I have a HP Color Laserjet CP1518ni and whenever i print photos, it looks like there's a burn mark down the center of photos which ruins all photos. I have laser printing paper, I thought this was the problem, but it is still happening
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 24 Answers
Could be you have a broken fuser film (tube) Hot fusing element is contacting ptinted paper.
Tubes often get broken when removing paper jams.
Posted on Dec 21, 2008
How to reset the language on my HP color laserjet CP1518ni printer to english
1. Turn off the printer.
2. Press 'select' and turn on the printer. (select button should be pressed while turning it on)
3. press '-value+' to choose your language
4. press 'select' to save
5. press 'go' to return to ready mode.
Hope this Helps you its in your Manual or you can down load a new Manual from the internet.
Apr 30, 2018 | HP Office Equipment & Supplies
Does anyone have the schematic of the RM1-4815 which is the low-voltage supplier board. Actually I just want to know the value of the R106. It has burned in my board. Thanks a lot
Hello;
You would be better suited to order a new power supply board such as the one listed below on eBay, as HP does not provide any real support for things such as this and it is probably /maybe a lot cheaper anyhow doing it this way! I know it seems like a waste of money for 1 stinkin' cheap resistor (if that's all it is) but what if the other part it is attached to that caused the burn out is nearly bad also?
NEW HP Color LaserJet CP1215 CP1515n CP1518ni LV Power Supply RM1 4815...
Good Luck!
Rich Lilja
Aug 21, 2015 | HP LaserJet CP1215 Color Printer
My laser color HP cp1515n is not copy anything that's black copy? what can l do
Hi there, my name is Lisa and I'd be happy to help you with your LaserJet CP1515n. The following document will help you to troubleshoot the issue you have described:
HP Color LaserJet CP1215 CP1217 CP1514n CP1515n and CP1518ni Printers One...
I took a second look and found this one too:
HP Color LaserJet CP1514n CP1515n and CP1518ni Printers Resolving Print...
I hope this helps.
I work on behalf of HP.
Jun 19, 2015 | HP LaserJet CP1515n Printer
HP color laserjet CP 1510 printing stripes on the left
Is this for all colors or just one color? There are three color toner cartridges plus a black cartridge.
Mar 09, 2015 | HP CC378A Color LaserJet CP1518ni...
Hp lj cp1518 printer printing blank pages
you need new ink if not used it will dry up. if you are not sure go buy black ink
Jun 20, 2014 | HP Color Laserjet Cp1518ni - Printer -...
Color printed pages are too light.
  • Troubleshooting Setup and Install If your device is not recognized:
    • Verify that your cable is USB 2.0 high-speed compliant.
    • Ensure that your cable is connected correctly. Remove the USB cable, look at the end of the cable, and then match it to the pattern on the USB port. Make sure that it is not upside down. Insert one end of the USB cable completely into the USB port on the HP device and the other end into the back of the computer.
    • Check that the peripheral is turned on. Peripherals will not be recognized if the power is off.
    • Ensure that your USB cable is no more than 15 feet or 5 meters in length.
    • Check that the USB port is enabled. Some computers ship with disabled USB ports.
III. INSTALLATION INSTRUCTIONS When operating in a Windows environment, the CD-ROM setup or installation software detects the version of the operating system that you are running. The software is installed in the language that you have selected. For example, if you are running an English version of Windows and have the language preference set to Spanish, the installation utility will install the Spanish version of the printing software for the appropriate Windows version. INSTALLATION OPTIONS Two methods are available for installing printer drivers and software components for the printer.
  • Full (Recommended) . Installs everything that your device needs to work plus HP Solution Center:
    • HP Color LaserJet 2605 PCL 6 driver or HP Color LaserJet 2605dn_dtn PCL6 driver
    • HP Toolbox FX . Allows you to change some printer settings and contains documentation and self-help tools.
    • Screen Fonts . Printer-matching TrueType fonts help ensure WYSIWYG printing.
    • HP Color LaserJet 2605 series printer documentation. A list of documentation, which includes information about product operation, troubleshooting, warranty and specifications, supplies, and support.
