Question about Nikon Coolpix L11 Digital Camera
Nikon Coolpix L18 keeps freezing
I just pulled it out of the box 20 min ago and it keeps freezing up. I put my memory card in and only have space for two pictures, so I have been trying to delete and retake images. After I deleted the 1st image, the camera froze and after 2 min or so it gave me a "please wait" message with the hourglass. I waited for a while & nothing happened so I popped the batteries out & restarted it. Then I deleted the last image from the memory & it froze on a black screen. The lens retracted back into the camera and the power light stayed on green. I waited, and then popped the batteries out again to start over. I cant seem to get any of the buttons to recognize when I try to switch from mode to mode. It freezes just like a computer does. HELP!! Its a christmas present & I would really love it to work!
  • jreed001 Dec 25, 2008
    I have a similar problem - camera freezes periodically. It sounds like ddancer2119's issue with only being able to store 2 pics may be a problem with memory card not formatted, though - did you format it? We've formatted ours, but it might have not been in right, I opened it and it was popped up, so we have just pushed it down, will see if that's the fix.
  • 423 Answers
Put in a new set of batteries and then before you do anything else format the SD card using the camera.
Posted on Feb 18, 2009
  • 4 Answers
SOURCE: I JUST MY GOT MY
hey dear you must have got the battery and charger along that charge those batteries for 8 hrs and then use coz nikon doesn't have LI ion battery so u have to charge the cells instead
Posted on Jan 10, 2009
robmcd27
  • 423 Answers
SOURCE: Nikon Coolpix L18 Driver
Try this, it may work without the software.  Turn off the camera. Plug the usb cable between the camera and the computer. Turn on the camera. If a box pops up on the computer asking what you want to do, scroll down and see if there is an option to view pictures. If a window opens up with all your pictures on it, great. Now open up a folder where you want to put your pictures. Bring up the other window with the pictures in it and hit the control key and the d key at the same time on your keyboard. Then drag your pictures to the window where you want them and let go of the mouse key.  They should all move over. Then you can use Windows image viewer to see them. Let me know if that works.
welcomejee
  • 10594 Answers
SOURCE: lens error message on nikon
When system control does not get lens initialize signal while extending it, then it try again by folding it and extending and still no required initialize signal then generate error and stop further functions.
Please remove battery and open camera and remove flexible wire of lens mechanism from connector, there would be lock that needs to release to remove flexible wire. Clean wire terminals with alcohol, let it dry and put back flexible wire in connector and lock it. Now put battery and power camera up, hopefully lens will work properly.
Hit "add a comment" button for further query / info.
Thanks.
Posted on May 01, 2009
  • 11967 Answers
SOURCE: The lens is jammed on a Nikon Coolpix L18?
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Dec 08, 2009
  • 502 Answers
SOURCE: Nikon COOLPIX L18 Digital says lens error!
Sometimes the lens is just stuck, sometimes it needs to be replaced. Try to mechanically move the lens in and out by gently twisting, pushing and pulling. If that fails, the gears are too misaligned to repair it without opening it.
If you're out of warranty, there are third party place that replace them such as camera lens repairs.
If you want to do it yourself, there are also free camera repair guide websites that show you how to replace the lens, the replacement part is usually available on ebay.
Posted on Jul 15, 2010
I put my memory card into laptop, message says my card is full, and yet i delete my pics from camera., do i have to delete from memory card also, if so how do i do that.
Did you delete the pictures from the internal camera memory and not the SD card? An easy way to solve this problem would be to insert the card into your computer and open up "My Computer". In here you should see your memory card mounted as a usable drive. Open up the SD card, select everything in it by pressing "Control" + "A" and then hitting delete. This will clean everything off of the card. If you want to save the files from the card first, simply make a folder somewhere on your PC and drag all of the files from the SD card into that folder after pressing "Control" + "A". If you are still getting an error stating your card is full after removing them this way you may need to re-format the card or it may be malfunctioning.
Jun 27, 2011 | Computers & Internet
I have several pictures on my camera I took a couple of days ago that show up in the view but will not upload to my computer. I deleted some pictures and video files to free up space but it did not help....
Transfer all of your picture to your PC, format your memory card to make it new again with full space of memory.
