PC Hardware Troubleshoot, works slowly,IDE not detected sometimes
Hello Everyone!
I've a problem with my old PC.
Whenever I boot up my PC, sometimes it doesn't detects the connected IDE (HDD and DVD-RAM) and low beeps which are barely audible are produced. The time interval in the beeps is random, sometimes it beeps 2 times in a second and sometimes in 5-10 seconds per beep. I know the beep codes but I didn't find any beep code which occurs for random intervals of time. When by luck, if the system starts working normally, while working on it for some hours or I can't give any specific times because it happens for random time, the system again starts giving that same beep sound with the random intervals and system hangs.
After several reboots, the PC boots and the Windows Operating System installed on the machine boots extremely slowly. It takes around 1-2 minutes for the splash screen. After the splash screen, I've a scheduled disk check as the last time the system hanged. When I let the disk check to start, its taking more 15 mins to complete even the HDD is empty as I formatted the HDD and reinstalled Windows few weeks ago. Now, when I cancel the disk check after splash screen, Windows starts working normally, all the application takes normal time to load but the mouse pointer doesn't works smooth, it goes from one end to other end after a small break.
I tried to diagnose the PC by removing its ram from the slot, cleaning the slot and ram and put it back in the same position. After this, my system does not give that beep sound for some bootups but this whole scenario start again and the system works too slow even there is no new application installed and the HDD is totally empty. I sure this is some hardware related issue, but I can't make sure where is the real problem. If its the RAM or the Motherboard or the HDD? Please help me out in this issue.
My system configuration is as follows:
Motherboard: Intel 845GV Chipset (Gigabyte GA-81845GV)
Processor: Intel Celeron 2.4 Ghz (Code Name: Northwood, BID: 10)
RAM: Hynix DDR 256mb, 133 Mhz
HDD: Seagate 80 GB PATA (Model: ST380021A)
Thanks for reading my query! ;o)
  • 51 Answers
Try go to this website download Download SeaTools for DOS now!
and run diagnostic to hdd but remember stand by floopy disk to create diagnostic disk.IF this diagnostic disk check said no error so you hdd is ok.try put the ram to different pc may be is RAM or motherboard faulty
Posted on Dec 21, 2008
GA-EP41-UD3L problem with SCSI/IDE
Sounds like the motherboard bios is only capable of booting from drives connected to the motherboard's ide connector and not additional / or external ide connectors. Looks like you would have to have 1 HDD and the CDRom Drive on the built in ide connector and the other hard drive on the extra ide connector you added. Although that would probably stop the other HDD from booting. Have you thought about putting both operating systems on the same drive. I do it all the time.
Feb 11, 2012 | Computers & Internet
IDE HD Not Detected
Computers sometime act crazy.. Go into Bios Check to see if the Dimm is turned on
Nov 30, 2011 | Dell OPTIPLEX GX1 PIII-667MHz 128MB 10GB...
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they are probably old and faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error
hope this helps
Jan 24, 2011 | EliteGroup ECS P4M800-M Socket...
Dvd drive not detect in IDE secondary
Go to the BIOS settings and in the main menu and set the first boot device as cd rom. Then reboot ........
Apr 24, 2010 | Computers & Internet
A1430N Moved my two working ide drive 250G over
Thank you for using
FixYa for your problem
IDE will try to boot first when pluged in, sata will not boot. I think there is a adjustment in the BIOS setting to have the SATA boot first
Please rate our solutions and if you still have problems please call back for more ideas to help you
Richard Scott
Technical Support
New Zealand
Nov 18, 2009 | HP Pavilion a1430n (ER900AA) PC Desktop
My second hard drive (slave) sometimes works and
try to find out if all cables are properly attached, that in bios both IDE channels are set active and ide(hard/drive detection) is set to auto.
Exit saving changes. reboot and wait if in boot-up screen hdd is shown. Now you have made sure the hdd is being recognized from the hardware side.
Boot up windows and check if it is listed in the explorer.
IF yes, youre lucky.
if not, run hardware detecton and wait for results.
IS it now?
if yes goto properties, tools and check disk thoroughly.
back-up data, format it(long version!). check again.
(Now any invalid or broken clusters are marked)
Hope this solved the issue!
Aug 04, 2009 | Gateway Computers & Internet
Hello Everyone, I have an old PC windows98 with maxtor 90840D5 hard drive. Sometime back I've removed the hard drive and attched it to the new PC, so as to access the old files.Today when I try reattach...
you need to detect your harddisk in bios setup.
For that when you power up the computer press "del" key to enter in bios.
Then check your harddisk is detected in bios.
If not cxheck power cable and ide or sata cable connected to harddisk.
Reconect both connection to harddisk then check.
Aug 01, 2009 | Maxtor DiamondMax 3400 (90840D5) 8.4 GB...
PC Cannot Boot
Common windows problem,you need to wipe your drive and reinstall your operating system
Jan 08, 2009 | MSI K8MM3-V Motherboard
Cant boot from CD Drive.. cannot be seen in the bios
Make sure the hard drive is connected to the ide cable that has a blue end. Don't connect anything else to this cable. when the pc is booting up watch the screen for the option to enter setup usually Del, or F2. Once into the bios see if the boot options are set to cd first and ide 0 second. You can also see if the hard drive is being detected in the bios.
Hope this helps. Let me know.
Nov 15, 2008 | Dell Dimension 4700 PC Desktop
Computers & Internet Logo
136 people viewed this question
David Payne
David Payne
