIP
FOUND SOLUTION...THE LITTLE CAPACITOR THING THAT SMOOTHS OUT THE FLOW OF ELECTRICITY TO MACHINE WAS BROKE. COST £5.00 FOR GENUINE HOOVER PART. FIXED EASILY TAKES ABOUT 3 MINS.....SORTED
Mar 25, 2008 | Hoover 24 in. HD83M Free-standing...
Hoover CA230 1300 Special Edition Washing Machine
Should you have to use un due force to get the filter undone on the Hoover 1300 special deition washing machine
Jan 14, 2008 | GE S8000E
Washing Machines Logo
180 people viewed this question
Top Washing Machines Experts
