If the light is blinking is it charging because my battery wont charge
SOURCE: My Psp battery will not charge. I tired plugging
it is shot. a quick test is try another psp and charge it with that one.if it does charge then it is your psp and your psp might be fried.if the battery doesn't charge then try another known woking battery.if you got any more qeustions email me at [email protected]
SOURCE: My PSP's charging light is blinking but it doesn't charge
Have you tried a new battery?
They can only take so many recharge cycles before they die like my Ryobi cordless drill stuff
SOURCE: I HAVE A PSP 1002 (ORIGINAL MODEL). the problem is
i do believe you have burnt out the inverter within the system :( i dont have an answer for you on how to persue a fix but i do wish you good luck .......keep in mind these are very cheap new nowadays so dont pay a big amount to fix it if possible ok :)
I have the same problem... I thought it might be because that wall charger can only charge the 1800mAh battery and not any of the larger ones like the 2200mAh batteries. I can charge my smaller 1800 battery, but not my second, larger 2200 battery in it... I get the blinking light. I ordered an actual AC adapter to see if the PSP itself can charge it.
