JVC TH-L1 no sound through tv
Just bought a JVC TH-L1 system.i have set it up to my ps3,ps2 and tv and have picture with all but no sound.i know the sound works because i can plug in my ipod and it works fine.all i have used to connect it all together are red yellow and white component cables.in the book it talks about composite video cords and s-video cords...is this what im needing?like i said i have picture on my tv through my jvc unit of both my consols and all the cords are pluged in i just have no speaker sound with any of it apart from my ipod.any help would go along way cheers
  • Anonymous Jan 03, 2009
    I have the exact same prob, only Im using the HDMI hook ups from PS3 to JVC unit, then to TV.
techman
  • 3130 Answers
SOURCE: audio/vidio plug in wont show picture on screen, only sound.
There is a broken connection inside the set at the jacks on the set. If you know how to solder and work on solid state circuits, you may be able to repair this,BUT if you dont please take to a repair shop as it should not cost much to repair this. A tV set is not a place to experiment with!
Posted on Sep 02, 2006
SOURCE: JVC Home theatre system TH - S3
This appears to be a hardware problem in the video signal path.Have it checked by a technician.
ampere
Posted on Mar 13, 2008
SOURCE: Hooking up Xbox 360 to JVC TV 20 inch 1 year old tv from Luxembourg
change the plug on the back of your xbox 360 from hd to tv unless of course your tv is hd then change it to hd :]
Posted on Dec 17, 2008
joshter32
  • 82 Answers
SOURCE: no sound from JVC do have sound from TV connected
hey man my names josh i used to work in home theatre if you can clarify what your problem is i can walk you through it my cell is 832 248 4144 on thing thing yo want to check with that no sound being produced out of of hdmi is to make sure that the port that you have it running to on your tv does not have a set of analog jacks next to it. if thats the case you want get your sound cause you will have to run sound with your hdmi next to that port on the tv that is if your tv has that function and providing you have more than one hdmi port on your tv it will most be the first port you have it pluged into if not you may need to check your wiring and your pre sets on the tv as well as your wiring that your have going to every thing cause i cant promise you that everyting may be hook up like it should but i can straiten that up for ya like i said my name is josh and my cell is 832 248 4144
Posted on Nov 02, 2009
fkuk
  • 311 Answers
SOURCE: fitting a jvc head unit to a 1990 telstar tx5
get a voltmeter(multimeter) and check the voltage on the
red wire
and
yellow wire
(from the car)
when the car is turned off and when the car is on
one should be 0V when the car is off
and both should be 12V when the car is on
then you need to match that up with the radio using the manual
but im guessing that you dont have a manual so...
i want ot confirm that
when you connect red to red and yellow to yellow
nothing happens
try the oposite way
red to yellow yelolow to red
Posted on May 29, 2010
I have JVC TH-L1 sound system and it stopped working
I had the same problem change the fuse before you mess up the circuit board .
Aug 06, 2012 | JVC TH-L1 Theater System
I've had my JVC TH-L1 Theater System for about 2 years now. I recently rearranged my theater setup in my living room and after reconnecting my system the receiver will power up but not work. I have...
The fact that it stopped working after you tampered with it implies human error in reconnecting.
I'd advise you to carefully go over every thing you touched and crack the manual for settings.
http://www.retrevo.com/s/JVC-TH-L1-Home-Theater-Systems-review-manual/id/2771ag519/t/1-2/
Treat it like you just opened the box for the first time.
Keep the volume at a medium level until you figure it out. One misplaced control like a Mute or Tape Monitor, when flipped, could blow your speakers if the volume is set too high. If you can't hear a source at 1/3 volume it ain't there.
Jan 20, 2011 | JVC TH-L1 Theater System
No sound from JVC do have sound from TV connected
Nov 02, 2009 | Audio Players & Recorders
Th-l1 no back lit screen
Although not fully familiar with your unit, many receivers have a small lamp behind the display panel. Sometimes they burn. It is not to easy to replace them bya DIY. If the unit works fine otherwise, it could be just that. lots of other units use Fluorescent type displays, and if they go bad, causes are more complex.
Good luck.
Oct 06, 2009 | JVC TH-L1 Theater System
Hooking up my ps3 to a all in one jvc home theatre system
Well I am assuming that you have a HD tv, If so than you can run HDMI from Ps3 to Tv then run optical audio wire from ps3 to reciever.To listen to ps3 turn reciever to aux setting.
Hope this helps
Apr 29, 2009 | JVC TH-G30 Theater System
Cannot figure out how to hook up my jvc th c5 to my tv & cable tv
Do you have audio outs on you tv to run to the jvc
Mar 15, 2009 | JVC TH-C5 System
Connecting PS3 to receiver via HDMI
First put the orginal ps3 cable onto ps3 then to tv.set tv to see ps3 and go to ps3 setup,now down to display settings,set to hdmi,picture will go off so now switch tv to hdmi input .Next go to sound settings for ps3 and set to hdmi if your amp can work this way ,if not set sound out to optical.
hope this helps.
CABLE GUY.
Jun 24, 2008 | Onkyo HT-SR800 System
JVC TH-A9
1st u need to covert stereo cable with stereo conversion pin which avelieible in electronic consumer store after u got this cable u able to connect ur speakers directly to play station or a tv
Feb 19, 2008 | JVC TH-A9 System
Cannot TV to play throught JVC TH-C50
http://www.retrevo.com/search/v2/jsp/downloadPage.jsp?doc=9f8aca666be88c19dfe7c8b7d3504340&q=JVC+TH-C50
Dec 24, 2007 | JVC TH-C50 System
ampere
Oct 29, 2006 | JVC TH-S3 System
Televison & Video Logo
112 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
