Question about Whirlpool 24 in. DU930PWP Built-in Dishwasher
Water stay in the dishwasher,don't exit
Tryed to clean the filter but don't work
  • lorrainebugd Dec 21, 2008
    My Dishlex 160 will not drain.
  • Robert Artiaco May 11, 2010
    have you installed a new garbage disposal recently?
DU930 is not draining water out
Posted on Sep 08, 2009
Doesn't drain out all the way water stays in
Hi
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. First make sure that the drain is not clogged and remove clogs if present. If no visible lint is present then remove the lower front access panel to check the drain filter and drain pump for any clogs, you'll need to clean the drain filter and drain pump completely. Also, check for any food pieces stuck near the pump impeller & clean the chopper assembly. Please note that dishwashers don't drain out the complete water such that heating element doesn't overheat. Hope this helps... Please post back for any further assistance.
Daniel
Aug 30, 2011 | Maytag Dishwasher
My dishwasher doesn't seem to be washing the
Hello
Water Inlet Valve
A dishwasher's water inlet valve is its most common part to fail. When your dishes are not being fully cleaned, quite often a faulty water inlet valve is to blame. Test your dishwasher's water inlet valve, and if it is no longer functioning as it should, you will have to replace it.
Upper or Lower Spray Arm
Your dishwasher has a lower spray arm. It may also have an upper spray arm at the top of the dishwasher. These spray arms are designed to shoot high pressure, high temperature water at your dishes. It is possible that the holes of the spray arms, where the water comes out, are blocked with debris, affecting wash quality. You should inspect your dishwasher's spray arms regularly. Clean out the spray arms as need be.
Heating Element
Water temperature is a key element in achieving clean dishes. A dishwasher's heating element is not designed to heat the water that enters it. Rather, the heating element is designed to maintain the heat of the water that enters the dishwasher. Its a good idea to run the hot water in your sink for a couple of minutes before you run the dishwasher. Just to make sure the water is nice and hot before it enters the dishwasher. If the water is unable to stay hot, it can adversely affect your dishwasher's cleaning ability.
Filter/Drain Grate
There is a filter in your dishwasher. Its function is to keep large particles of food and foreign objects away from the pump. Many of the newly-manufactured dishwashers have self-cleaning filters, and routine cleaning isn't a concern. However, some other dishw ashers need to have the filter removed and cleaned regularly. If the filter or grate is clogged or blocked with debris, it may interfere with the normal functioning of your dishwasher. Consult your owner's manual for specific directions for removing your dishwasher's filter and cleaning it.
Detergent or Detergent Cup
It could just be that you aren't using enough soap to completely wash your dishes. Your dishwasher may be designed to dispense soap at two different times during the wash cycle. If you don't fill all of the detergent cups, then the diswasher will lose a cleaning cycle. Also, if you use a gel-type detergent, try switching to a powered kind. Powders tend to dissolve better in hot water. And don't buy in bulk. Detergents are most effective in the first two weeks. After that, they decrease in potency.
Alternatively, your dishwasher's detergent cup could be defective in some way. It is possible that it is gunked up full of built up detergent, and a thorough cleaning may be enough to get it working again. If that doesn't do the trick, you probably need to replace the entire detergent cup assembly. If your cup isn't even opening, please see our section My dishwasher detergent cup won't open.
Aug 09, 2011 | Viking 24 in. Professional Series VUD040...
I have a Matsui MF2W dishwasher that will not drain. Theres always water in the bottom. The exit tube rises to the pipe at a height of 90cm which is < 100cm as ststed in the manual Could it be blocked?...
Hi
Daniel
Jul 21, 2011 | Dishwashers
Water is not completely draining, not even close. I've already checked the exit tubing and even found a pumpkin seed lodged near the pump hose. The float switch appears to be not working, I push it...
Hi... there might be a partial stoppage at the drain spigot under the sink check here. Then check in the sump of the dishwasher for any thing.... clean the filters. Otherwise the drain pump will have to be removed to ensure proper operation. good luck
Mar 01, 2011 | GE Dishwashers
Water is staying in the bottom
Water staying in bottom is not a problem unless the dishwasher base is full of it and covers the wash arm.
This means the drain cycle is not working or dishwasher is shutting off before drain cycle.
Try to clean the filters at the base and check drain in kitchen sink side is clear.
Need the model number in case you want more specific instructions.
Dec 06, 2010 | Maytag Dishwashers
Dishwasher will not clean very well
There are many probable causes of failure .
There is a filter in your dishwasher. Its function is to keep large particles of food and foreign objects away from the pump. Many of the newly-manufactured dishwashers have self-cleaning filters, and routine cleaning isn't a concern. However, some other dishwashers need to have the filter removed and cleaned regularly. If the filter or grate is clogged or blocked with debris, it may interfere with the normal functioning of your dishwasher
Nov 01, 2010 | Whirlpool DU960PW Dishwasher
Mbuchana@seidata.com It leaves calky residue on glasses. Is there a filter we need to clean in the water inlet?
Oct 01, 2010 | Dishwashers
Dishwasher does not clean dishes, soap does not fully go away
Water Inlet Valve
Heating Element
Filter/Drain Grate
  • filter
  • . Detergent or Detergent Cup
    Alternatively, your dishwasher's detergent cup could be defective in some way. It is possible that it is gunked up full of built up detergent, and a thorough cleaning may be enough to get it working again. If that doesn't do the trick, you probably need to replace the entire detergent cup assembly. If your cup isn't even opening, My dishwasher detergent cup won't open.
    Cycle Selector Switch
    Sometimes a dishwasher's cycle selector switch is the reason why dishes are not coming completely clean. Test your selector switch to determine whether or not it has become defective. If it has, replace it.
    Mar 29, 2009 | Dishwashers
    Water not draining out
    Plug off the mains. First drain out all your water by lowering the exit hose into a bucket or drain. You have to look for screws below the front kick-panel, the panel comes down & out. The pump is on the right side. Be prepared for dirty water. Inside the big flexible tube (coming from the tub bottom) is the filter, be prepared to find all sorts of junk here, clean out. Examine your pump also, clean out the impeller. Carefully refit all. Your machine would be fine. Don’t wait for the machine to jam to look into your filter.
    Mar 18, 2009 | Kenmore Washing Machines
    Won't drain
    Make sure the garbage disposal is clear so the water can exit. After that, you may have something caught in the drain hose or check valve. It would require removing the bottom kick plate to gain access to check.
    Jan 28, 2009 | Kenmore 24 in. 15689 Built-in Dishwasher
    Whirlpool 24 in. DU930PWP Built-in Dishwasher Logo
    186 people viewed this question
    Top Whirlpool Dishwashers Experts
    Mike
    Archie Ferrarini
    Archie Ferrarini
    Smitty
    Level 1 Expert
    Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
