Question about Husqvarna 23 Hp 48" Deck Yard Tractor
18hp kawasaki FH531V engine on ride on mower slows down and stuggles to get back to full speed happens when hot and worked hard never used to engine has done about 800 hours have fitted new spark plugs
  • nickpower
    nickpower May 11, 2010
    how does your air filter look?
  • 33 Answers
Check the air filter and the fuel filter
Posted on Jan 07, 2009
I'm having the exact same problem. Any help would be good.
Posted on Sep 12, 2012
How do i disconnect the throttle cable from the carburetor so that I can take out the carburetor and clean it.
the throttle cable DOES NOT attach to the carb on that engine. It attaches to the control panel underneath the carb. you have linkage rods that connect and they either have clips or you need to pull the carb mounting studs
Oct 18, 2014 | Husqvarna Garden
How do i fix a Kawasaki FH531V 18hp that is surging at idle
sounds like fuel went bad from siting carb will need thero cleaning
Jun 22, 2014 | Husqvarna Fe 501 Motorcycles
Very hard starting and won't run full throttle
try valve clearences check air cleaner and check pilot and main jet again in carby
Jun 19, 2013 | Husqvarna Garden
Carburetor problems husqvarna 18hp kawaski FH531V walk behind mower 52"
drop the bowl off the bottom and see if the float is stuck or the needle valve might be stuck as well
Apr 09, 2012 | Garden
Engine runs fine til hot.
I think one of the intake valves, or a valve pushrod, is bent or warped. When the engine heats up, the metal expands and the valve starts sticking open. That would cause compression to be lost in one cylinder, reducing available power so things drag when you engage the blades. This would also causes air/fuel to be blown back through the intake. I think you'll need to take it to a small engine mechanic. Good luck! Please rate my solution if helpful, thanks.
Jul 11, 2010 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
22 horse kawasaki riding lawn mower will not run at full throttle unless the choke is engaged
That is not a good situation. Too rich of a fuel adjustment can wash the bores out on that engine and prematurely wear it out! You will likely need to have the carburetor linkage and plate adjusted so that full throttle operates without engaging the choke. (If this is a single lever that you slide from slow, idle speed to fast, then on to choke)
May 09, 2010 | Husqvarna Garden
Kawasaki FH531V
Hello:
You can View this Engine in a Breakdown Form at the Following Site Addy. This will also show you the Part Numbers and you can Purchase Parts from the Site as well.
http://www.emerichsales.com/pages/parts/viewbybrand/default.aspx
Hope this Helps.
Good Luck
Respectfully
John
May 10, 2009 | Husqvarna 23 Hp 48" Deck Yard Tractor
Husqvarna 23 Hp 48" Deck Yard Tractor Logo
901 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
