Question about Philips Garbo Multimedia Projector
Mi projector fonction badly.
-The lamp of mi projector LC 6231 is fused and it is replaced with a compatible bulb (B CEL LCA3116, but repeatedly, when i connect the projector  the lamp work correctly only a minute. After, the pilots of the lamp and temperature turned blinking red and the project turned off. The fan is apparently well.
  • 10,594 Answers
Compatible Lamp is producing much heat and heat sensor activated with in one minute or so.
Please use Original Philips Lamp for your projector.
Posted on Dec 21, 2008
  • Shahid Electronics
    Shahid Electronics Dec 21, 2008
    Let me know have you reset the Lamp Hours in projector?
    This is necessary when you replaced lamp in projector.
    Please do the following to reset lamp hours.
    1 Press Menu.
    – The menu bar appears on the screen.
    2 Use cursor control to select ‘Settings’ in the menu bar.
    3 Use cursor control to select ‘Lamp counter’ in the sub menu.
    4 Press OK for 3 seconds to reset the lamp counter.
Quiero dar de baja de mi cel wap.wingo.mx
hola kieroo dar de baja wap.wingo.mx me acaba todo el saldoo x favor mi num es 6411021570... graxiias.
Apr 21, 2014 | Health & Beauty
Blinking green power light on ux60 projector
I would refer to this page to determine if you ahve an internal problem or if your lamp is bad. Make sure you buy a lamp that has an original bulb inside and not a compatible. Original bulbs cost less than OEM but more than OEM-Compatible(knock off) but they last as long as OEM bulbs. Your SMART Hub Doesnt Turn your UX60 Projector On or Off 146535 SMART...
This link goes to a highly reputable company. They have the same Osram bulb as the OEM. SmartBoard Lamp
Mar 04, 2014 | Smartboard Smart Board 685ix, UX60...
Origional Epson 3010 bulb burned out after 2 years. New bulb died in a month
our company supply the Original lamp ,unit price is USD200
any questions, feel free to contact me
We supply original projector lamp,bulb,accessories,Lcd panel,Lens,DMD chip,color wheel,motherboard,powersupply,ballast... with high quality and competitive price.
have a nice day!
Jerry,Lampdeng Limited
Dec 08, 2013 | LC EPSON ELPLP68 / V13H010L68 Projector...
Mi proyector es panasonic PT-L550U, que tipo de formato es proyectado
ave a nice day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
Jerry
Lampdeng Limited
Mobile: 0086-13178867858
Wechat ID: 008613178867858
Whatapp ID: 008613178867858
Skype: lampdeng@hotmail.com
http://www.lampdeng.com
Nov 25, 2013 | Panasonic ET-LAE500 Projector Lamp for...
Codigo para desbloquear nokia 1616-2b
oa..... quien mi puede ayudar a desbloquear mi cel nokia 1616 2b mi imei es 012598009095141
Jul 02, 2013 | Cell Phones
Como eliminar enterfactory de mi celular
quiero desactivar de mi celular entertainment factory
Apr 26, 2011 | Health & Beauty
My projector overheats quickly
Two possibilities:
1) Air filter is clogged and preventing proper air flow
2) Lamp is getting old and is less efficient, creating excess heat.
For option 1, check the air filter located on the bottom of the projector. Page 81 of the manual details this process:
http://www.wrcs.k12.mi.us/Technology/How%20Tos/Ceiling%20Projectors%20PGC45X.pdf
Once you have removed filter,either replace or clean out with vacuum or simply blowing out the dust
Option 2: if you have used the projector for over 1500 hours, there is a good chance the lamp is close to the end of its life cycle. Check to see if the lamp replacement light is on; it is just below the power button on the unit.
If you are feeling adventurous, you can take out the lamp by following the instructions on page 86 of the manual: http://www.wrcs.k12.mi.us/Technology/How%20Tos/Ceiling%20Projectors%20PGC45X.pdf
Once removed from the unit, see if the lamp has any bubbles or crystallization. The crystallization makes the mirror in the lamp look muddled, rather than crisply reflecting light.
Hope this helps.
Mar 03, 2011 | Sharp Notevision PG-C45X Multimedia...
Doest function.no image projection,fun does not function
fuse on ac filter board. if that's ok, there is a power supply issue.
May 31, 2009 | InFocus PROJECTOR LAMP, Projector Lamp FOR...
Bulb Life
hi,
This is 2000 Hours, 160 Watts, UHP lamp. dont keep it on always.Check the usage and then replace the lamp. It's better to turn off the projector after each class.
The lamp is around $400.00 for Eiki LC-SD15.
Viren
Rave Services India
Feb 07, 2008 | Eiki LC-SD15 SVGA LCD Projector Multimedia...
Open Questions:
Garbo Mirror Mode not selectable in menu My Philips Garbo Matchline is about four years old. After being switched off for the past six months, it is no longer possible to select Mirror mode from the Picture menu. (We need to do this to invert the projected image, since the projector is ceiling mounted and thus upside down). This worked fine for the first three years of the projector's life. Not any more, however. Using either the remote or front panel buttons, I enter the menu, cursor down through the Picture Menu options until I reach Mirror at the bottom of the second page. This reveals a set of four sub-options: AB / BA / BV / VB [approximately], representing the four ways of orienting the display. When I try to move the current selection from the default AB, the entire menu rotates so that the AB option moves with the cursor. The new menu then looks like this: VB / [AB] / BA / BV and [AB] is still selected, even though the cursor is now on the second item on the line. Moving the cursor right does the same again (rotates entire menu, without changing the actual selection). This is quite bizarre. I've tried resetting to factory defaults, making the change both with and without video sources connected, using alternate buttons on the remote while in the menu, and (of course), Philips technical support. Nobody has anything to suggest. The projector works perfectly in all other respects, and in particular, other menu options can be selected correctly with no strange effects. Suggestions appreciated!
Feb 28, 2017 | Philips Garbo Multimedia Projector
Philips Garbo Multimedia Projector Logo
Top Philips Office Equipment & Supplies Experts
matt martin
matt martin
Are you a Philips Office Equipment and Supply Expert? Answer questions, earn points and help others
