Question about RCA F36650 36" TV
Dead, cycles 3 times
When power is pushed, the green light flashes 3 times with 2s between flashes indicating system control and buttons are working but then cuts off. all voltages seem good out of the power supply with roughly 130V towards the HOT, the HOT is good as well. I suspect the hv transformer, is there anything else i could possibly check for???
  • 3 more comments
  • R E Dec 21, 2008
    what does it mean to ring the transformer? thanks
  • kpickett22 Dec 27, 2008
    I have a RCA F36650 . The TV Power indicator blinks 3 times and nothing happens... Please help !!
  • Anonymous Jan 28, 2009
    I have the same issue RCA 36 in Entertainment series
    power doesn't seem to turn on at all, the green light in the power button comes on, for about 3 seconds and then goes off, this cycles 3 times then stops.
    do I need a repairman? I have no tools and wouldn't know how to fix any components.
    thanks
    ken
  • R E Feb 11, 2009
    replaced flyback, TV WORKS!!!!!, but now i hear some intermittent (every couple seconds continuously) crackling coming from the yoke coil. I'm assuming this is arcing, will this cause the flyback to break again? If so, how can i fix the yoke, thanks
  • sunshine3139 Mar 19, 2009
    I have the same problem. Where on the board is the flyback transformer? What does it look like?
  • 934 Answers
You could ring the FBT if you have the equipment... If not I would suspect that also. RCA p/n# 257805 which is NLA so you'll have to order a 257807 which is electronically identical to the 257805 with the exception of a plug connected to the screen wire. You simply cut this connector off and you have a 257805.
Bill
Posted on Dec 21, 2008
  • William Rayburn
    William Rayburn Dec 21, 2008
    If you have to ask the question you likely don't have the equipment... Might as well shotgun the repair and simply replace the FBT or take it in to a tech and have it repaired. They will likely ring the flyback and in most cases that will be the problem..
    Bill
  • William Rayburn
    William Rayburn Feb 11, 2009
    I doubt the static discharge you hear is from the yoke, more likely the anode cup leaking. You can purchase some HV putty and form it into a ring and place it in the cup and seal the anode cup, that should stop the discharge.. Remember you're dealing with 20,000 volts on the crt - doesn't take more than a pin leak for some of that plasma to attempt to find ground.. Just don't get in its way!
    Bill
Mod.Hp980PT, red and top green light flash, no heat
This is a very common feature on these types of simple, high-volume, low-cost home appliances known as a safety fault. This fault will temporarily (or permanently) disable the appliance and happens for several reasons: (1) an over-temp (high heat) occurrence, (2) an over-power (power surge) occurrence, (3) an under-power (power outage or trickle power) occurrence, (4) an over-time occurrence (auto-off fails), (5) a short-circuit occurrence (exposed/crossed/frayed wires, etc.). Fortunately, it uses a digital "fuse" system and can be reset by the user. However, there is no universal reset process on SoftHeat products so you just have to play with it until you figure it out (customer service dept is no help). Mine is a Kaz SoftHeat HP980PT, with a red power indicator/power-off button and 4 green heat setting buttons. Mine faulted after a heavy storm caused multiple power outages and power surges in my neighborhood. The green light on the highest heat setting button was flashing on mine. Here's how I fixed it: (1) unplugged both ends of power cord and straightened out the cord, then plugged back in to the heating pad end. (2) While holding down the flashing light button, I plugged back in to the wall outlet. (3) While still holding down the flashing light button, pressed and held down the red power-off button, then while still holding down the red power button, I released the flashing light button, followed by releasing the power-off button. This stopped the flashing green light and caused the red power indicator light to stay on (steady-on). It works fine now. Note: Some models have an actual hard fuse in addition to the digital fault feature or possibly only a simple fuse (without the digital fault system). These fuses can the found at many retail stores and then very easily replaced. I hope this helps some of you!!!
Jan 27, 2014 | Softheat Heating Pad HP218 12 3P
How do i reset the service light on a bhm (voyager) v4 ceiling hoist?
To turn off the service light that is flashing red on your V4 BHM ceiling lift, you have to proceed this way:
1- Power off the lift with the red cord
2- On the hand controller, push on the PROG + RETURN button at the same time and maintaint it
3- Power on the lift
4- Keep pushing on both buttons, and push in order: UP, DOWN, LEFT, RIGHT.
