Question about Motorola Mobility V170
Loss of vibration
I recently lost the vibration mode on my phone. Is this an indication of time to replace the battery?
    Problem Solver:
  • 12 Answers
Loss of vibration doesn't indicate battery's life is coming to an end. There are lots of probable cause to this problem. It can be mechanical - a small motor responsible for the phone's vibration might be defective due to prolonged use. Since I will not be able to actually check your phone, the best solution to this is bring your phone to a qualified phone technician in your local area for proper diagnosis. He's the right expert and the second opinion to that kind of problem.
Posted on Apr 04, 2007
How can I increase battery life for my iPhone 6?
tips-to-increas_27396731-gvhr1u2s3xea1la53vdrzj4m-3-1.png Apple's confirms that their iPhone becomes slow with time , as well as their battery will be perform below average after certain period of time , then here are sort of tips that can help iPhone users to boost up their phone battery lastly more than average time
@use phone screen brightness low and on manual mode
@Use Aeroplane mode when their is no signal possibility
@use silent mode instead of vibration mode
@keep Homescreen clean with minimum apps
@Use dark wallpaper which having low intensity
@turn off all background Apps
@Keep all app with updated version older app may consume more powers
@ Use manual data on when their is no wifi zone
@keep system clean
@use power saving mode
For more iPhone support services visit http://iphoneexpertsusa.over-blog.com/2018/01/want-to-replace-an-old-iphone-battery-how-much-will-it-cost-in-usa-know-here.html
Want to Replace an old iPhone battery How much will it cost In USA Know...
Jan 18, 2018 | Cell Phones
How to removed or turn off the vibration on the phone?
What phone you have would be useful to know but for
Android : How to Turn off Sound and Vibration in Androids Keyboard
Iphone: If you set the iPhone to vibrate in silent mode, it still makes an audible buzzing sound that may bother or disrupt others. If you need your iPhone to stay completely quiet, temporarily disable vibration. You can turn off vibration when silent mode is on, off or both. Tap the button next to "Vibrate on Ring."
Blackberry:
Turning vibration on my mobile phone on or off
  1. Find "Notifications" Slide your finger down the display starting from the top edge of your mobile phone. ...
  2. Turn vibration on or off. Tap the indicator next to Vibrate to turn the function on or off.
  3. Exit.
Nov 09, 2015 | Cell Phones
If I have lost acid from my battery should I have it replaced
If it was lost by evaporation it was just water that left, so add distilled water only. If it was lost by spillage then add a mix of 37-38% sulphuric acid with distilled water, to the correct level indicator.
You can get this mix from an autoparts store like Autozone. It can't be sent by post. If you make the mix yourself, then only ever add acid to water a bit at a time, NEVER add water to acid, it will spit. Wear good eye protection and rubber gloves as well.
Aug 21, 2015 | Cars & Trucks
Vibration is not working
Most cell phones the vibration mode is produced through the battery, nine times out of ten if the phone wont vibrate it is an indication of battery going bad. First try removing the battery and putting it back in, also try charging the battery while the phone is shut off. If these dont help you may have to look into another battery. Hope this helps.
Aug 26, 2012 | Nokia 5530 XpressMusic Smartphone
Battery power was very low. plugged Drsire into charger and set phone to shut down mode. when i unplugged it from charger and pushed the 'on' button,the phone vibrated 3 times but will not turn on.have...
Please remove the charger and take the battery out of the phone for one minute. Whilst the battery and charger are out press and hold the power button for 10 seconds to drain any residual power from the phone.
Replace the battery and charger and after a minute power up again.
If the issue is resolved or if it persists please do let me know.
Many thanks for using FixYa
Nov 27, 2010 | HTC Desire Cell Phone
My LG enV Touch Does'nt vibrate!
You don't have to have the spindle... just go to "touch settings" and turn the vibrate on. I had the same problem.
Oct 25, 2009 | LG enV Touch VX11000 Cell Phone
MY COPIER SAYS "MAKING SPACE IN MEMORY" HOW DO I CLEAR THE MEMORY?
If the machine remains without power for a
specific period of time (about 2 hr or more)
while an image exists in its memory, the
power of the vanadium lithium secondary
battery (BAT2) will become exhausted. A
report will automatically be generated when
the machine is turned on.
or
When the jumper plug (JP1) is removed, all data in
control memory will be lost. Therefore, do not
disconnect the jumper plug (JP1). The data stored in
the SRAM is as follows:
- user data (data indicating user mode settings)
- service mode deta (data indicating service mode
settings)
- control data (communications control record of most
recent 20 communications, system dump record)
Jul 28, 2009 | Canon imageCLASS D860 All-In-One Laser...
Battery indicator,interior and head lamps flicker
check heat shield around the cat ...if there is no heat shield ..you should install one
Jul 25, 2009 | 2004 Ford Escape
How do i turn my phone to silent mode?
To place the handset in Silent / Vibrate Mode
Step 1
To place the handset in Silent / Vibrate Only Mode, hold down the pound key (#) for about 2 seconds. To exit Silent / Vibrate Mode, perform the same action while in Silent / Vibrate Only Mode. You will see a confirmation message for Silent / Vibrate Only Mode, each time you enter or exit Silent / Vibrate Mode.
The SCH-U470 (Juke) handset will vibrate rather than ring when you receive a phone call, message or alert while in Silent Vibrate Only Mode.
Step 2
While in standby mode, press the volume key, located on the left side of the handset, then select either “Vibrate Only", “Alarm Only” or “All Sounds Off”. To disable perform the same action while in Silent / Vibrate Mode.
The SCH-U470 (Juke) handset will vibrate rather than ring when you receive a phone call, message or alert while in Silent / Vibrate Only Mode.
Jun 08, 2009 | Samsung SCH-U470 Juke Cellular Phone
W380i vibration problem
The vibration is performed by a small motor in your mobile.. please check it out it... i think its gone.. It will be in back side of your mobile... near battery..
May 29, 2009 | Sony Ericsson W380i Cellular Phone
Motorola Mobility V170 Logo
49 people viewed this question
Top Motorola Mobility Cell Phones Experts
vince
D. E. Hev
Steve Berry
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
