Question about RCA DIRECTV Satellite Remote Control
Direct tv works but remote doesn't
I have a brand new Toshiba LCD and hooked up my direct tv to it with the yellow, red and white cable. The direct tv works but the remote won't do anything. In order to change the channels or do anything you have to press the buttons on the face of the direct tv receiver. It was working fine last week with my other tv.
    Top Expert:
  • RCA Master
  • 76,016 Answers
Check the remote control for its infrared emission. Check it with fresh batteries. Check it by pressing all the keys. You can detect the presence of infra-red emission from the remote control, using a cell-phone camera. If you wish to get more details about how to check a remote control, please visit this site. One among the posts has details about it. In some cases, the remote control might need to clean.
http://homenol.blogspot.com/
http://remotesearch.blogspot.com/
Search the site by type in this key phrase "how to test a remote control "in the "search box at the top right of the display window of the Homepage" to get the related post quickly.
https://youtu.be/wUpnETSm6_k
https://www.youtube.com/watch?v=jsSCNCW3IbQ [open and clean]
https://www.youtube.com/watch?v=Qp-l1uh-5gE [open and clean]/
Posted on Dec 09, 2017
techman
  • 3130 Answers
SOURCE: channel selection
What you need to do is take the remote, go into the menu, find channel scan and do a channel scan to find all the available stations available on this system. Make sure the TV set is in the cable mode and not antenna mode or you wont get any stations above channel 13.
Posted on Sep 18, 2006
snakehead
  • 1074 Answers
SOURCE: TV - DVD Hookup
use another tv and see what it does if it works on the other that is to say that your tv is defected in the video circuit.if the dvd does not work on the other tv then your dvd is not functioning. then it is time to call in the tech,good luck.
Posted on Apr 01, 2007
  • 12 Answers
SOURCE: Programming the remote
1. Hold on TV and POWER simultaneously (light comes on), let go
2. Press POWER then CH+ back and forth (light comes on), when TV turns off
3. press STOP, code is saved!
Posted on Dec 15, 2007
SOURCE: RCA Universal Remote stopped working
I also have the same problem with my rcv remote and it started when the batteries accidently feel out
Posted on Feb 05, 2008
Kazong
  • 152 Answers
SOURCE: Remote control code to program for directv receiver
i have a ton of codes i need your model# of your Directtv Receiver.
We have a new Philips 32" LCD TV, 3500 series/32PFL3505D. We are having problems as we try to connect it to our existing Direct TV receiver. Do we need to call for Direct TV assistance, or can you...
Looks fairly straightforward.
Depending on the output of your DirectTV receiver, you are either going to use an HDMI cable.tomcattech17_0.jpg
A component cable: (Red\Green\Blue for video... White\Red for audio)
Or a composite cable: (Yellow for video.. White\Red for audio)
Hook one side of the cables to the Direct TV receiver and the other into the correct inputs on the back of the TV.
Page 9 and page 25 in the attached manual:
http://download.p4c.philips.com/files/3/32pfl3505d_f7/32pfl3505d_f7_dfu_aen.pdf
Hope this helps!
Jun 16, 2011 | Philips Televison & Video
The converter box is hooked On the TV and working. I have the TV with the rabbit ears and only video n audio in the front (yellow n white). I recently purchase a DVD player n I am trying to hook it on the...
you have to change the input on the tv to AV. there should be an input button on the remote, but if your remote doesnt work you might not be able to change the input. you can try to use the channel up and down on the tv and once you get to the end of the numbers, some tvs will change inputs before restarting the number list. make sure you hook the yellow cable to the yellow plugs on the dvd and the tv and either of the red or white ones to the white one on the tv. red and white are left and right audio and the yellow one is the video
Dec 24, 2010 | Insignia Digital-to-Analog Converter for...
Have no sound from VCR, cable hooked up properly, picture is great. TV is brand new.
Connect RCA cables yellow, white and red from VCR to TV. White and red are sound. Select TV input where VCR cables are connected using TV remote. Try different tapes. Turn up volume on TV.
Aug 12, 2010 | Toshiba M755 VCR
Can't hook vcr to tv
on the back of your VCR there will be a yellow colored port - most likely labeled "OUT" as well as possibly a white/red pair of ports.
