Question about Efficient Networks SpeedStream 2108 (936-2108-001) Networking Switch
Connection problem cannot work w/ cable modem
  • Asmodeo May 11, 2010
    Only one PC? A group of PC's? In a group of PC's only one at the time (usually the first one connected) works well?
  • 40 Answers
Check for static ip or dhcp setup on cable modem if static you will have to enter in speadstream if dhcp dynamic ppoe enter isp
Posted on Mar 11, 2010
I have a modem arris cm450b, i bought splitter to use 2 cables but the the cable connected to my sons computr isn't working
That is not the right way to do it. Connect one computer to the cable modem using an USB A/B cable from the USB port on the modem to an available USB port on the computer and connect the second computer to the modem Ethernet port-to-Ethernet port using an Ethernet cable (probably the modem came with one Ethernet cable).
Hope this helps.
Oct 14, 2014 | Arris Touchstone 450a (CM450) Modem
Easytether.. connecting via cable modem after installing easytether
Surely it needs more info to may it be resolved. But seems that you have a problem with DHCP. Try rebooting your Linksys Wireless G router and the two laptops AFTER you connect the cable modem.
Sep 27, 2017 | Cell Phones
I plugged all my cables from my modem to the router and the internet is still not wanting to work on my laptop. Im still confused as to which plugs go where.
Please follow the physical connection setup to get your connection working,
1. Connect the modem cable to the router in the yellow color slot
2. Connect your computer to any one of the grey slot of the router
3. If your Internet Service Provider is cable provider (like Comcast, Cablevision) , then
unscrew the coaxial cable(TV cable) from the cable modem and unplug the power cable from the modem also unplug the power cable of the router then wait for 1min .
4. After a minute first screw in the coaxial cable and the power cable to the cable modem and wait till all the lights comes up on the modem , then turn on the Belkin router.
5. Then the light on the router will be Green , You will be able to access the internet .
Let me know it it works!
Thanks in Advance!
With Regards,
Prema.
Jan 10, 2011 | Belkin Connect N150 Wireless Router...
How to connect netgear fs108 to cable modem
leeb..... switches cannot be connected to the Cable modem.... because NAT will not be enabled in cable modem....so there wont be any DHCP server present in the cable modem....
Nat will be enabled only in DSL modem like AT&T verizon etc....So DHCP server will be present inside DSL modem...that is the reason why switches can be connected only to the DSL modem....
With NAT enabled modem, switch will work as a switch.... With NAT disabled modem, switch will work as a hub.... This is the difference....
Any doubts further ? please clarify with me.... I am ready to help you....
May 09, 2010 | NetGear FS108 8-Port Ethernet Switch
I just switched from cable modem to dsl modem..dsl modem gets on the internet when connected directly to computer..once connected to router doesnt connect to internet
Your new ISP is DSL. the router was working before with the cable modem. The settings for the cable and DSL ISP are different. Now your computer is working when you connect it directly to the DSL modem. that means the modem is working.
The DSL modem works on 2 different modes.
You will need to check which mode is your modem working on and according to the settings of your modem you will need to set up the router.
To change the settings of the router, you will need to open the set up page of the router.
Click Here for more information about the router set up.
Feb 20, 2010 | Linksys WRT160N Wireless Router
Vista desktop won't connect to internet cable modem eithernet
power down cable modem, router, and computer. Connect ethernet cable from modem to router/ and connect ethernet cable from router to PC. Power up cable modem first, after modem shows connectivity, plug in router. After router shows internet connectivity, start computer. Be sure that you LAN card operable
Apr 15, 2009 | Acer Computers & Internet
I'm trying to connect an xbox 360 to the ethernet using a cable modem. We're having trouble. Is this possible? We connected the modem to the cable hook-up and connected the ethernet cable from the modem to...
Make sure your modem or router is compatible with XBOX. I think Microsoft has a lost of working modems and routers. If this is all clear, connect the eth.cable to the modem/router. Power up the modem FIRST then the xbox. All this without any cd/dvd in the tray.
Usually as simple as that...
Jan 12, 2009 | Arris SBG1000 Wireless Cable Modem Gateway...
Ethernet vs. usb
FYI for those people trying to use a ethernet and usb cable from a cable modem - it may work for a while but it won't work forever - your ISP will only allow one IP address out of the modem unless you pay for additional addresses (then you need a switch). Each device you have on the modem is fighting for that IP and eventually it will just quit working (if it works at all).
If you want more than one computer on your network (on the Internet or sharing printers/files, etc) then you need a router or a gateway (cable modem/router combo which I DON'T recommend).
Feb 09, 2008 | RCA Thomson Digital Cable Modem (DCM305R)
Efficient Networks SpeedStream 2108 (936-2108-001) Networking Switch Logo
Top Efficient Networks Computers & Internet Experts
Vijay Damaraju
Vijay Damaraju
Level 1 Expert
Michael Galve
Michael Galve
Jax Planet
Jax Planet
Are you an Efficient Networks Computer and Internet Expert? Answer questions, earn points and help others
