Question about Logitech Z-2300 Computer Speakers
I have plugged in my speakers and there is no sound i have gone into control panel and its not on mute
    Scholar:
  • 123 Answers
Plug some headphones into the same output that you had your speaker in. If they work it is your speakers. If not, then it is your computer.
*If it is your speakers, just the power is plugged in, the power button is on or replace.
*If it is NOT your speakers, then it is your computer driver. Uninstall and then restart. The computer will reinstall the driver automatically. Make sure you have the driver or have download it in case the computer doesn't install it for you.
Posted on Apr 29, 2009
I did some thing nd my speakers are not working
you might muted your sound or deleted the sound drivers
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it
if his does not fix the problem
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar for any further volume control settings you will need to right click on the volume icon system select adjust volume
click start control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speaker plug/outlets is usually at the back of the computer or if it
Sep 28, 2011 | Logitech X-530 5.1 Speakers
Cannot hear sound
they might be muted or have faulty connections/leads
also
Sep 28, 2011 | Compaq Audio Players & Recorders
My vaio laptops sound is gone .checked the speaker ikon but it is not muted. what do i do ?
if you are having problems with your sound
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
also
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps
Mar 29, 2011 | Dell Computers & Internet
My advueu monitor has built in speakers which are not working now. do not know what is wrong
First--have the speakers worked before? If so, be sure the speaker wire is plugged into the green hole on the back of the computer and also plugged into the monitor.
Is there a volume control on the monitor? If so, be sure it's turned up.
Are you speakers muted? Check in the sounds icon in the control panel (there could also be a little picture of a speaker in the system tray. Many times people mute the speakers and forget they did it.
Also in the sounds area of the control panel, be sure the volume is turned up.
Oct 06, 2010 | Computers & Internet
My toshiba satellite laptop sounds suddenly gone
you will have to get this fixed as the speaker has gone bust. As i had the same problem
Apr 07, 2010 | Toshiba Sattelite A105-S2051 Notebook
Dell computer seems to have lost it's external sound
This could happen for several reasons. Of course, the first is that the speakers might have gone bad, but that is not usually the case.
The next reason would be if you have muted the speakers in the "sounds" option in the control panel. Check that. While there, be sure you have the volume up and not way down.
Jan 05, 2010 | Dell Inspiron 1525 Laptop
Speakers are not making any sounds
ok let's try a simple test.unplug the the usb.i hope that your speaker has its own power supply.turn it on.try to touch the inputs of the speaker, you should hear humming sounds.if yes, then your speaker is ok.if the speaker is getting its power from the USB port, i suggest you should use its independent power.the USB does not have enough to supply your speakers. try also the output jacks for built-in audio of the pc, ok.
May 31, 2009 | Insignia 2.0 Speaker System (2-Piece)
Sound won't work without the earphones being plugged in
Make sure the speaker volume is turned up and also go into Control Panel, Sounds and make sure nothing is muted and all volumes are turned up. Also make sure the speakers are plugged into the sound jack in the back of the pc. The speakers also need power but since the light is on, it sounds like they are plugged in.
Apr 14, 2009 | E-Machines eMachines Desktop PC
Hello there, I have a Dell computer and trying to use HP speakers with it. Will this not work? I am not hearing a sound and my computer shows no device for speakers.
The HP speakers should work fine with your Dell.
Make sure that you have the speakers plugged into the correct port on the back of the Dell (This is typically a green colored port) Once the speakers ar plugged in to the correct port make sure that your sound is not muted.
Click on Start then on Settings or Control Panel.
Once you get to the Control Panel double click on the Sound Icon.
Verufy that the sound is not muted and you can also check the box to display your voulume settings on the task bar.
You may also want to check that your sound card in correctly installed.
Check these items and let me know if there was any change because there can be other items to check - These are just a few good jumping off points
Dec 28, 2008 | E-Machines eMachines Desktop PC
SPeaker and Headphone
If both speakers AND headphones aren't working and nothing is muted, it sounds (no pun intended) like your sound card has gone south. Have you checked in Device Manager to see if it's still listed? Right click My Computer>Properties>Hardware>Device Manager. Check under Sound, Video and Game Controllers to see if it's there. If so, right click and choose Update Drivers just in case it somehow got wiped out. That would be the easy fix and I hope it's not your card!
Thanks for using Fixya.com and please rate this tip accordingly.
Oct 18, 2008 | Harman Kardon HK695 Computer Speakers
Logitech Z-2300 Computer Speakers Logo
65 people viewed this question
Top Logitech Audio Players & Recorders Experts
Michial Gueffroy
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
