Question about Breville 800 Class 800GR Indoor Grill
Breville 800 Grill power switch won't click on.
Link to table tilt control prevents disassembly to remove switch
  • Spacec4t Jan 12, 2013
    Check the little circlips at the base of each button's shaft. then the mechanism will come off the faceplate. Be extra careful in noticing where the temperature control shaft and the the table tilt controls attach -- at both ends. ;-)
    New Friend:
  • 3 Answers
I love this grill. It heats fast, it gets to 400F, it is large, it can open up flat. From what other people say, the switch might be a weak point. Mine got troublesome and then seized after almost 7 years of use. Everything else works like the first day so I am not really complaining and am keeping my fingers crossed I can keep this machine for many years to come.
The main riddle to opening this one is getting the 3 buttons off. It IS stubborn.
The part diagram I found here was helpful, although it doesn't show all the little screws that are behind the buttons: http://www.ereplacementparts.com/breville-800grxl-diecast-indoor-bbq-and-grill-parts-c-116052_116056_116067.html . This site is also useful if you need to buy a part online.
The buttons are glued on with a strong glue. It took a lot of effort to ''carefully'' pry them off.
Do put a thin steel plate (the edge of a paint scraper?) between the face of the machine and your screwdriver, otherwise you might be left with a few marks on the faceplate.
Do try to pry all around the buttons, otherwise they will not come off and you might break one. The marks on the edge of the buttons will be hidden by the faceplace once the machine is put back together, but not the ones on the faceplate.
It's normal that the shaft stays on the middle button, it's made to take apart this way.
Personally, I bought a new generic switch at a local professional electronic supplies store. Cost me 1.25$CAN. You need a 2 prongs, 20A 125VAC - 16A 250VAC switch, that can fit into the 1 1/16" x 1/2" hole.
Everything in that machine is attached very strongly, it sure looks like Breville doesn't want their wares to fall apart on their own.
It is a fairly complex machine for a simple grill. If you are not used to take apart appliances, do be on your gards for the location and positionning the little shafts and mechanisms you will fing behind the faceplate.
Do get the switch beforehand if you can and have it on hand to rebuild the machine right away if you are the type to have doubts about remembering where everything attaches correctly and which screw goes where, if some time passes between the gutting of the thing and putting it back together.
It would be a shame to have such a nice machine land in the dumpster for lack of a 1$ switch.
Posted on Jan 12, 2013
    Welcome Back:
    Visited the website for 2 consecutive days.
I was advised to pull off carefully the glued-on knobs to find screws underneath.
I had tried pulling the knobs before posting the question and found them very firmly connected.
I was as careful as I could be but the contact glue was too strong for the tensile strength of the shaft to the temperature control. Also it pulled the shaft off the bell-timer but that went back on OK.
Watch out for the connection to the power-on display led. The leads break off the led easily.
Posted on Dec 22, 2008
Hello all, does anybody know where I can get/download an instruction manual for an Anthony Worrall Thomson Breville Healthy Grill HG11, thanks in advance
hi there
follow this link and copy in the Breville healthy grill HG11,it says the manual is available now. i did'nt try to down load it, but it looks kosha!
www.productmanuals.org
Nov 13, 2017 | Breville Kitchen Appliances - Others
Tip
Mazda3 Sunroof Adjustments & Repairs
Folks -
The "gearbox" is unfortunately under the headliner with no easy access. If you are also experiencing a clicking sound when the motor is activated, the regulator track had slipped position and will need to be reset.
http://img696.imageshack.us/img696/2781/roofadj04.jpg
IMAGE WONT POST, SORRY
Removing the map light assembly (process below) may help in your initial diagnosis, you can feel the motor mounting screws and the motor assembly to determine if their loose.
http://img696.imageshack.us/img696/8415/roofadj03.jpg
I have been through this problem twice now. The first time the motor / gearbox came loose from it's mounts, began slipping (click, click,click), very nasty sound. I remounted the motor with threadlock on the NEW ALLEN HEAD screws, but alas.. two years later (mine's 2006) it slipped again.. I need to drop the headliner once more and have a look. If you would like a copy of your 05/06 FSM, drop me a line.
Here's the RESET procedure from the FSM, absolutely gospel, no other way to fix it:
Sunroof Motor Assembly Note:
Note
• If the guide is removed, initial position setting of the sunroof motor will be required. After installing the sunroof unit, perform initial position setting using the following procedure.
1. Press the TILT UP switch to fully tilt up the glass panel.
2. When the glass panel reaches the fully tilt up position, temporarily release the TILT UP switch and press it again for approx. 13 s continuously. Continue pressing the switch until the glass panel automatically stops at the fully tilt up position after reaching the mechanical lock position.
3. When the glass panel stops at the fully tilt up position, temporarily release the TILT UP switch, then press it again within 5 s and hold.
