Question about GE 13GP243 TV
Its actually a 13GP244
I know there is a short somewhere in the board because the fuse blows as soon as i plug it in, any idea's on where to look first?
  • 68 Answers
You need to check the power supply area. usually when a fuse blows, that means the bridge rectifier is blown or the ic in the power supply area is blow too or both are blown.check there..good luck
Posted on May 09, 2007
How do I find the fuse panel on LG model LSC269055b refrigerator
I think your model number is actually LSC26905SB
There isn't a fuse panel, per se. If I remember your model correctly, the main board is on the back, so pull your refrigerator out, unplug it, and take off the access cover located about halfway up your refrigerator's back. Look at the fuses on the main board. There is a 20 amp fuse that blows easily (the newer boards have a slower blowing fuse in them, now). Temporarily jumper the 20 amp fuse and then plug your refrigerator back in. If you hear relays clicking and such, that's good. The compressor should start up shortly afterwards and all the lights should be on in your refrigerator.
After you have verified operation, go to Radio Shack, or somewhere similar and get yourself a 20 amp slo-blo (slow blowing) fuse and solder it on top of the old fuse on your main board.
Remember to always unplug your refrigerator when dealing with the main board and power circuits.
Good luck and let me know if you need any more help.
Nov 17, 2014 | LG Refrigerators
Why does fuse keep blowing on vizio hdtv32inch as soon as I plugin
There is a short somewhere in the tv. The blowing fuse is trying to keep you from getting electrocuted. Take the tv back to where you got it from. Bad power board.
Jun 27, 2014 | Cars & Trucks
6 amp power board fuse blow when power button pressed.
That is usually caused by shorted output transistors. What brand/model do you have?
Apr 29, 2013 | Audio Players & Recorders
RCA HD52W58 has a short somewhere in the deflection board
TL010 which is the HOT its attached to the heat sink directly in front of the flyback. Unsolder that and see if the fuse stops blowing.
Oct 21, 2012 | RCA HD52W56 52" Rear Projection HDTV
Have a short in the Horn/dome light fuse on a 1990 chevy suburban, keeps blowing fuse even when truck isn't on. using a 20 amp fuse and with truck completely off as soon as the fuse is put in it blows...
You will have to trace the wiring. There is a short somewhere before it reaches the actual horn or light. Horns pull an extreme amount of amperage. The relay may be stuck or the wiring to the switch may be bad. My bet would be a shorted switch or relay.
Dec 11, 2017 | 1990 Chevrolet Suburban
1997 Dodge Ram 2500 Diesel 4x4 keeps blowing a 40 amp fuse for the ign/acc when this happens I lose all my gauges and the wipers/turn signals/ radio/ both cig. acc. plugs and the starter. I also lose the...
I would start at the starter, it could have a short but it's only apparent when the engine gets it hot. you can try to pull the fuses to other things and see if the problems stop. this will at least give you an idea of where to look. also check fusible links and look for wire corrossion
Jun 16, 2010 | 1997 Dodge Ram 2500 Club Cab
Blowning fuses
i would check the wires going to your headlights there is a wire shorting out somewhere
Jun 13, 2009 | Craftsman 24 Hp 48" Deck Yard Tractor
Blows fuse internally when tv powered up
There is a short in it somewhere. check the ground.
May 24, 2009 | Olevia 237T 37 in. LCD TV
Brake Light Fuse
You have a short in the lighting system. Try removing both brake bulbs and with a new fuse installed.. does it still blow the fuse? If not, then install one bulb at a time and repeat the test.. You probably have a short in or around the bulb socket.. Hope this helps
Sep 18, 2008 | 1997 Honda Civic
GE 13GP243 TV Logo
100 people viewed this question
Top GE Televison & Video Experts
matt martin
matt martin
Are you a GE Televison and Video Expert? Answer questions, earn points and help others