The yellow is for a VIDEO hookup, the white and red are for AUDIO hookups.
These ports use what is called an RCA type connection.
Radio Shack, or just about any department store should be able to sell you an inexpensive set of RCA cables.
now on the back of the TV (possibly on the side) you will also have the yellow, white and red ports.
Hook one end of the RCA cable to the colored ports on the VCR, the other end of the cable to the colored ports on the TV.
last thing - the TV most likely has multiple inputs. there is probably a input button on the TVs remote, you need to press that button to cycle through the inputs until you get to the one the VCR is hooked up to.
its easiest to put a tape in the VCR and press play - when you get to the right input, you will see your tape...
good luck
Apr 05, 2010 | Dynex DX-L32-10A 32" LCD HDTV
No signal from my dvd player
Can you tell me how to connect my dvd player to my 42 inch proscan hdtv ? There are no yellow,its blue and there are two rows of the same colors.
Feb 03, 2009 | Proscan 32LA25Q 32 in. LCD TV
How do I hook up the DVD player to the TV?
Hi, basically you need to put them into their respective slots in the back of the tv. I know this can be frustrating because the slots are all faced downwards, tucked behind this piece. Look at this image, which should be what you are seeing if you're using a Toshiba 26'' 26AV502U, a model similar to yours.
http://www.bestbuy.com/site/olspage.jsp?id=cat13506&type=page&h=387&skuId=9034733&productId=1218010846690&&viewtype=backView&count=0
Look at the four plugs with labeled "Video 1 In." "L Audio" is your white plug, "R" is your red plug(R actually stands for Right [Audio Input]), and Video is your yellow plug. It would be wise to remember this for every Audio/Video cable accepting unit. It makes sense you are putting the cables IN to the tv, hence "Video 1 In."
Now, to tell the tv to read the video input, find and hit the "Input" button on the remote, and it should be one of those options..(there are only a couple to choose from).
Hope these directions worked for you, and enlightened you!
Dec 29, 2008 | Toshiba 26AV500U 26 in. LCD HDTV
Sony T240HD monitor TV
make sure that the plug on ps2 is connected and check the settings on tv and the settings on ps2 browser are correct if possible check ps2 on another tv to be sure of it's settings if the ps2 works the check channel setting on tv make sure it's not in pal setting it should be ntsc and also check the antenna setting make sure it might be set to cable and also check cables of any sharp kinks your problem is with the yellow cable red and white is the sound
Dec 01, 2008 | Samsung T240HD 24 in. LCD TV
Toshiba 36AFX61
Just Connect signal to tv and run autoprogram. Or use video input jacks from converter to tv ( yellow,white and red video in ) and select tv/video on tv pannel front ( don't need remote control) I hope this work for you.
May 11, 2008 | Toshiba 36AFX61 36" TV
DVD VHS recorder
It sounds like your cables are connceted ok, but what you neede to do is to be able the switch from one video mode to the other so lets go through the cable and vrc conncetions again just to make sure. From your cable set top box connect your component video (RGB) video out to your TV (RGB) video in via the (RGB)cables. From your VCR connect your composite video (yellow) out to your TV composite video in withe the composite video (yellow) cable. From your VCR (Left & Right audio out)connect your left and right audio connections (White and Red) to the Audio in of the TV (Left and Right). Whith this setup you should be able to use the TV to switch between the two A/V inputs using the remote control.
Sep 03, 2007 | Philips Magnavox 27MS343S 27" TV
Can't find my user manual and need help hooking it up
First check Color code
Yellow is for Video Red is for Audio Right Speaker White is for Left Speak.
Do you see rear pannel of the DVD there is Socket
Connect Yellow Cable to Video Out on the Dvd other end of the Cable to Video In on TV.
Connect Red Cable to Audio Out on the DVD other end of the cable to Audio In on TV.
Connect White Cable to Audio Out on the DVD other end of the Cable to Audio In on TV.
Turn on TV as well as DVD Player.
ON tv remote do you seee buttons as TV/AV. AV, Aux, Video, Input, or Game, Pree any one of these Buttons, You should be able to get Picture.
Jul 30, 2007 | Curtis CMD5000 DVD Player
RCA DIRECTV Satellite Remote Control Logo
32 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
