Question about D-Link AirPremier DWL-8200AP 802.11a, 802.11g/b (DWL8200AP) Wireless Access Point
How do i setup bridge mode w/ my D-Link DWL-8200AP
We are going to transfer to another building about 175 meters away from the old one that we live before, and the connection is there in the old building, i want to do a bridge mode from the old building to the new one using my D-Link DWL-8200AP. can you help me by telling me how to set it up? and what do i need. tnx in advance.
tech curly
  • 298 Answers
SOURCE: DHCP option is disabled when LAN IP is Dynamic on DWL-G700AP
that is right the access point does not have a dhcp server. that will give an ip address to all of your computers or device connected to it wireless. If you have a modem with a dhcp server there will be no problem with the IP but if the modem does not you must have a router and now an access point.
Posted on Aug 07, 2008
  • 10 Answers
SOURCE: can't connect to configure password through web address 192.168.0.50
When you reset the AP, how long did you press the reset button? To reset the AP to factory defaults, the reset button should be pressed and held for at least 15 seconds. Also, once reset, the AP should have the following settings:
IP address: 192.168.0.50
Subnet Mask: 255.255.255.0
Default admin username: admin
Default admin password: <blank>
When connecting your PC, either set an IP address within the same subnet (192.168.0.51 255.255.255.0) or choose "Obtain address automatically".
I hope this helps.
Dave Grannas
Posted on Jan 25, 2009
kamal1984
  • 1383 Answers
SOURCE: AP does not work in Repeating Mode?
check your wi fi is enabled on ap settigns also che k broad cast ssid is enabled on it.
Posted on Apr 27, 2009
ginko
  • 19396 Answers
SOURCE: d-link DWL-900AP+ Wireless access point CAN'T SET PASSWORD help!!
192.168.0.50 is the default address for your router, if router was boxed and new, this should be the router IP.
The router configuration must be done using a cable connection, cannot be done using wireless.
If you want to reset the router you can hold pressed the pinhole reset switch until the unit will restart, about ten seconds, this will reset IP to 192.168.0.50 . If router is irresponsive after reset and ethernet cable is tested and fine , then the router may be faulty.
You can call the phone number listed on the router manual to get online assistance.
If the router was not new, but had been re-programmed , the default IP may have been changed manually by the user, in this case do the following to find out the IP.
Click start button
Locate and use Run command
In the Run box type CMD, this will open command prompt.
in command prompt type: ipconfig /all
THe router Ip will be listed as 'Default Gateway'...192.168.......
You can also find IP by rightclicking on network connection, in Windows and choosing Status. ClThen clicking Support tab, and finding the default gateway IP address.
Posted on May 07, 2009
  • 3 Answers
SOURCE: connect D-Link DWL-G700AP to dreambox decoder
you can connect to your box via FTP via a crossover cable. If you can’t, you might want to read up on that before attempting this.
Now, what we’ll need is…
Ethernet cable (crossover or patch)
Router
Modem
We’ll also assume that you have a router (wireless or not) and that your modem is connected to the ‘Internet’ or ‘WAN’ port.
If you have a free port on your wireless router, you can connect your dreambox to this. Use the ethernet cable (crossover or patch, most modern routers will accept either) connect one end to your dreambox and one end to a free port on your router. You don’t need to change any settings on your router or PC.
Over to the dreambox. Navigate to the networking page on your dreambox.
Setup -> Expert Setup -> Communication Setup
Posted on Dec 09, 2009
I cant access my Router's configuration...
Just see on the back side of the router. There would be a button of "Reset". Press it. Now try to access . It would work.
Jul 22, 2013 | D-Link AirPremier DWL-8200AP 802.11a,...
Hi, My d-link dl-604 suddenly stopped working. When I plug it in, only the power led and #4 lights are up. None of the other leds are responding nor the internet is not working as well. Please help. Thanks
The following reset procedure will completely restore the default settings on your D-Linkmag-glass_10x10.gif device including your password. This procedure applies to the DI-514, DI-524, DI-604, DI-614+, DI-624, DI-754, DI-764, DI-774, DI-784, DI-804V, DWL-700AP, DWL-800AP+, DWL-900AP+, DWL-1000AP+, DWL-2000AP, DWL-2100AP, DWL-6000AP, DWL-7000AP, and DWL-7100AP.
Step 1 Locate the reset pinhole on the back of the unit.
Step 2 With the unit powered on, press and hold the Reset button.
Step 3 Hold the Reset button for about 10 seconds.
Step 4 Release the Reset button.
Step 5 The unit will reboot. Allow 20-30 seconds before reconnecting.
Step 6 The device is now at factory defaults.
Note: Do not recycle power during the reset procedure.
The default user name for most D-Link devices is admin and the password is left blank.
Hope this helps! Give me thumbs please!
Aug 23, 2010 | D-Link DI-604 4-Port Cable/DSL Router...
Ibought a ner desktop w/windows7 & it can't read the DWL-122. I hooked the old computer & down loaded the updates but can't get it to update. what next?
According to the D-link website, the DWL-122 (with wireless B) was discontinued in 2007. The only operating systems it is supported on are XP and earlier.
http://www.dlink.com/products/?pid=175
Click on "Specifications" when you go to the link and you'll see.
The good news is they're relatively cheap to get these days. I'm sure you can find one that works with Win7 at Best Buy or a computer store near you.
Sorry! Hope this was helpful at least!
Mar 13, 2010 | D-Link DWL-122 Wireless 2.4GHz (802.11b)...
D-Link 2000AP+ and 2100AP Bridge configuration
Solution #1
Set the DWL2000AP+ as "Bridge Mode" and the new AP (DWL2100) in "WDS Mode".
On each device set the MAC address of the other device.
Solution #2
Set the DWL2100 as "WDS with AP Mode" and the DWL2000 in "Bridge Mode".
Aug 31, 2009 | D-Link : DWL-2100AP Wireless-G 108Mbps...
DLINK DWL-2100AP
check whether DHCP is enable on ur main AP.
Apr 21, 2009 | Computers & Internet
Can't connect to configure password through web address 192.168.0.50
I hope this helps.
Dave Grannas
Jan 25, 2009 | D-Link AirPremier DWL-8200AP 802.11a,...
D-Link DWL-G122 Wireless USB Adaptor
This happens all the time first make sure you download the right drivers for your model for ex: d-link is have D-Link DWL-G122 vs1 or D-Link DWL-G122 vs2 make sure you download tthe right one. If you have Vista make sure you download (VistaBETA) if not download (WinXP, WinME, Win2K) also this product does not work on Mac os! links to look at http://www.dlink.com/products/support.asp?pid=334
Sep 02, 2007 | D-Link AirPlus G DWL-G122 802.11g/b...
D-Link AirPremier DWL-8200AP 802.11a, 802.11g/b (DWL8200AP) Wireless Access Point Logo
199 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
