The monitor on my laptop has been broken for a while so i'm using an external monitor, now all of a sudden when the laptop gets to the loggin screen it switches to the native (broken) laptop monitor and the secondary monitor switches off and i have no way to see anything on screen inorder to fix it unless i boot in safe mode. is there anyway to fix this in safe mode so when i boot in normal mode the display treats the second monitor as its native one again? please help!
  • brevneal Apr 10, 2009
    my laptop monitor is broken and i need to connect it to a external
    monitor. But the only way i can get the external moitor to work is in the safe mode. How do i connect the second monitor in safe mode.
  • 111 Answers
Open the device mgr. and disable the internal and set the external as default windows should set it as default automatically when disabling the internal
Posted on Dec 21, 2008
Lenovo g550 laptop with an external monitor would only display of broken original screen after crash dump
Firstly you need to get your external monitor working. Have you tried pressing FN+F3 while turned on, (may take several presses).
If you can get the external monitor working then you'll need to run windows in safe mode and try removing any new drivers you installed. or try a 'Last Known good' on start up this depends on the OS version.
Nov 19, 2014 | Acer Computers & Internet
Acer aspire 4736Z suddenly went black
Ram chips may be bad. Test it using an external monitor. If the problem does not occur on external monitor then you lcd screen may be going bad
Dec 24, 2013 | Acer Computers & Internet
Have a Gateway Notebook KAV-60 with a broken screen. Trying to connect to an external monitor without any prompts or commands, as I can't see the screen. With an Acer Netbook I just plugged in the
Make sure the vga cable is in tight on the kav-60 and the external monitor.
Try the keystrokes to toggle the display. Normally you would Press and Hold the FN function key located at the lower left on the keyboard then hit the key F1 thru F12 that toggles the display. The correct F1 thru F12 key to hit will have LCD/CRT on it or it will have the icon of a display. The display toggles in three stages ( laptop only, external only or both laptop and external).
Apr 29, 2012 | Gateway Computers & Internet
How to use external monitor on a toshiba laptop with external monitor
It's probably best to buy a keyboard off auction sites or a new screen, the Function keys are not OS sensitive so a different keyboard will not work with them, they are device specific and require special drivers to operate.
Are keys broken or are they just missing? the membrane will still work to a firm press even if the key is missing.
keyboards can be found on auction sites
sorry I can't help more.
Apr 25, 2012 | Toshiba Computers & Internet
HOW TO REMOVE SCREEN FROM DELL VOSTRO 1000 AND CONNECT TO A MONITOR
if laptop is still running with a broken LCD screen , it id possible to use an external monitor, if laptop totally died or broken, not possible to use with external monitor.
Mar 26, 2012 | Dell Computers & Internet
Aspire 4930, Model no. JAL90 purchased on 31.3.2009.On 22.12.2010 suddenly display stopped working. What is the solution
Hello
The display of your laptop may go dark in one of two scenarios.
  • Physical damage that has resulted into a cracked or broken screen, if your laptop is dropped, especially with its case opened.
  • Malfunctioning of video power or control circuitry
If your laptop screen is physically damaged you should determined whether there is other damages to the laptop. You can plug an external monitor by using the video output connector to ascertain this. If your applications function of this external monitor you can simply go LCD screen repair and you can be sure that you will be able to recover your data. On the other hand, if there is no physical damage to your laptop screen and it goes blank you can connect to an external monitor and determine if other components of the laptop are functional. These steps will help you in your repair decision.
Good Luck
Jan 01, 2011 | Acer Aspire 4730-4947 Notebook
Connect broken laptop screen to external monitor
Suggestion- on my toshiba fn-f5 switches display modes, but to remove display connectors, you may have messed up your keyboard ribbon cable connection. it probably has a small sliding lock to hold it in place- if the lock isn't tight, your keyboard may not be recognized, which could mess up your display. Also, make sure your battery is charged and/or your power supply to your laptop is connected. hope this helps!
mothmanmeg@gmail.com
Sep 06, 2009 | HP Pavilion dv6000z Notebook
ACER cracked screen..external monitor???
Hi there.
The keyboard toggle you are using is the correct one.
Sometimes you have to hit Fn + F5 a couple of times to stay on there is no real set time. Make sure Fn + F6 is on so the laptop screen stays on.
Good luck and thanks for using FixYa!!
Apr 21, 2009 | Acer Aspire 5500 5570-2609 Laptop
Nec laptop screen not displayin
What have you tried so far?
Connect your laptop to an external monitor to see if it is the adapter or the screen that is broken. Toggle on to the external monitor. If the external monitor works, you'll know it is the laptop screen(or a component of it) that needs repair
Check your laptop latch to see if it is broken.
Dec 15, 2008 | NEC MultiSync FE991SB 19" CRT Monitor
Acer Aspire 3100
you need to toggle the screen on by use of a key on the keyboard... do you see one that resembles a monitor...
Robert
Sep 07, 2008 | Acer Aspire 5100 Notebook
Computers & Internet Logo
98 people viewed this question
Alun Cox
David Payne
David Payne