    • HP Solution Center . Use HP Solution Center to gain access to product-specific software and on-screen help. By using HP Solution Center, you can access the HP Shopping Web site and update your HP software. If you have the HP Color LaserJet 2605dtn, you can also transfer images from a photo memory card. To start HP Solution Center, click Start, Programs, choose the HP program group, and then click HP Solution Center.
    • HP Photosmart Transfer . Software for transferring images from photo memory cards to your computer (HP Color LaserJet 2605dtn only).
    • HP Product Assistant . This software detects problems that occur with your HP products and can offer solutions to help you resolve those problems.
    • HP Software Tour . Use this for an overview of the software features.
    • HP Software Update . Use this software to check for software updates for your HP products.
  • Minimum . Installs everything that your device needs to work. The following is a list of available components:
    • HP Color LaserJet 2605 PCL 6 driver or HP Color LaserJet 2605dn_dtn PCL 6 driver.
INSTALLING SOFTWARE ON WINDOWS 2000 and XP Printing system installation from CD-ROM, Internet download
  1. Close all programs.
  2. Insert the CD-ROM.
  3. If the HP printing system installer program has not started after 30 seconds, complete steps 4 through 7.
  4. From the Start menu on the taskbar, select Run.
  5. Browse to the root directory for the CD-ROM drive.
  6. Select the SETUP.EXE file, click Open, and then click OK.
  7. Click Install.
  8. Follow the onscreen instructions.
USB Installation for Windows 98 Second Edition, Windows Me and Windows Server 2003 (Plug and Play Install)
  1. Turn on the printer and computer.
  2. Verify that the printer displays “Ready.�?
  3. Attach the USB cable to the printer and computer.
  4. When the Add New Hardware Wizard appears, click Next to install the USB Printing Support.
  5. In the following dialog, select option Search for the best driver for your device, and click Next.
  6. Make sure the HP Color LaserJet 2605 series CD-ROM is in the CD_ROM drive, select Specify a location, browse to your CD_ROM drive, and select the Drivers folder, then either Win98_Me( for Windows 98 and Windows Me) or Win2000_XP (for Windows Server 2003). For example, CD ROM drive:\Drivers\Operating System\Language. Choose OK, and then click Next.
  7. For Windows 98 SE, in the USB Printing Support dialog, you should see the path and file name. Click Next. For Windows Me and 2003 Server, this step may not apply.
  8. Once the files are copied, click Finish.
  9. Steps 4-9 will repeat to install the printer driver. File names will change. At step 9, you have the option to rename the printer. Click Finish. After files have installed, click Finish to close the dialog.
Network Installation for Windows 98 Second Edition, Windows Me, and Windows Server 2003
  1. Download HP's Install Network Printer Wizard.
  2. Run Install Network Printer Wizard and follow the on-screen instructions.
INSTALLING SOFTWARE ON MACINTOSH OS 10.2.X, 10.3X, and 10.4.X USB installation instructions
  1. Insert the CD-ROM.
  2. Run the installation utility.
  3. After the software installation is complete, attach the USB cable to the printer and the computer and then restart the computer.
  4. After the computer has restarted, open the Print Center or Printer Setup Utility to see if the printer name appears in the Printer List.
  5. If the printer name displays in the Printer List, the setup is complete. If the printer name does not display in the Printer List, go to the next step.
  6. Click the Add button, and then select USB from the drop-down list. 7. Select HP Color LaserJet 2605 and then click Add. The printer name displays in the Printer List. Setup is complete.
Jan 27, 2010 | HP LaserJet 2605DTN Color Printer
Printer always says "Remove and check color cartridge"
It must be your ruined catridge. Some times the wire connections are burned at the side of the catridge and you must thaw away it and buy a new color catridge.
Oct 28, 2009 | HP PSC 750 All-In-One InkJet Printer
Hp color laserjet 2600n ''black print down form its orignal place''
an allignment need to perform on printer with proper placement.
Nov 27, 2008 | HP Color LaserJet 2600n Printer
227 people viewed this question
k24674
Marvin
Marvin