5-The green light will flash and the buzzer will beep 5 times
6- Release all buttons on the hand controller.
7-Push on the UP button many times, till your hear 4 beeps
8-Push the PROG button once.
9-Push on the LEFT button many times, till your hear 3 beeps
10- Push the PROG button once.
11-Power off the lift with the red cord, then back on.
The service light should be off.
May 25, 2011 | Health & Beauty
Aquos model LC46D64U...approx 2 years old..Won't power up and get the power light flashing 3 times then the OPC light once..which is repeated...Any ideas...I believe this is quite common with Sharp TV's
I have a Sharp LCD 46 in.tv do this often.Yes,it is.This problems,the tv Tuner signal board have problem,but the tv is still useable.The POWER and OPC light indications flashes.Just push the power switch again,wait see tv turn,not POWER and OPC flashes again,push the power switch agian and wait.Have to do this like 3 or 4 times sometimes,than the tv backlight will come on,tv will work.Don't know but,if u require to pushing power button more 10 or 12 times,the tv Tuner signal board don't take an turn on the tv backlight get the tv to work.The Tuner signal board is dead,time to replaced the tv Tuner signal board.
Oct 18, 2010 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Waste ink absorber - what is it and how do we rep[lace it?
plz try
1) With the printer power turned off, while pressing the Resume/Cancel button, press and hold the Power button. (DO NOT release the buttons. The Power LED lights in green to indicate that a function is selectable.)
2) While holding the Power button, release the Resume/Cancel button. (DO NOT release the Power button.)
3) While holding the Power button, press the Resume/Cancel button 2 times, and then release both the Power and Resume/Cancel buttons. (Each time the Resume/Cancel button is pressed, the Alarm and Power LEDs light
alternately, Alarm in orange and Power in green, starting with Alarm LED.)
4) When the Power LED lights in green, press the Resume/Cancel button the specified number of time(s) according to the function listed in the table below. (Each time the Resume/Cancel button is pressed, the Alarm and
Power LEDs light alternately, Alarm in orange and Power in green, starting with Alarm LED.) [hth: I believe the power button has to be pressed once more after cycling the alarm button to complete the action. The power/resume-cancel button LEDs toggle to help you count.]
Time(s) LED indication Function Remarks
0 times Green (Power) Power off When the print head is not installed, the
carriage returns and locks in the home position capped.
1 time Orange (Alarm) Service test print See 3-4. Verification Items, (1) Service test print.
2 times Green (Power) EEPROM information print
See 3-4. Verification Items, (2) EEPROM information print.
3 times Orange (Alarm) EEPROM initialization [hth: does not re-initialize Waste ink counter]
>>>> 4 times Green (Power) Waste ink counter resetting
5 times Orange (Alarm) Destination settings [hth: not applicable]
6 times Green (Power) Print head deep cleaning (Cleaning of both black and color)
[hth: 7-10 not applicable]
11 to 13 times Orange, Green, Orange (Alarm, Power, Alarm) Return to the menu selection
14 not used in servicing
15 Orange (alarm) return to the menu selection,.
Note: If the Resume/Cancel button is pressed 16 or more times, the Alarm or Power LED lights steadily without
any changes.
Note : if the alarm light is flashing 15 times at turn-on [cartridge not recognized error], none of these procedures seem to work.
Aug 26, 2010 | Canon PIXMA iP4000 InkJet Photo Printer
Canon Color Bubble Jet Printer i550 wiil not print - (greenlight then orange light blinks 8x - then green light) When attempting to print receive "Printer not responding" - "Paper thickness lever...
try this. It is the reset for the waste ink error (8 flashes)
1) With the printer power OFF, while pressing the Resume button, press the Power button. (Do not release the
power button.)
2) While pressing the Power button, release the Resume button, press the Resume button again twice, and then
release the Resume button and Power button.
3) The green indicator flashes during initialization.
When the indicator stops flashing and remains on, press the Resume button 4 times to clear waste ink message.
(The indicator toggles between orange and green each time the Resume button is pressed.)
4) Next, press the Power button, and the green indicator will light, and the function will be executed.
5) Turn off the printer then back on and error should clear.
Aug 04, 2010 | Office Equipment & Supplies
When I turn on my Canon i560 printer the light blinks orange and green and will not print anything. I've tried to turn it off and on, unplug it and nothing seems to be working. What can I do to fix it?
power button.)
