Question about Samsung HP-R4272 42 in. Plasma HDTV
When Playing Halo 3... The Screen Shrinks Down...
So, when I initially start up the game on my (Samsung 42'' Plasma 720p) tv (which I just bought from best buy 1 week ago) it displays the full 16:9 or whatever it is. HOWEVER, once I go into matchmaking and finally make it into the round... the display changes to 4:1 or whatever the smaller ratio is. (There are two 4 in. black bars runing the down the right and left side)
I have the same samsung tv (just LCD and 1080p) and this tv doesn't do that...
  • 121 Answers
16:9 is the widescreen mode, the other size is 4:3 ratio which is what the game's native size, it is picture boxing by the plazma is showing the size as not to distort the image, to get the full screen picture, but make sure it's not the plazma's setting first - where it selects the size of the image, you may have the streched version on your normal play.
Posted on Jan 29, 2009
Snow on screen with no picture.loud noise on audio
42" Vizio TV flickering strobing easy way to repair VW42L ...
? 2:49
Dec 2, 2013 - Uploaded by ozzysslayer
42" Vizio TV flickering strobing easy way to repair VW42L HDTV10A LCD TV ... EASY How to Fix Samsung LCD TV Flashing Flickering Screen!Missing: vp422hdtv10a ‎snow
Vizio Replacement Boards - > ... > Plasma & LCD TV Forum
Apr 15, 2009 - I have a vizio p42hdtv10A that just went into a black screen. .... I have a Vizio VP422 HDTV10A that will not stay on or show a picture. I removed ... Vizio vp422 hdtv10a
Dec 20, 2011
May 13, 2011
More results from
Dec 30, 2015 | Vizio VP422HDTV10A 42 inch 720p LCD HDTV
My tv goes from 1080 to 720 while I'm playing my ps3 how can I make it stay on 1080
You have make sure the game can run in 1080p first by looking at the back of the box. If it can, and you're using hdmi etc then simply do the following:
1. Go into display settings.
2. Select HDMI, then "custom"
3. Uncheck 720p and 1080i, leave 1080p selected.
4. Start up the game and double check it is on 1080p.
Otherwise, you're stuck because the majority of games are in 720p to avoid lag within the game.
Dec 10, 2010 | Westinghouse W4207 42 in. HD-Ready LCD TV
42" 720p Flat-Panel Plasma HDTV: hey i have an insignia is-hd 42" tv. the power com...
We recommend that a technician diagnose and complete repairs. In home service can be obtained by calling 1-888-237-8289 in the U.S. or 1-866-237-8289 in Canada.
May 18, 2010 | Panasonic 42" 720p Flat-Panel Plasma HDTV
Cracked plasma screen
honestly probably not worth it
May 31, 2009 | Insignia 42" Flat-Panel Plasma HDTV
Samsung Model: HP-R4262 42" Plasma Problem, pink pixelation/ghosting
Onece the plasma heats up it shrinks a little, i think the cause is that you are low on plasma, so when i heats it shrinks and since the plasma cycles, the area low on plasma wil move slowly around the screen, take this to a repairman and more plasma can be added to it.
Jun 19, 2008 | Samsung LN-R268W 26 in. HD-Ready LCD...
Samsung Plasma 720p HDTV hpt5034
If this is a new set, return it for exchange. This is a warranty repair item.
Mar 19, 2008 | Samsung SPN4235 42 in. Plasma HDTV
Replace the Main board of your tv.
Dec 30, 2007 | Samsung SPN4235 42 in. Plasma HDTV
Time lag between Playstation 3 and LCD TV.
If your playing with lag on your new HD LCD your at a competitive disadvantage! Everything you see happens seconds later than your opponent who has his/her settings right.
The fix:
1. Connect your PS3 using HDMI Input 2.
2. SELECT or RENAME the HDMI Input to PC. Already pointed out, but this does not make the majority of tv's run in PC mode.
3. On the PS3 start-up menu go to Settings---> Display ---->
Choose HDMI ----> DO NOT choose AUTOMATIC ----> SELECT CUSTOM ----->
4. Now, Select all the Resolution options EXCEPT 720p. This will force your games into 1080p mode. What it will also do is drop any game that doesn't have 1080i/p support into 480. Games like Burnout Paradise, Vegas 2, Heavenly Sword, NHL 08 and more will be dropped into SD (480) rather than HD. Your picture will be terrible. 720p is standard gaming resolution currently, 1080i/p is not.
5. Save and complete the display setup.
6. Turn off the PS3. Turn off the TV.
7. Turn on the TV. Turn on the PS3.
8. Complete! (Lag eliminated). Please spread this around!
*The key to eliminating ALL LAG is modern LCD's need to be in PC MODE (NOT GAME MODE) On many tv's, PC mode requires you to use a VGA or DVI connector. You'll either need to buy an HDMI adapter or an HDMI to VGA / DVI cable if that's the case.
and the Source MUST BE IN 1080p so that the TV can use it's NATIVE RESOLUTION.* Please, check your tv's native resolution. If you have a plasma that only does 720p, your native resolution is probably 720p. You do not need to follow these steps, it will only make things worse. If your tv's native resolution is 720p, obviously you want to keep your display settings at 720p on your PS3. If your native resolution is 1080i, you shouldn't go selecting 1080p. If your native resolution is 1080p on your TV, you need to be aware that removing 720p as an option will force many games into 480.
Keep these things in mind and remember that the steps above are far from a cure all solution. .
Lag gone! Worked for me! (SAMSUNG LNA52850)
Source :
Dec 16, 2007 | Sony Playstation 3 (PS3) Console
Open Questions:
See all Samsung HP-R4272 42 in. Plasma HDTV Questions
Samsung HP-R4272 42 in. Plasma HDTV Logo
179 people viewed this question
Jerry Greenberg
Jerry Greenberg
