Question about Siemens SL65
No volume! no ringer!
No matter what I try to do (re-start, adjust settings and profiles)the volume on my phone has gone completely silent. Even has the 'no-volume' icon. People can hear me fine but I can't hear them.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 128 Answers
Check the + volume switch if pressed,if not then is broken and you have to change it
Posted on Apr 05, 2007
  • 78 Answers
SOURCE: Forgot my username cant log into laptop, help
Posted on Sep 22, 2014
Jitterbug flip won't ring. I've checked the volume and it's set at maximum What is the Jingle, I've tried both ways, no help. Exasperated, donna
Page 30 of manual at the link shown suggests a way to silence the Jitterbug.
http://www.specsserver.com/CACHE/FREOWQFWSXOG.PDF
Quoting from Page 30:
To adjust the ringer volume:
1.
Be sure the phone is open and on.
2.
Press the
Up/Down
volume button
on the outside of the phone below the
display window. Press each time you want
to advance to the next choice.
These choices will appear on the screen:
- Ringer Volume Ring Max
- Ringer Volume High
- Ringer Volume Med
- Ringer Volume Low
- Ringer Volume Silent
3.
When you're satisfied with the setting,
release the volume button.
Your Jitterbug may ring and vibrate
to alert you to incoming calls. The
ringer and keypad can be silenced
by pressing the volume button
Down
until
"Silent"
appears on the screen. Your
Jitterbug will now only vibrate to alert you
to incoming calls (This can come in handy
at a movie, a library, or any other location
where a ringer may be a distraction.
May 09, 2018 | Cell Phones
Blu Advance 5.0 ringer sounds won't work.
Hi if u have silent mode turned on u won't hear a sample ring tone check where u adjust volumes there should b a silent mode on or off..Cheers..
Dec 20, 2016 | Blu Cell Phones
How to take off silent mode? I never programmed it to do this...
See if this helps
Adjusting the Ringer, Earpiece and Speaker Volume
Adjusting the Ringer Volume
You can choose from four ringer volume settings (off, low, medium, and high)
separately on each handset or the base.
With the phone in standby, press or on the handset or VOLUME or
VOLUME on the base. The handset or base sounds the ringer at that level.
Use on the handset or VOLUME on the base to make the ringer volume
louder. Use on the handset or VOLUME on the base to make it softer or
turn it completely off.
When you hear the ringer volume level you want to use, stop pressing keys.
The handset or base will use the new ringer volume starting with the next incoming call.
Note: If you set the ringer volume to Off, the handset or base won't ring. Other handsets or base will ring according
to their individual settings.
Oct 17, 2014 | Uniden DECT 6.0 Cordless Telephone...
IPad won't ring when calling face time
either your profile is silent or your volume is down. whenever your profile is in silent mode/vibrate mode even if someone is calling you it wont ring. change that to ringer via settings and sounds.
Aug 27, 2013 | Cell Phones
The volume on one of my Gigaset 8825 mobile handsets is very low. I have adjusted the handset volume to the max setting but still can barely hear the ringer. Is there another way to adjust the handset...
Hi, you can try to change the profile settings of the phone, because sometimes even if the volume is full but if the profile settings is on low, the sound will still be low.
Thank you for using Fixya.
Jul 15, 2011 | Computers & Internet
Ringer is set at max but is hard to hear
If the ringout volume is very low, then try not to select a soft, silent or low ringing tone. Try to choose a ringing tone that is loud so that you can hear your phone ringout.
Hope that was helpful?
Mar 18, 2011 | One Touch Jitterbug One-Touch Cellular...
The ringer will not ring, everything else is perfecty fine and working well
Your phone is set too silent. If it has buttons on the side, try pressing the up arrow button until it's loud enough for you. Alternately, go into the phone's settings and look for a "Ringer Settings", "Sounds", or "Profiles" category. You should be able to adjust the volume from there.
Feb 28, 2011 | Cell Phones
I have the new nokie 6700 slide and the sound just stopped working, it hasnt been wet or anything it just stopped working i cant even hear it ring. please help
Make sure that the incoming call alert (under profile settings) is "NOT OFF"...
Make sure the profile is not in silent mode...
If everything is ok, then probably it may be the ringer might have gone bad... You can take it back to any Nokia care and ask them to check the status of ringer...
Feb 25, 2011 | Nokia 6700 Classic Cell Phone
Got a new Blackberry Storm and my ringer won't ring
Check either your profile or under "Options" -> "Sounds and Ringer Tones" and see if your volume is set to "Silent". Change volume to something other than "Silent" and see if your ringer works then.
Oct 23, 2009 | RIM BlackBerry Storm 9530 Smartphone
I have a new LG200C cell phone that has been activated with TRACFONE. Problem: when dialing the LG200C from another phone, the the ringer is completely silent, even though I have put all volume settings on...
try pressing the * key for about 2 seconds (until it vibrates or beeps) that toggles between the normal ring settings and "manner mode" which is vibrate
then check menu - settings - sounds - volume
select Master volume and make sure it is not on silent
Sep 28, 2008 | LG Cell Phones
Cell Phones Logo
302 people viewed this question
Top Siemens Cell Phones Experts
Stormi  Paulk
Stormi Paulk
Sameer Raut
Sameer Raut
Colin Stickland
Colin Stickland
Are you a Siemens Cell Phone Expert? Answer questions, earn points and help others