Or just buy a new memory card with larger capacity to get many pictures saved in it.
Hope this help and RATE please.
Jan 18, 2011 | Kodak EASYSHARE M1063 Digital Camera
Why does my fujifilm finepix z2 say card error. it was perfect half an hour ago.
All memory cards need to be formatted before use to provide optimum performance. Formatting provides the camera a clean medium to put the picture files on. After each download the memory card should be re-formatted to clear the old pictures off and provide space for the new pictures
Dec 26, 2010 | Fuji FinePix Z2 Digital Camera
My z950 is not reading my memory card. I got it a couple of weeks ago and it was working fine. I took my memory card out to print pictures and when I put it back in, the screen keeps saying internal...
make shore the memory card is out of the camera and reformatte the interal memory and reset the camera ,turn it off and put the memory card back in it should work now.
Aug 29, 2010 | Kodak EasyShare Z950 Digital Camera
Cant take pictures says phone memory full
Your phone only has so much space for pictures, if you've used up all the space it has - you will probably have to buy a memory card and slip it into your phone. Then use the menu to change it so that your future pics will be stored on the memory card, instead of the memory on the phone's brain.
Or you can delete some pics from the phone's brain, to make room for more.
But most people just buy a memory card, since you can get them for $5-$20 depending on how much memory you want.
Nov 30, 2009 | LG Neon GT365 Cell Phone
I want to put my storage memory in my program memory or i will delete my storage memory but i want to know what is all in the storage memory thats important like pictures,music, voice reocrdings?
than have your storage or removable meory card check by a computer so that you can what is youwould like to transfer, and also be aware regarding the capacity of your Internal memory(program memory), see if it has enogh space to accomodate the data's that you would like to transfer, it can cause your program hang or not working if you use all the space, you'll need atleast 20% of its memory free to have your program space to boot up
Nov 06, 2009 | HTC Touch Diamond Smartphone
Im trinyg to change my wallpaper on my lg cookie, but it keeps sayin memory full, but i've got loads of free space.. help?
actually its the space in the phone memory not with the memory card,if it says memory full
remove your memory card and erase the data present in your phone memory and put the MC and change the wallpaper...
RATE ME!!!
tnx.
Jul 14, 2009 | LG KP500 Cookie black on T-Mobile U-Fix...
Phone freezing
hi all viewers `this is a good tip for your nokia 5310. well your phone is freezing cus you have to much memory on the phone the phone has a memory on its self witch is 20 mb. if you fill up like 15-20 mb it will slow your phone down or freezing completely. you can fix this by moving files to a memory card on the phone freeing up space i recommend you store 5-7 mb on phone memory. 100% success if not you have a problem
Jun 27, 2008 | Cell Phones
Frozen and Speaker phone turns on and off
I BET YOU HAVE A LOT OF RING TONES AND PICTURES IN THE PHONE., THE MEMORY ON THE PHONE SUCKS. DELETE A FEW PIC AND TONES AND THAT WILL SOLVE YOUR PROBLEM.
Oct 12, 2007 | Motorola Mobility RAZR V3m Cellular Phone
Internal memory
Quality Mode Resolution 14MB Internal Memory 16MB xD-Picture Card 512MB xD-Picture Card SHQ 2288 x 1712 4 images 5 images 178 images HQ 2288 x 1712 14 images 16 images 523 images SQ1 1600 x 1200 27 images 32 images 1030 images SQ2 640 x 480 144 images 165 images 5324 images Storable movie length and resolution (approximate figures). The number of movies saved is based upon the storage capacity of the xD-Picture Card and length of each movie. Quality Mode Resolution 14MB Internal Memory 16MB xD-Picture Card 512MB xD-Picture Card HQ 320 x 240 30 fps movie 20 sec. max movie 24 sec. max movie 12 min. 54 sec. movie SQ 320 x 240 15 fps movie 41 sec. max movie 48 sec. max movie 25 min. 48 sec. movie
Aug 31, 2005 | Olympus Camedia D-425 / C-170 Digital...
Nikon Coolpix L11 Digital Camera Logo
1,204 people viewed this question
Top Nikon Cameras Experts
Steve
Are you a Nikon Camera Expert? Answer questions, earn points and help others
