Question about MTX Thunder 1501D Car Audio Amplifier
My 1501d is making a wierd noise when i turn it on almost like an amplifed line noise but thats not the problem??
I have an mtx 1501d amp. that was hooked up to 2 kicker L7 15s and when i turn on my radio and turn the volume up in any way my subs start making a weird and really loud noise almost like an amplified line noise it use to work fine till i blew a tranistor i had all three in the set replaced and turned it on and it was working fine till it started to make this noise i hooked up another amp and they work fine all the subs are at the perfect ohms and wired right but the amp seems to have a prob. Any suggestions??
    Problem Solver:
  • 13 Answers
I had the same problem. Its your rca inputs. They need to be resoldered.
Posted on Sep 08, 2011
  • 109 Answers
Also check to make sure that your RCA interconnects are good. If you are using interconnects that have a screw on top piece, make sure that they are all tight. This can induce all kinds of noise.
Posted on Jul 17, 2008
  • 113 Answers
Check for broken rca input GND.
Posted on Aug 09, 2007
Can you bridge 2 4 ohm kicker speakers to a mtx thunder 7801 amp?
Ya. Just hook one sub to your amp (bridged) and hook the other sub (positive and negative) to the first subs positive and negative
Nov 12, 2010 | MTX Thunder TA7801 Car Audio Amplifier
I own a mtx 1501d.Also own a 18
THE AMPLIFIER NEEDS A 1 OHM LOAD AND YOU HAVE THE RIGHT SPEAKER TO PROVIDE THIS LOAD. THE AMPLIFIERS TERMINAL STRIP PROVIDES YOU WITH 2 POSITIVES AND 2 NEGATIVES, BUT THEY ARE ONLY FOR CONVENIENCE WHEN WIRING 2 DRIVERS. ACTUALLY THE 2 POSITIVES ARE THE SAME CONNECTION INTERNALLY ON THE BOARD, AS WELL AS THE 2 NEGATIVES. THAT BEING SAID, THE SIMPLEST WAY TO CONNECT YOUR SPEAKER IS TO PARALLEL THE VOICECOILS IN THE BOX BY CONNECTING THE 2 POS. TOGETHER AND THE 2 NEG. TOGETHER THEN RUN THAT POS. AND NEG. OUT OF THE BOX AND SIMPLY CHOOSE EITHER OF THE 2 POS AND NEG. OF YOUR CHOICE AT THE AMP. IF YOU EVER HAVE TO ADD A SUB, THEN YOU WILL HAVE 2 MORE TERMINAL LEFT OVER ON THE AMP. TO CONNECT IT TO AT THAT TIME. BY ALL MEANS, IF YOU WOULD LIKE TO RUN EACH COIL SEPARATELY OUT OF THE BOX AND CONNECT THEM TO ALL 4 TERMINALS, THEN THIS IS FINE TOO, AS EITHER WAY, THERE WILL BE NO DIFFERENCE WHATSOEVER. LET ME KNOW IF I CAN BE OF FURTHER ASSISTANCE....V
Nov 24, 2009 | MTX Thunder 1501D Car Audio Amplifier
1501d,, What subs should i use/
I would stick with Kicker or MTX. The best place in my mind to get them is soncelectronix.com
Just try to mach the specs as close as possible. Make sure to look at the recommendations of the subs for the size of the box and the port volume.
Oct 11, 2009 | MTX Thunder 1501D Car Audio Amplifier
1 ohm stable?
YES IT IS i have the same amp and i have it to 1 ohm its powering to kicker l7's which are 2ohm subs down to 1 ohm stability
May 16, 2009 | MTX Thunder 1501D Car Audio Amplifier
Most power out of amp w/out blowing subs
you may only be able to get but so much out of the subs. If you turn the bass down a little so the that you dont drive the subs so hard you may get a little more wattage out of them
Apr 06, 2009 | MTX Thunder 1501D Car Audio Amplifier
My subs make a loud humm when I turn my gain up.
your ground has to be no longer then 2 feet if ot it picks up noise from rca
Mar 13, 2009 | MTX Thunder 1501D Car Audio Amplifier
Need help MTX 1501d amp diagram
Remove cover and set in direct sunny window for long time, may be no problem with it, Took a month to dry one of my amps out enough that it decided it would come back to life, cell phone dropped in sink took 2 weeks, If you try power to it too soon --fried--, good luck finding diagram and repairing it sincerely-hope its okay, good amp, bad luck,
Mtx thunder 1501d
yes you can not run amps with your speakers being grounded un ground and then try
Nov 26, 2008 | MTX Thunder 1501D Car Audio Amplifier
My mtx thunder 1501d car amp making noise in the subwoofers
This is common with pioneer head units, the rca jacks are not properly grounded and this lets engine noise come through the rcs cables. This thread explains a fix http://www.caraudio.com/forum/showthread.php?t=337644.
Nov 13, 2008 | MTX Thunder 1501D Car Audio Amplifier
Makeing poping noise
Although open shields on the head unit generally cause MTX amps to squeal, it can sometimes cause the symptoms you described. To check the shields, you will need a multimeter. The procedure is on the following page:
Testing for Open Shields on RCA Signal Cables
If the shileds are OK, we will have to check a few other things.
Nov 11, 2008 | MTX Thunder 1501D Car Audio Amplifier
MTX Thunder 1501D Car Audio Amplifier Logo
186 people viewed this question
Top MTX Car Audio & Video Experts
hoyzee1
Marvin
Marvin
RegWorts
Level 1 Expert
Are you a MTX Car Audio and Video Expert? Answer questions, earn points and help others
