Question about Lexmark X4270 All-In-One InkJet Printer
Error #12 Shows on my lexmark x4270 all in one how do i clear it
    Problem Solver:
  • 14 Answers
Hello there,
In my experience I've never come across an error #12 on a X4270. I've seen an error 1200 & error 1203 a couple of times. Did you get this error after installing a new cartridge? then there are chances that the new cartridge that you installed is defective. The best way to figure if out is to take both the cartridge out and power recycle the printer with the cartridge out. Check out if the operator panel says "cartridge missing" when it is powered back on. If it doesn't say "cartridge missing" then the printer hardware is defective. You would need to get it serviced. If the printer comes up with "cartridge missing" message, then either one of the two carts that you have is defective. I would suggest you to insert one cart first and close the cover and check if it says "cartridge missing" If it does come up with that message then insert the other cart too.. If you get Error 1203 on after inserting a cart, then that cart is defective and needs to be replaced.
Merry Christmas!
Posted on Dec 21, 2008
Ink cartridges will not move in place error # 1200
Lexmark X4270 Error 1200 Fix - Click here for document link
1. Unplug printer from wall and remove power supply.
2. Unplug any phone lines or USB cords connected.
3. Remove printer attachments, paper trays and phone.
Figure 1 - Printer paper holder and completed print tray
4. Lift the front cover of the printer and remove the white rubber bar by pulling the blue lever on right towards you.
Figure 2 - Top view of printer showing the white rubber feed bar with purple attachment
5. Remove the screws underneath the front cover (6 screws), back of printer (2 screws), and bottom of printer (1). View the images below to find where to remove the screws.
Figure 3 - Top view of printer showing which screws to remove.
5. Cont...
Figure 5 - Bottom view of printer. Image on left is cover to screw. Gently remove ribbon cable to reveal the gold screw beneath
6. Flip the front cover open and gently lift the top of the printer cover. Keep front cover open.
7. Remove the ink cartridges out of their carriage.
Figure 6 - Displays ink cartridge carriage with ink cartridges removed.
Caution: Electrical hazard. Keep hand and metal pieces clear of board or any other electrical wires or parts.
NOTICE: The ink cartridges are all the way to one end. If the X4270 is plugged in, the cartridge carrier is stuck and doesn't move. After further investigation a noticeable small black plastic lever is preventing the ink cartridges from moving. Photo below shows lever up and down (cartridges already moved in image below).
Figure 7 - Shows inside of X4270 and the lever that causes error #1200. Image on left displays lever up. Image on right displays lever down.
8. Push lever down clockwise so it is flush with plastic wall. Refer to image on right in Figure 6.
9. Lift the front cover open (if not already open) and plug in the X4270. Cartridges should move to center as if preparing for replacement.
10. Unplug the X4270 and remove power supply.
11. Remove bottom assembly carefully.
Figure 8 - Displays bottom assembly with lever and spring
Note: The cause of this problem is the spring slides out of place over time, probably because of ink shed on one end of its loop and loop attachment.
Figure 9 - Displays loop attachment
12. Place spring in loop attachment and use hot tip of heated tool to melt top of loop attachment to prevent further errors. Melt top of loop attachment similar of that to a mushroom top.
Figure 10 - Displays fix for jammed carriage.
13. Reattach the lever to the bottom assembly and slide back into place inside the X4270.
14. Plug in and check if operational.
15. Reassemble X4270 using steps 3-7.
Jan 31, 2011 | Lexmark X4270 All-In-One InkJet Printer
Error 1203
Hi there
ERROR 1203 LEXMARK ERROR 1200 Error 1203 is an issue that occurs either when a cartridge is bad or the printer cartridge Slot is bad...
1 - try cleaning the copper contacts of the both carts and cart slot in the printer and try again..
or
2 - when error shows up, shut the printers power off; wait one minute and turn it back on press copy.
Posted by LEH at 5:39 AM
Labels: Lexmark x
1 comments:
MarCrazy said...
Lexmark X4270 Error 1200 Fix - Use link below to see how to fix
Text version below use link above to see pdf with images.
Figure 2 – Top view of printer showing the white rubber feed bar with purple attachment
5. Cont…
NOTICE: The ink cartridges are all the way to one end. If the X4270 is plugged in, the cartridge carrier is stuck and doesn’t move. After further investigation a noticeable small black plastic lever is preventing the ink cartridges from moving. Photo below shows lever up and down (cartridges already moved in image below).
Apr 07, 2010 | Lexmark X4270 All-In-One InkJet Printer
I get a 1200 error when trying to fax
5. Remove the screws underneath the front cover (6 screws), back ofprinter (2 screws), and bottom of printer (1). View the images below tofind where to remove the screws.
5. Cont…
NOTICE: The ink cartridges are all the way to one end. If the X4270 isplugged in, the cartridge carrier is stuck and doesn’t move. Afterfurther investigation a noticeable small black plastic lever ispreventing the ink cartridges from moving. Photo below shows lever upand down (cartridges already moved in image below).
Figure 7 - Shows inside of X4270 and the lever that causes error #1200.Image on left displays lever up. Image on right displays lever down.
9. Lift the front cover open (if not already open) and plug in theX4270. Cartridges should move to center as if preparing for replacement.
Note: The cause of this problem is the spring slides out of place overtime, probably because of ink shed on one end of its loop and loopattachment.
12. Place spring in loop attachment and use hot tip of heated toolto melt top of loop attachment to prevent further errors. Melt top ofloop attachment similar of that to a mushroom top.
Feb 16, 2010 | Lexmark X4270 All-In-One InkJet Printer
Cartridge error 1203
or
Labels: Lexmark x
1 comments:
MarCrazy said...
5. Cont…
February 27, 2010 10:27 AM
Feb 06, 2010 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
Error 1203
or
Labels: Lexmark x
1 comments:
MarCrazy said...
5. Cont…
Feb 02, 2010 | Lexmark X4270 All-In-One InkJet Printer
Cartridge error No. 1203 - LexmarkX7170 All-In-One
or
Labels: Lexmark x
1 comments:
MarCrazy said...
5. Cont…
13. Reattach the lever to the bottom assembly and slide back into place inside the X7170
15. Reassemble X7170 using steps 3-7.
Jan 21, 2010 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
Displaying "Error 1200" on my lexmark x4270. How do I fix it?
This error is too complicated to explain using text, so will refer you to a Lexmark support document for your error and model:
Jan 14, 2010 | Lexmark X4270 All-in-One Multifunction...
Received an error code 1203 for my Lexmark x4270. What do I do to correct it?
Try this
or
Oct 23, 2009 | Lexmark X4270 All-In-One InkJet Printer
I cant install my lexmark x4270
Hit Start, Run and type Regedit
Find the following HKEY_CURRENT_USER\Software\Microsoft\Windows| CurrentVersion\ Explorer\User Shell Folders
In the right pane - see if these is any entries which has an F or any other alphabelts not C (your OS folder) modify data to C:\
Has worked for me on the same error message
Jan 05, 2009 | Lexmark X4270 All-In-One InkJet Printer
Lexmark X4270 All-In-One InkJet Printer Logo
140 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
