Gateway notebook says "operating system not found" error codes pxe-e61: media test failure, check cable and pxe-m0f: exiting pxe.
    Genius:
  • 1,066 Answers
Your ide controller has gone bad. you need a new motherboard
Posted on Feb 01, 2009
PXE-E61 : media test failure, check For Realtek RTL8101E/8102E PCI-E Ethernet Controller v1.06 (080222) PXE-E61: Media test failure, check cable PXE-M0F: Exiting PXE ROM.
The system is not finding any bootable media (Hard Drive) and is attempting to boot via the network card (PXE Boot) the error message is saying that there is not PXE network to boot from and it is exiting the process.
Generally, this is caused by a hard Drive failure. Reseat the drive and or drive connections and see if the system will find the hard drive.
Generally, a Hard drive failure
Jun 17, 2011 | Computers & Internet
PXE-E61: Media test failure, check cable PXE-M0F: Exiting Broadcom PXE ROM Operating System not found Acer Travelmate 5720G
This error is a result of your computer not finding the operating system. This is usually the case when the hard drive has failed. You will need to take the computer to a technician to replace the hard drive and have windows reinstalled.
Mar 06, 2011 | Computers & Internet
Upon start up my Dell Mini keeps showing a code stating " intel UNDI. PXE.2.1 ( BUILD082) For Realtek RTL8101E/8102E PCI Ethernet controller v1.08(080408) PXE-E61: Media test faliure. check...
You computer is trying to boot from the LAN port (Ethernet).
Go into the BIOS by pressing either the F2 or the Del key. Check and make sure the hard drive is recognised by the system as with it saying "Operating system not found" does not sound good and could mean a hardware failure.
If it is seen by the BIOS check the boot order, change it to the HDD as the first boot device.
Regards.
Dec 15, 2010 | Dell Inspiron Mini 10 Notebook
Pxe e61 check cable message
"Intel UNDI, PXE-2.1 (build 082)
Copyright (C) 1997-2000 Intel Corporation
For Realtek RTL8101E/8102E PCI-E Ethernet Controller v.105 (071227)
No bootable device -- insert boot disk and press any key"
sounds like a driver issue try to go to toshiba's website and download the latest drivers for the NIC card.
Nov 02, 2010 | Toshiba Qosmio G15 Notebook
Wile I am trying to boot it up it goes in to a loop
Hello.
That error message usually refers to a hard disk failure. Your hard disk cable could be loose or faulty. Or, your hard drive would need to be replaced.
I'd suggest to check the cable and run your system's hardware diagnostics (often F2 or F12) when your system boots.
Hope this helps.
Nov 26, 2009 | Compaq Presario M2000 Notebook
I keep getting codes pxe-e61 media test failure,
Something went wrong with your last installation. try reinstalling windows. But, before that go to BIOS and check the BOOTING devices
Nov 18, 2009 | IBM ThinkPad T42 Notebook
Media test failure,check cable, exiting bordcom pxe rom os not found
check connections of hard drive. 2nd check boot order in Bios, remove Lan or network boot from top order. 3rd choice if not solved reset bios by removing cmos battery and putting back in to clear it.
Char S.
May 24, 2009 | Computers & Internet
PXE-E61: Media test failure, check cable Pxe-M0f: Exiting Broadco
PXE-E61: Media test failure, check cable (of the HARD DISK pls)
pls first check the hard disk seated in the bottom left side of ur notebook u have to take out the 7 or 8 screws first and then take take it out by pulling the connector gently and try to re seat or re fit the hard disk so connector can seat firmly in hard disk and then power up ur notebook if Error persists
then sorry to tell u my friend that ur Hard disk has CRASHED and not giving up files for OS loading kindly replace ur HARD DRIVE and restore ur OS thru backup disk u got
Pls take care of ur notebook from bumps and falls and hard impacts during operation and carrying bcoz the disk inside the HDD is very sensitive and gets damaged easily by impacts
pls rate me FIXYA for my diagnosis
Mar 09, 2009 | Acer Aspire 4720 Notebook
Trying to start my computer
you have a failed hard drive and will require a replacement.
Oct 15, 2007 | Toshiba Satellite P25-S5263 Notebook
Computers & Internet Logo
174 people viewed this question
David Payne
David Payne