Aug 04, 2010 | Canon BubbleJet i560 InkJet Printer
My ps3 is dead!!!. flashing red light
Follow the procedure below to fix the problem on your ps3,
1. Turn off Playstation®3.
2. Hold the power button down; the system will turn on and turn off once again.
3. Once the System has been shutdown, re-press you finger until you hear 2 consecutive beeps
4. When you hear the 2 beeps take finger off power button.
5. You will be prompted to plug in your controller via USB and then hit the PS button
6. The Recovery menu will pop up.
The current Recovery Menu supports:
• Restart System: Restarts the PLAYSTATION®3 System.
• Restore Default Settings: Reset all system settings back to default.
• Restore File System: Checks for corrupt/missing system files.
• Rebuild Database: Rebuilds the OS for the PLAYSTATION®3.
• Restore PS3 System: Fresh restore; Deletes everything and starts from Scratch.
• System Update: Update the PLAYSTATION®3 System.
Take care.
Jul 20, 2010 | Sony Playstation 3 (PS3) Console
Flashing green light
Did you try this yet
SYSTEM RESET
If the TV will not respond to either the remote control
or the front panel controls and/or will not power Off,
press the SYSTEM RESET button with a pointed item
like the end point of a paperclip. The TV will turn Off
and the TIMER light will flash quickly for about one
minute. When the TIMER light stops flashing, you may
turn on the TV again. Changes you made the last time
the TV was On before you used the SYSTEM RESET
button may be lost, however, the changes you made
previously are not lost.
POWER/TIMER Indicator
The green light is a multi-function indicator. This light
will flash rapidly for about one minute each time the TV
is plugged into the wall electrical outlet, when power
is restored after a power failure, or using the SYSTEM
RESET button. Do not attempt to turn on the TV again
during this period. Wait for the flashing to stop and
the light to turn off, before attempting to turn the TV
on. While the TV is powered on, the light illuminates
steadily. If the TV has been programmed to turn on
automatically using the Timer feature,
Sep 21, 2009 | Mitsubishi WS-65515 65" TV
Error code e10
Communication failure =E10
1. Rotate the CYCLE SELECT KNOB to the 3 O’clock
position.
2. Press and hold the Select and Pause Cancel
buttons simultaneously for (6) seconds.
3. Immediately after, press and hold the START and
Pause Cancel
buttons simultaneously for (4)
seconds.
4. Rotate the CYCLE SELECT KNOB to the 2 O’clock
position.
The STATUS indicator lights will flash the number of
times for the first digit of the code and the START indicator
light will flash the number of times for the second digit.
The code is obtained by counting the number of times
the lights flash. Example E24: the STATUS indicator
lights would flash twice indicating the 2 and the START
indicator light will flash four times indicating the 4. The
STATUS indicator lights and the START indicator light
will start flashing at the same time. The control will then
pause for 2 seconds, then repeat the code.
Troubleshoot the problem by using the chart on next
page.
To move to the next code, press the OPTIONS button.
To clear code, press the Select botton.
To exit this mode, simultaneously press and hold the
Select and Pause Cancel buttons for (6) seconds to
reset.
if this does not work need to replace control
Sep 07, 2008 | Frigidaire Washing Machines
Error number 1700 canon s9000 printer
knowing printer manufacturers I doubt they even have a sensor to detect that its full at all, they probably based on something crumby like print count. here are some instructions to reset the waste ink tank, the instructions vary so try them until one does the job :
Waste Ink Tank Reset
1: Power off printer
2: Hold Resume button then press and hold POWER, the beeper will sound once.
3: Hold POWER and release RESUME
4: Press RESUME twice, then release all buttons
5: When the indicator lights steady, press RESUME three or four times. The indicator should be orange.
6: Press Power to set data
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not, press the Power button once more.
8. Your printer should respond as normal.
1. power off Printer
2. Push and hold resume button and push power button
3. Hold Power button and release Resume button
4. Push Resume button twice ( 2x ), and now release resume button and power button
5. Green light will blinking and stop.
6. When green light on, push resume button 4 x
7. Push Power button and printer will off, if that isn't off, push power butto again until print off position.
Aug 20, 2008 | Office Equipment & Supplies
RCA F36650 36" TV Logo
186 people viewed this question
Top RCA Televison & Video Experts
jason
Steve Allison
Steve Allison
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