Note
• Press the TILT UP switch continuously until the glass panel opens to the fully open position, returns to the fully closed position and then stops.
4. Release the TILT UP switch when the glass panel stops at the fully closed position.
ALSO, Here's the clearance adjustment specs for having the glass panel in the correct resting position:
GLASS PANEL ADJUSTMENT
1. Fully close the glass panel.
2. Measure the gap and height difference between the glass panel and the body.
3. Loosen the glass panel installation screws and move the glass panel to adjust.
http://img696.imageshack.us/img696/3097/roofadj01.jpg
Standard clearance a: 0.2-2.2 mm {0.008-0.08 in} b: 0 mm {0 in}
4. Tighten the screws.
5. Insert any available thin plastic card between the weatherstrip and the body, and verify that they are sealed. (There is resistance when the plastic card is moved.)
http://img696.imageshack.us/img696/610/roofadj02.jpg
• If they are not sealed, perform Steps 3-4 and adjust again.
MAP LIGHT REMOVAL/INSTALLATION
1. Disconnect the negative battery cable.
2. Insert a tape-wrapped flathead screwdriver into the gap between the headliner and the map light.
3. Press the tab and remove the map light.
http://img94.imageshack.us/img94/2121/roofadj05.jpg
4. Disconnect the map light connector.
http://img696.imageshack.us/img696/3024/roofadj06.jpg
5. Remove the socket, then remove the map light bulb.
6. Install in the reverse order of removal.
SUNROOF UNIT DISASSEMBLY/ASSEMBLY
1. Disassemble in the order indicated in the table.
2. Assemble in the reverse order of disassembly.
http://img268.imageshack.us/img268/9769/roofadj07.jpg
1 Screw A
2 Drip rail
3 Sunshade stopper
4 Screw B
5 Sunshade
6 Deflector
7 Screw C
8 Sunroof motor
9 Rear drip
10 Guide
11 Decoration link
12 Front drip
13 Tape protector
14 Short cord
15 Frame
on Jan 01, 2010 | Mazda MAZDA3 Cars & Trucks
Manual for Breville BGR200XL Variable Temperature Panini Grill
Hello Kevin, I have a link to the manual online. It can be downloaded in pdf format or you may view online. Here is your link.
http://www.breville.ca/media/mediaappearance/4528/BGR200XL_IB_B13_FA_LowRes.pdf
May 15, 2015 | Breville BGR200XL Variable Temperature...
Burner Replacement , How to disassemble.
Unfortunately, Ducane is the only grill manufacturer who requires the removal of the front control panel, to replace the burner(s).
Here is a link to the Meridian Series grills. Click on the link that is your model and you can download and print the owners Manual. In it under Maintenance, it will describe and show you how to remove and replace the burner(s).
http://www.ducane.com/manuals/
Hope this gets you back up and grilling.
Apr 29, 2011 | Ducane Meridian 30557501 Propane Grill
How do I get my panini maker clean again
From the Owners Manual:
Before cleaning, switch the grill off at the on/off button, switch off at the power outlet and unplug. Allow your Professional Grill to cool before cleaning. The appliance is easier to clean when slightly warm. Always clean your Professional Grill after each use to prevent a build up of baked-on foods. Wipe cooking plates with a soft cloth to remove food residue. For baked on food residue squeeze some warm water mixed with detergent over the food residue then clean with a non abrasive plastic scouring pad.
May 24, 2010 | Breville 800 Class 800GR Indoor Grill
Have a Breville Ikon Panini Press ... doesn't work
First point of call would be to check the microtemp, which is the small heat regulating fuse inside. If that has blown, you most likely will have no power.
Otherwise call you local Breville Service Centre. If you're in Australia you'll find them at http://www.breville.com.au/care_agentsearch.asp
NOTE: In Australia, this model has a Two year product guarantee. Check your receipt as it may be under warranty!
May 19, 2010 | Breville 800 Class 800GR Indoor Grill
Bosch 4000 tablesaw won't start. Brushes replaced
I found that the remaining problem was a intermittent at the switch, which disassembly and cleaning resolved.
Tilting the motor / blade assembly down allows access from below, to the 3 screws fastening the controller circuit board cover on the brush end of the motor. From there, one can easily test exposed wires for power supply, see that brushes are contacting and clean accumulated sawdust.
Jan 06, 2010 | Bosch Electric Table Saws
Brevill Grill Removable plates - dishwasher safe?
Greetings jackneve,
The manufacturers specifications would indicate these plates are indeed dishwasher safe!
I hope this helps!
Dorothy
Go Ahead. Use Us.
Jun 25, 2008 | Breville TG400XL Indoor Grill
Breville 800 Class 800GR Indoor Grill Logo
386 people viewed this question
Top Breville Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Jerry Greenberg
Jerry Greenberg
bengsoon Neo
Are you a Breville Kitchen Appliances - Other Expert? Answer questions, earn points and help others
