Question about Smeg 23 in. SE64 Gas Cooktop
Smeg SE64 Gas cook top
Lodger had been cooking- had a Problem -possibly a spill. Switched cooker off at wall. Cooker is now cleaned. Now all 4 ignition units spark repeatedly as soon as wall switch turned on without turning control knobs If the control knob is turned ring lights correctly but the other ignition units continue to spark Also the ovan and grill do not seem to work at all. Please help as i am hungry and in need of a coffee!
  • 1 more comment
  • Ruth Marshall Apr 07, 2007
    Still does not work after 6 days...any other ideas
    I can only set the hob by switching it on at the wall...then the ingnition sparks start then. So cant leave it on
    How long will it take to dry out? I can now use the hob with a match, but will this solve it in the long term.
    Thank you for your assistance I appreciate it
  • rothko Jun 09, 2008
    I have the same smeg hob, and for several weeks now the ignition on the hobs has not been working - it had been cleaned quite rigorously, so it sounds like this could be why, but it has not fixed itself automatically. Can anyone suggest a solution?
    New Friend:
I think you need to replace your cook tops spare parts. It is easily available here in Sydney, Australia.
Posted on Aug 02, 2013
    President:
  • 1,462 Answers
Problem with hob is probably water ingress in area of ignition unit - will probably cure itself oven is a completely separate unit from hob. problem with it is that you have to re-set the clock - you have it on automatic. after power outage, oven clock always has to be reset
Posted on Apr 04, 2007
  • douglas smith Apr 07, 2007
    which bit don't work? hob or cooker? (they are completely separate honest. did you try re-setting the clock? to work the hob, you can switch off at mains - it should be wired on a separate circuit from the cooker - and use a match to light hob. using it will help dry it out
  • douglas smith Apr 08, 2007
    use hob for a few days switched off at the wall and see what happens. the other thing which has occurred to me is to ease the hob knobs up slightly - you may have pressed them down when cleaning. (knobs are just a tight push fit)
My GE Monogram gas range will not light. The igniter keeps going off but the gas will not light.
Hi, sometimes cooking spills stop the ignitor from working. Clean the cook top thoroughly and try it again. Spills can also make the ignitor go off randomly when you are not operating your cooker. Check if the ignition point where the zap comes from is not turned or bent too far from its original position. If you have a gas shut off make sure it is fully open to supply enough gas. If all else fails buy a cheap hand held ignitor to start your gas stove. If the cause is a spill which sometimes the problem can persist even after cleaning it may take a while for it to work again. If the problem is with all six burners then your ignitor probably needs replacing. When you hear the ignitor zap check to see if the electronic zap appears to jump across to the edge of the burner. If it doesn't it will not light the flame no matter how many times you try. I hope this helps you.
Aug 21, 2012 | General Electric GE Monogram 48""...
The igniters are constantly clicking after cleaning the cooker. What can I do to stop the clicking?
This a coomon problem thaty occurs when you clean the "cooker". Residue from cleaning products may be preventing the ignitor from producing a spark (Arc) to the base of the burner. If you are able, clean the ignitor and adjust it. f you have too much space between the ignitor and the base of the burner, it will prevent the burner from igniting. You should only have a little more space than the thickness of a nickel between the burner base and the ignitor. Good luck
Jul 11, 2010 | Cooktops
Cooker igniters are sparking constantly
Please disengage circuit box.
There is probably a short,which would require a licensed repairman. The expense should be minimal, especially next to the high price of a housefire.
Mar 04, 2010 | Cooktops
All 4 of the hobs started sparking/ clicking after cleaning the cooker top. Now they won't stop sparking/ clicking.
there is probably some water in unit that is causing the unit switches to not work. you can try to use a hair blower to thoroughly dry components.
Feb 26, 2010 | Smeg 23 in. SE64 Gas Cooktop
1992 glass top gas cooker ingitors keep clicking just out of the blue. We realize there is no gas being delivered until the knobs are on but we have to unplugg the cord from the wall to keep them from...
sounds like your spark module is being grounded out could be from something you spilled on the cooktop or it is just gone bad. if it is water it could take a week or so to dry out then problem will go away. have you spilled anything latley?
Sep 20, 2009 | Cooktops
Viking 30" gas professional series cooktop sparking problem
And before that Most likely one of the ignition switches (they are under knobs) got shorted possibly due to spilled liquid or a cleaning stuff sprayed on. In that case it should stop sparking after a switch drys. Still no go replace the spark control unit.
Thanks
Kindly rate the answer
Kevin
Jul 06, 2009 | Viking 31 in. VGSU101 Gas Cooktop
Ignitor will not stop sparking on AEG Electrolux Cooker Hob
gud day,try to clean the bottom of knob control by removing of knob then clean if by using a vacciumm,if u want to use manually ur cooktop unplug the unit to stop the cliking,then use macthes every time to on the gas cooktop.
Jan 09, 2009 | Cooktops
No Ignition
Dirt. Spilled oil, grease, milk etc. act as isolator and prevent contact between burner and casing (mass). You need to clean up burners, scrub all the dirt and make sure their seats are cleaned too (brass elements below burners).
Mar 14, 2008 | Cooktops
Smeg 23 in. SE64 Gas Cooktop Logo
1,291 people viewed this question
Top Smeg Cooktops Experts
Steve Allison
Steve Allison
freddyfox
Andrew Taylor
Andrew Taylor
Are you a Smeg Cooktop Expert? Answer questions, earn points and help others
