I just purchased a Mitsubishi LT-52144, we connected the wires to the cable box, the tv had picture for about 20 minutes then the screen turned black. We can hear the sound but there is no picture. Please help!!
    Problem Solver:
  • 6 Answers
Contact 9420806154
Posted on Dec 21, 2008
  • sidney faber Dec 21, 2008
    contact 9420806154
How to take base stand off
The should from 4 to 6 screws near where the base & tv come together. They are either #2 phillips or torx(t-20 or t-25) screws. Unscrew and the base pulls out straight down.
Jun 27, 2015 | Mitsubishi LT-52144 52 in. LCD HDTV
My 52" mitsubishi Model LT-52151 has sound no picture
Wow. There could be several causes for that. This model does have some history of main board failures after a few years of use, but let's hope it's simpler than that.
We'll start by assuming that the symptom shows up on a cable or satellite feed. Have you also tried playing a DVD? If so and you get a picture, the problem is not with the TV -- it's with your cable feed, the cable box, or the connections between the box and your TV.
Check the cable equipment first. I'm guessing that other sets in your house do get a picture, and that therefore the cable feed is good. If that's true, check the box connected to the Mitsubishi. To do so, pull its power plug out of the wall and wait a couple of minutes, then plug it back in. (It will take a minute or two to restart, and the program guide will be empty for a couple of minutes more.)
If that doesn't bring back the picture, the problem is either the wiring to the TV or something inside the set. We'll start with the wiring.
Assuming you're using HDMI cables (single wire with one rectangular plug at either end), try unplugging and replugging them at both ends. These connections sometimes become loose, and doing this will restore the connection. If that works, go buy new HDMI cables -- yours may be getting tired and should be replaced.
Some cable companies routinely use the old, less efficient component cables (5 wires, with 5 round plugs at each end) to hook up TVs. If you have them, just make sure they aren't loose in their sockets.
If that does not correct the problem the chances are your set has an internal failure, either on the main circuit board or in the display section. Try disconnecting the power to the TV for a minute (pull the plug). Sometimes this resets the main board on this model and it begins to work again.
Otherwise you'll need professional service, which can be expensive. It's possible the backlight on the display is gone, which is not that pricey an item. But circuit boards can be expensive, and labor costs mount up quick. So don't commit to getting the TV repaired until you find out how much it will cost, even if you have to pay to get an estimate. Your set is around 5 to 6 years old, and given the price of a new TV, you may find out that it doesn't make sense to fix the old one.
Good luck.
Jun 07, 2014 | Sharp LC40E67UN TV
Green light stays on when trying to turn off tv. picture go's off when cable remote is used but green light stays onand you can see that screen is still on?
You need to set up the cable box remote for your TV , now you are just turning off the cable box. Some cable boxes have a switched plug on the back that will turn on and off with the box. If yours has the switched receptacle you can use that to turn the TV on and off by plugging your TV into the switched receptacle. Make sure the TV power is on, the receptacle will kill the power so the clock on the TV wont work. Otherwise you need to set the code for your TVs remote and use the system power button.
Apr 23, 2014 | Mitsubishi LT-46153 LCD TV
Problem with the Mitsubishi LT-52144 52 in. HDTV LCD Television TV will not turn on, power light flashes rapidly
Hello. I was in a live session with you earlier and it seems like you accidentally closed the window. Does the tv tv click on momentarily before it shuts off and starts blinking?
Feb 12, 2011 | Mitsubishi LT-52144 52 in. LCD HDTV
Black and white lines running through the screen
you have loose connections on the boards, or capacitors leaking.
Jan 27, 2010 | Mitsubishi WS-55511 55" Rear Projection...
Will not unlock for PG-13 and R rated movies
I can help you unlock your Mitsubishi HDTV V-Chip.
Please follow these steps to bypass the vchip or reset the V Chip password.
I hope that helps.
_______________________________________________
Reset Mitsubishi HDTV VChip Password
Bypass Mitsubishi HDTV Front Panel Lock
Jul 26, 2009 | Mitsubishi LT-52144 52 in. LCD HDTV
Spot on the screen
This problem is covered by Mitsubishi even out of warranty.
Jan 14, 2009 | Mitsubishi LT-52144 52 in. LCD HDTV
Mitsubishi 52144 won't power on with blue flashing led
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://homenol.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Mar 12, 2017 | Mitsubishi LT-52144 52 in. LCD HDTV
Mitsubishi WD-62825 Green Blinking light and TV won't turn on
I have the same problem with the green light blinking and the T.V will not come on. I have reset it and unplugged it and everything and still nothing. Can anyone help me
Aug 19, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Toshiba RD-KX50 HDMI freezes the recorder.
Press the standby button for about 10 seconds and will reset the HDD you may lose what you have on the HDD but will fix it.
May 07, 2008 | Toshiba RD-KX50 DVD Recorder/HDD Recorder
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
