Question about Panasonic DVD-RV32 DVD Player
Dvd player hi guys. i have a problem with my dvd player everything is ok i mean it takes in the cd spins a little shows me on the screen that its reading then no cd .I have open the caver and found that the lence is not moving up and down .I am thinking of changing the lence but am not sure.
    Genius:
  • 1,074 Answers
Check the motor and the strip that leads from the body of the lens to the circuit board.replace them
Posted on Apr 04, 2007
Screen shows loading
well this typically means that either then lens has gotten dirty, or the circuitry controlling the lens is defective. (If it cannot read any disks).
These tiny dvd players can also warp and the CD's may be getting scratched just by spinning inside and not reading as a result of an uneven spin. Maybe it got left on the dashboard of your car for a weekend and is all out of shape, who knows.
You can attempt to clean the laser lens with rubbing alcohol and a qtip. Use very little rubbing alcohol and be gentle, make sure its dry before powering on also.
I wouldn't recommend spending a lot of money on this project, portable dvd players are borderline expendable electronics they just expect you to throw it away. Looks like you could get the same model on ebay for 60 - 80 bucks.
May 20, 2012 | Sony Dvp-fx750 7" Portable Dvd Player...
It won't press the button even though the power is on
Since you don't indicate what you mean by "won't work", let me provide a few possibilities:
1) You close the door and you can hear the DVD spin, but no reaction on the screen other than some type of "loading" message. This indicates that the optics are attempting to read the DVD but are having difficulties. The operation may ultimately be successful and the DVD may start, but the movie will be unwatchable because of freezes etc. In this case, try cleaning the lens using a cotton swab and alcohol. A dirty lens can cause this.
2) You close the lid and do not hear the DVD spin. In this case, the optics can not even determine that a disc is in the machine. Again attempt to clean the lens. If that fails to at least cause the disc to spin, the optics have failed and need to be replaced.
3) Try a music CD. If that plays OK, but a DVD does not, then the optics are defective and need to be replaced. DVDs require a more powerful laser and will typically fail sooner than CD levels.
Hope this helps,
Dan
Jul 10, 2008 | Audiovox Televison & Video
Everything powers on, it plays dvd's cd's and the radio but the screen won't come on and the little square at the bottom keeps flashing.
Hi.
That usually means that there is no video connection.
Check the video connections to displays and check the video connection at the back of the main DVD unit.
Regards.
May 28, 2010 | Kenwood Excelon DDX-7015 Car DVD Player
The disc spins for a long time and then wrong disk message shows it plays cd's ok.
Check ur DVD disc have scratches or cracks that the laser head can't read.Tries to wash the disc with dish washing soap to get clean surface to leaser head to read.Use other Disc see it have same probblems?Check the region of the disc is on the lable like NTSC or PAL.Euroupe and Asia run only in PAL. U.S.Canada,Mexico run on NTSC.
Feb 10, 2010 | Lenco DVP712 7 in. Portable DVD Player...
Code H02
Your DVD player is having an issue with the spindle motor (the thing that spins the DVD around). The following solution works for most people, and you should only have to do this once.
  1. Unplug the DVD player.
  2. Take the cover off.
  3. Place a disc on the spindle.
  4. Put a little pressure on the disc (so it doesn't slip) and spin it around a few times.
  5. Remove the disc, reassemble, and plug back in.
  6. Try to play a DVD.
  7. Report back if this solved your problem, or if more troubleshooting is needed.
Aug 02, 2009 | Panasonic DVD-S55 DVD Player
Coby DVD shows Invalid Disc HELP PLEASE
Did you make the disk if you made the disk your computer has to give it a digital signature so the DVD player can read it if you're using a regular DVD then I would very carefully using rubbing alcohol and Q tip clean the actual laser I would be very careful doing this if too much rubbing alcohol is on the Q tip it will ruin the laser you can also try resetting the DVD player by taking out the battery and unplugging it from any power source and leave it that way for at least 20 seconds to a minute if that doesn't work you might have something else wrong
Jul 18, 2009 | Coby TF-DVD7005 Portable DVD Player
Can' turn off the player
hi. i got the same problem, did u manage to fix it?
Jan 07, 2009 | Necvox RE-8169D 8 All-In-One Motorized...
Dvd-rom driver not working on toshiba satellite A65-S126 laptop
Ok here is the thing. the driver that you are referring to is native to the XP operating system. Meaning the driver is embedded. If the CD/DVDROM comes up under my computer that means only 1 thing. The driver is ok. if you have tried more than 1 CD and the drive still does not read it., it means only 1 thing. The drive is defective. if you use an external drive via USB you should not have any problems. If you do then you will need to reload Windows but that will be an unlikely event.
Jan 05, 2009 | Toshiba Satellite A65-S1065 Notebook
Disc error
when i press play on my dvd/cd player it says error
May 24, 2008 | Zenith DVB412 DVD Player
Panasonic DVD-RP56 Error H02
I read about removing the cover and spinning the motor by hand. It was suggested without power. I found that I had to have the unit powered up when I hand-spun the motor, then everything worked perfectly... we'll see for how long.
Feb 10, 2008 | Panasonic DVD-RP56 DVD Player
Panasonic DVD-RV32 DVD Player Logo
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
