Question about Toshiba REGZA 47HL167 TV
How to fit TV base to Toshiba Regza LCD TV 42xv500a
It seems the base stand does not fit into the Toshiba Regza LCD TV 42XV500A. Any suggestion would be apprecaited. I wonder whether there is a chance that I got a wrong base stand.
  • Anonymous Apr 22, 2009
    I want to know how to take the base so i can put on the wall
SOURCE: taking stand off toshiba regza tv
forget the four holes on the bottom of the stand. Remove the five allen bolts on the back bottom of the tv-not the stand. Yank on stand and metal plate slides out with stand.
Posted on May 17, 2009
  • 36 Answers
SOURCE: Connecting Compaq Presario CQ40 to LCD tv Toshiba REGZA '32'
Check your resolution output from laptop it maybe set to high for the TV to handle, also go to the Display Properties and ensure that the second monitor out is enable. Good luck!!
Posted on Aug 03, 2009
  • 290 Answers
SOURCE: Best picture settings for toshiba regza 42RV500e
Go to menu on your remote control and select picture setting and try selecting "default" setting to seeif you like the color, if not adjust contrast to about two thirds of the way and brightness to your liking and color to about the middle.
Posted on Jan 17, 2010
SOURCE: Can't remove base-mount from Toshiba REGZA 46
Forget Youtube (it's been removed anyway) here is the incredibly simple answer straight from Toshiba ...
http://www.tacp.toshiba.com/customersupport/pdf/FAQLCD00009.pdf
Posted on May 30, 2010
SOURCE: how do I take the swival base off my toshiba regza
how do i take the base off my toshiba regza tv
Posted on Apr 11, 2011
What size bolts attach tv to stand for Toshiba 37"
You will use the bolts that you take out to remove the base from the tv.
Mar 21, 2011 | Toshiba Regza 37HL17 37 in. LCD TV
I can not get the base off
Follow the below instruction on how to the base off your Toshiba LCD TV;
  1. Turn off your Toshiba TV if it is on.
  2. Unplug your TV from the wall and any other devices (like DVD players or Blu-ray players) that it is connected to.
  3. Put a blanket, towel or some other kind of soft object down on the floor (if you have hardwood floors and not carpeting in your home).
  4. Set your Toshiba TV down onto the soft surface with the screen facing downward toward the floor.
  5. Use a flat-head screwdriver to remove the two large, plastic bolts on the rear of the TV stand's base. These bolts are holding the stand onto your Toshiba TV. Set the bolts aside.
  6. Use your hand to pull the base off of the Toshiba TV. You will now be able to set your TV completely on the ground. Put the base (as well as the accompanying bolts) aside for safe-keeping, in case you ever need to use them again.
I hope the above helps.
Good luck.
Feb 02, 2011 | Toshiba REGZA 52RV530U LCD TV
How do i get the stand off so that i can mount the tv on my wall
Lay down the tv picture screen on a soft flat surface.Check all the screws holes and take out all the screws.Take ur hand holding on to the tv and base stand tight.Pushes in and out few times.The base stand should came wright out..
Dec 24, 2010 | Toshiba Regza 42RV535U 42 in. LCD HDTV
I need a pedestal stand for my Toshiba 42RV530U. Do you know where I can get one?
Manufacturer Toshiba Part Number 75010935 Description BASE BASE ASSY, BASE
Aug 08, 2010 | Toshiba REGZA 42RV530U 42 in. LCD HDTV
Can't remove base from Regza 37HL17
download manual and check' page 5 'for wall mounting.
Removing the Pedestal Stand
1) Carefully lay the front of the unit face down on a flat,
cushioned surface such as a quilt or blanket. Leave the stand
protruding over the edge of the surface.
Note: Extreme care should always be used when removing
the pedestal stand to avoid damage to the LCD panel.
2) Remove the jack pack cover on the back of the TV to expose
the pedestal stand screws. The jack pack cover can be removed
without tools.
3) Remove the five screws shown in the diagram below. This will
allow removal of the pedestal stand.
4) Once you have removed all five screws holding the pedestal
stand in place, remove the pedestal stand from the TV by
sliding the pedestal stand away from the TV.
Five screws
Feb 14, 2010 | Toshiba Regza 37HL17 37 in. LCD TV
Im wanting mount my 37 in toshiba regza but i can figure out how to take off the bottom brace that supports the tv as it stands. i have taken off all the screws but the brace or base still wont come off.
Carefull turn the tv on it's back and remove the 2 black screws in the bottom of the stand in addition to the screws on the back that I assume you already removed.
Nov 10, 2009 | Toshiba REGZA 47HL167 TV
Toshiba REGZA 47HL167 TV Logo
781 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
