Question about Lexmark Office Equipment & Supplies
Lexmark X5320 won't print acts like it's printing but paper is blamk, also tells me right ink is wrong( it is not)
    Problem Solver:
  • 14 Answers
Hello there,
The most common cause for printing blank pages is (1) Failure to remove the protective tape from the bottom of the cartridge. Even if you have removed the tape, there might be some residual tape left at the bottom of the cartridge. I would suggest you check out for this yellow or/and transparent blue tape at the bottom.Please remove it, if present. (2) If there is no tape left behind, then the next option is to clean the cartridge nozzles. I would suggest you go to Lexmark control program or Lexmark Solution Center and run the clean nozzle test. You should see solid dark lines on the print out. Repeat the process 2-3 times till you get a good output. (3) If all the above steps fails, don't worry.. we have one last thing to try... Remove the carts from the printer.. take a warm damp paper towel Set the ink cartridge right side up on the damp paper towel so that the ink nozzles are touching the towel, and hold the cartridge in this position for about 15 seconds. The nozzles are where the ink comes out of the cartridge. Repeat this process atleast two times and then put the carts back to the printer after 1 min (we need to allow the cart contacts to dry). Now you can install the cart to the printer and try printing. If you still have a problem with the cart, then I would suggest you try another cart as there should be something wrong with the cart that you have right now.
Merry Christmas!
Posted on Dec 21, 2008
Printer shows it is printing and it just pulls paper through and nothing has printed. I have changed ink and still won't work. I've cleaned print head. It will only print black and not colored on...
A firmware update for your model addresses a number of issues including print quality issues. Please visit the Lexmark website to download and install the Lexmark S300 Series Firmware Update.
Should the problem persists, please contact Lexmark Technical Support Center for additional assistance. Thanks.
Oct 17, 2011 | Lexmark S305 IMPACT LEXS All-In-One...
My printer is acting like it's printing nothing
Yes it is a ink problem so try and replace the ink.
Jul 02, 2010 | Lexmark X5470 All-In-One InkJet Printer
Printer acts like it is printing and sounds like it is printing but the paper is blank The test page does print
There are 2 probable cause, your ink is not fix properly or the machine is not closed in proper. The ink could not touch the paper beacause there is a small gap between the two that is why can not perform printing. Try to push a little bit harder to close the machine. Same problem happened to my printer once.
Feb 24, 2009 | Lexmark Color JetPrinter Z23 InkJet
Lexmark z23 will not print
go to the printer properties---there select printing preferences ---there select lexmaxr solution center-----in that option select printer cartridge replacement option----in that follow the replacement instructions.and select the it is new.and its proper appropriate number.then only it will print properly. selecting the cartridge is very much necessary.
Sep 12, 2008 | Lexmark Color JetPrinter Z23 InkJet
Lexmark x1180
This is what worked (so far) with my Dell1.gif AIO A940 printer1.gif that wouldn't print black ink.
It worked for awhile when I chose photo/glossy paper, but then it quit printing again (see below).
I got it to print, again, by putting SEVERAL papers in the feeder (instead of just 1) - there is a sensor that is supposed to automatically detect paper type, and it might not be working right, especially with one or only a couple of sheets.
Nov 13, 2007 | Lexmark JetPrinter X1185 All-In-One InkJet
Lexmark 710 printer
the ink cartridges may have dried up. try getting one color cartridge to test (color because it can also print black).
Sep 03, 2007 | Lexmark Color JetPrinter Z23 InkJet
No color printing with lexmark x4270
How may times did you use the printer to print befor this happened? If you used it a lot then you may need to buy more ink. My printer showed full ink and it turned out that they were empty.
Feb 26, 2007 | Lexmark X4270 All-In-One InkJet Printer
Lexmark Z11 Printer will not work
i am having the same problem and after looking it over, something is not feeding it thru the beginning of the paper starting in. if i pust 1 sheet down far enough to grab the paper it will print one page at a time. I have been unable to determine what is not feeding at the beginning yet.
Oct 03, 2006 | Lexmark JetPrinter Z11 InkJet Color...
320 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
