Question about Echo Garden
Unable to get head of whipper snipper
I have an Echo straight shaft whipper snipper. I do not have a manual. I want to remove the original head system and place a differnt head on to the unit. How do I undo the head??
Thanks Greg
After much mucking around I noticed a hole in the top shroud of the shaft. I placed a narrow screw driver through the hole until it made contact with the rotating part of the head and pushed until the head would not turn. I thern applied pressure clockwise until the head became loose. I did the reverse to tighten. The head of the unit will rotate anti clockwise to tighten as the shaft rotates clockwise during operation. I hope this explains the method.
Thank you any way for your interest.
Greg
Posted on Dec 22, 2008
My whipper snipper got so hot on the shaft that it melted the new plastic cord holder so I was told the drive shaft cable needed greasing can you tell me how to do this and with what grease
quite likely the head you put on is too heavy for your unit . not sure where you are but any auto parts store should sell grease that will work OK look for one that is a HI temp lube tho .
Aug 09, 2015 | whipper snipper Garden
Where can I buy replacement line spools for this whipper snipper??
I think that might be a K-Mart line of products
Mar 31, 2015 | Garden
I have a stihl 2 stroke petrol whipper snipper. It seems to have over heated at the reel end. I have smoke and grease spewing out at that end (metal neck at the reel end) have I fried it?
Sounds like you have a straight shaft trimmer version that have got bad bearing(s) that needs replacing. It probably will take the whole gearbox as a replacement item.
Jan 20, 2015 | whipper snipper stihl fs 38
Still fs 38 head stopped spinning why?
gear head or drive shaft may have come separated, at cutting end or engine end.
Jul 05, 2014 | whipper snipper stihl fs 38
Whipper snipper manual
50:1 with good quality 2/s oil
Jan 18, 2014 | Echo Garden
Whipper snipper revs but head doesn't turn
Englebert the most common thing would be that the inner shaft has sheared off. Remove the head and see if it spins then.
Dec 29, 2013 | Garden
Whipper Snipper
check to see that you have a left hand nut on the head as it requires it to tighten up as the shaft spins. Check to see if the shaft spindle turns the right way for your new head
Jul 04, 2013 | Cars & Trucks
SRM 2000a echo whipper snipper Not starting tried new spark plug and fuel.
Small engines have three systems. 1-ignition 2-compression 3-fuel
if you have spark at the plug and fuel gets to the engine the issue is in the engine compression system. I recommend pulling off the muffler and looking for scratches or scoring.
If you need to replace parts find a dealer like www.arcolawn.com to assist.
Feb 11, 2011 | Echo Garden
How do i replace a shaft for ryobi whipper snipper
I never heard it called a whipper snipper before but I am on this side of the ocean. you should be able to go to www.ryobiuk.com. Put in your model number and you should find a parts list for it.
HTH
Good Day. mate
Oct 22, 2009 | Ryobi Garden
Garden Logo
1,091 people viewed this question
Top Echo Garden Experts
Jim Parker
Jim Parker
colesmowers
Phil Walker
Phil Walker
Are you an Echo Garden Expert? Answer questions, earn points and help others
