Question about Panasonic HDC-SD5 Flash Media Camcorder
SD card unreadable
I bought a cheap SD Card. Worked fine when playing my video through the camera. Then I plugged into a card reader connected to my PC and it's all gone! Tried a freeware program that recovers files off SD cards but no go.
Has anyone experienced this? Is this a card problem or a reader problem ?
  • 599 Answers
Does card have notch / ...switch.... on side that needs slid to other position to be read?
Posted on Dec 21, 2008
Bought a new Sandisk 8GB microSDHC card (Product Description : Micro SD/8GB SDSDQ-8192-P36M) for my Nokia E51. It worked fine for two months, in this had many times used in PC with my card reader for...
try formatting ur card with the following steps:
right click om my comp then click on manage then disk menagement and right click on ur card then format it will forcely format ur card. gud luck....
Oct 19, 2009 | SanDisk 8GB microSDHC Memory Card with...
My netbook screen resolution is no good for canon instal disk
You didn't provide what netbook you got, but most netbooks today got built in SD-card readers. If your netbook does, the best solution is to remove the card from the camera and insert it into the netbooks card reader. The Canon G9 supports SD-cards, as well as SDHC, MMC, MMCplus and HC MMCplus compatible cards. I suggest using a SD or SDHC card.
You will not need to install canon software to access your pictures if you use the card reader, you will be able to access and copy/move them from the memory card in explorer (or equalent if you use Linux on your netbook). Also, it's a much faster way to move pictures from the camera to the computer, because the card reader interface is a lot faster than the USB interface to the camera.
If your netbook does not have an internal card reader, you could buy a SD card with built in USB, such as this one: http://www.cdrdvdrmedia.com/ultra-sd2-card-2gb-sandisk.html This SD card behaves like a normal memory card in your camera, but plugs directly to an empty USB port on your netbook. The card will be accessable as any removable storage, in Explorer (or equalent if you use Linux).
A third solution would be to get a cheap USB 2.0 card reader. Almost any cheap USB 2.0 accepts SD cards, and would be a lot faster than connecting the camera to the netbook with a USB cable.
I hope this help you!
/Chris
Jan 19, 2009 | Canon EOS 400D / Rebel XTi Digital Camera
Connecting my cam panasonic fz28 to my pc
To solve this problem, I bought an SD card reader.
All you have to do is plug your SDHC card into the reader, then plug the reader into your USB port, and you should be able to access your images/videos.
I have the same 8Gb SDHC 15 MB/s plus the same camera (FZ28) and it works perfect for me. - Doing it this way is much easier.
You can find SD card readers (Which will work also for SDHC cards) on ebay for a small price of around 2-3 pounds (£) at cheapest. - Just type in "SD Card Reader".
Hope this helps.
Jan 07, 2009 | Panasonic Lumix DMC-FZ28 Digital Camera
I have a Canon A720IS 8.0 meg camera that I'm having problems with. I have tried several SC cards; 1 gig and 8 gig. Same results. The pictures and video look fine on the LCD, but when I download to the...
This sounds like corrupted files. Are you downloading these pictures using your camera (ie through a USB cable attached to your camera)? If so, may I suggest using a USB card reader instead. If already using a card reader, suggest buying another one as it may have gone bad.
You plug the SD card into the card reader, and then plug the reader into the USB port of your computer. It essentially turns your SD card into a hard drive that you simply copy and paste or drag and drop the files from onto your computer's hard drive. It's very simple, no software involved.
Card readers are much faster in downloading files and are much less likely to incur file errors. For these reasons most (if not all) professional photographers use card readers instead of downloading directly from the camera. Card readers are also very inexpensive. Here's an example of a nice cheap one. Try it, see if it fixes your problem. If so, then consider getting a better one later:
http://www.amazon.com/Memory-Reader-Writer-MiniSD-MiniSDHC/dp/B000I4RFO2/ref=sr_1_14?ie=UTF8&s=electronics&qid=1231091003&sr=1-14
Jan 04, 2009 | Canon PowerShot A720 IS Digital Camera
USB connection problem?
The Best solution is to get an SD card reader. Then you take the SD memory card out of the camer, put the Sd card into the reader and plug directy into a USB port.  They are very cheap to buy and quite handy.
Sep 05, 2008 | Pentax Optio M20 Digital Camera
Pentax Optio 50 Digital Camara
Are you just plugging the camera straight into the computer? Does it come with software to install? Try plugging the camera in while the computer is off and then turn the computer on with the camera plugged in. Otherwise get a SD memory card reader that the SD card can plug directly  into and this connects straight to the computer.
Sep 03, 2008 | Pentax Optio 50 Digital Camera
Communication error
If your SD memory card contains more than 1,000 images, the camera will display "Communication Error". Use a card reader (if available) to import your images into the computer, or see about having some CD's made at a photofinishing business.
May 20, 2008 | Canon PowerShot SD750 / IXUS 75 Digital...
Cant find pics
The simplest solution is to buy a cheap SD card reader and connect it to your computer. Then put the SD memory card from the camera in the reader. Windows XP will open a dialogue window asking you what you want to do with the pictures.
The caa-03040s has a relatively slow USB connection. Get a USB 2.0 card reader and connect it to a USB 2.0 port on the computer for much faster download speeds than the camera is capable of.
Apr 28, 2008 | Polaroid CAA-03040S Camcorder
Memory card unreadable?
It is the card. Exchange the card at the store.
Trevor Gordon
Senior Customer Tech
General Imaging Company
Dec 05, 2007 | GE A730 Digital Camera
Panasonic HDC-SD5 Flash Media Camcorder Logo
184 people viewed this question
Top Panasonic Video Cameras Experts
Kenneth Walker
Pieter Vleeshouwers
Pieter Vleeshouwers
Marvin
Marvin
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
