Changing motherboard language
Hi. I have this cpu (kind of old one). It's an IBM P3, 866MHz, 128MB SDRAM with 20GB hard disk. I'm trying to format it. My problem is, the IBM cpu came from Japan so, the language in the motherboard also in Japan ;-0 I've been trying to change the language to English but i don't know how.
Do anybody know how to do it (changing the Japanese language in bios to English)
I know, some of you might say that i should get a new cpu but to me i just wanna use the IBM as my backup.
Any kind of help will be appreciated. Thanks guys...
  • jeramtoi Dec 21, 2008
    Ok, i went to the manufactures website and unfortunately it's also in Japan.The translation doesn't help much. Got any other ideas..?
  • jeramtoi Dec 22, 2008
    Ok, what I can tell is only this things :- IBM NetVista, Pentium 3, 866MHz, 128MB, 20GB hard disk with cd and floppy disk.
    It's an IBM NetVista M/T 6578-PBJ, S/N 97-987LV.
    The motherboard is ( i think ):
    -INTEL 815
    -FW 82815
    That's all the info i can give to you.
    Thanks in advance for all the trouble.
  • 837 Answers
You can go to the manufacturers website and look for a BIOS update flash .. but unfortunately since you nor I know Japanese we cannot get into the BIOS to see if it can just be changed there. Most BIOS have language settings but you gotta know the current one in order to switch to another.
Posted on Dec 21, 2008
  • Jay Glendenning
    Jay Glendenning Dec 21, 2008
    Can you give me the whole manufacturer name, make and model of the motherboard and I will see what I can locate for you?
  • Jay Glendenning
    Jay Glendenning Dec 22, 2008
    Download and update the BIOS here ..
Not vga.i want correct that
Posted on Jan 23, 2009
What kind of memory can I use in my 6282-75u
IBM 300GL 6282-75u
IBM = Manufacturer
PC300 = Series
PC300 GL = Subseries
6282 = Machine Type
75u = Model
Intel Pentium processor or Intel Pentium with MMX technology, and max frequency rate ('Speed') is 200Megahertz. (200MHz)
Two ram memory slots.
EACH slot can hold a maximum amount of ram memory -> 64MB
TOTAL ram memory amount for motherboard is 128MB (Woo-hoo!)
Ram memory is SDR Sdram. Commonly, but mistakenly, just referred to as Sdram.
Has 168 gold plated contact pins. 84 on each side.
Two Locating Notches on the bottom of the ram memory module.
(Two Side Notches. One on each side)
Non-ECC and 100MHz as shown above. (PC100) [ DIMM ]
I don't know if you can just use a 128MB ram memory module ('Stick'), in ram memory Slot 1, or not.
I would try it. May have to reboot up to 4 times for BIOS to recognize the ram memory. May NOT have to.
Under the bold white heading in the black bar -> Technical manual
,click on the blue -> [+] Click for files.
It is a PDF file, and the HMM for the IBM 300GL-6282-75u Desktop PC.
(Hardware Maintenance Manual)
Cheap buy on PC100 - 128MB - ram memory modules,
You have a D.I.P. switch on the motherboard. SW1
Has 4 dip switches, numbered 1 through 4.
The positioning, (ON or OFF), determines the 'speed' support for the Processor.
Page 26 - PDF file page, Page 14 - Actual manual page )
Aug 24, 2012 | IBM (61H0382) Motherboard
I have ibm deskstar 20GB. Problem is that i want to connect it as an external drive through usb connector. It detects but no partition is shown in my computer. i try all jumper setting define in manual...
In Windows 7, you can use Disk management to detect and create a partition on this drive if necessary.
Steps: 1. Connect your external drive through a USB port.
2. Click Control Panel - System and Security - Create and format hard disk partitions (under Administrative tools)
3. Your drive should appear in the table below. Select the external disk and Right Click on it. You will be presented with several options (Create partition, Format, etc.). Select whatever is applicable in your case.
4. Your external drive should now be detected by Windows 7.
Mar 23, 2011 | IBM Deskstar 40GV (DTLA-305020) 20 GB Hard...
I use i845ITE8712 mainboard. My PC is very slow.It takes 5 minutes to boot completely.I use Win XP Prof, Intel P4 processor. In spite of proper maintenance using Adv Sys Care and CCleaner, Auslogic reg...
You have Intel i845-ITE8712 chipset with 1.7GHz cpu. I will just upgrad the SDRAM from 256 MB to 1GB (two 512MB 133MHz DIMM SDRAM).
You can install 2.4/2.6 400 MHz You will gate more performance.
Or can install 2.8 400 celeron
Follow the installation guide
Hope it will help you.
Dec 03, 2010 | IBM (03R0329) Motherboard
I need to know how much ram my motherboard will be able to run without burning up? I have an Emachines t1090 w/ Windows XP, 900MHz Intel Celeron Processor, 128MB SDRAM, CD-ROM 48x Max. CD-Drive, 20GB Hard...
The max for your system is 512MB. You have two memory slots and one has a 128MB chip so if you want 512MB, you need two 256MB chips and throw away the 128MB.
At Newegg, a 256MB chip is $42+ shipping of $1. I'd consider getting a new computer instead.
I don't think memory upgrade will tax your system cooling.
Sep 09, 2010 | E-Machines T1090 PC Desktop
Does the Dell inspiron 8000 have a built-in webcam?
Here is the specs and it doesn't say anything about webcam.
SUMMARY corner_ffffff-fff0cc_13x13.gifDell Inspiron 8000
Pentium III-900/700 CPU,
128MB of SDRAM,
256KB L2 cache,
Windows Millennium Edition,
15-inch active-matrix screen,
NVidia GeForce2 Go graphics chip with 16MB of SDRAM,
20GB hard drive,
8X DVD-ROM drive,
built-in network adapter,
V.90 modem,
touchpad and eraserhead pointing devices,
9.2-pound weight (with AC adapter and phone cord),
Aug 24, 2010 | Dell Inspiron 8000 Notebook
That unit it about 10 years old.
Unfortunately, you cannot upgrade the CPU (processor)
The RAM is a standard 100MHz non-parity SDRAM SODIMM. The 2645 can use 128MB DIMMS for 160MB maximum. It has 32MB internal and two slots.
The hard drive size is limited by the BIOS. Any standard 2.5" hard drive should work, but may show as limited size, maybe 20GB.
Get a PCMCIA modem.
If you found a docking station for this unit, you'd be in better shape. Like I said, it's 10 years old. It won't be easy.
Jul 22, 2008 | IBM ThinkPad 600E 2645 Notebook
Regarding upgradation of SDRAM
hi dear
there is always speed mismatch problem occur when we use low processor & high ram
so try to use 256 ram
also try to use 1 slot of 256 ram & 2 slots of 128 ram diffrently
& compare the speed
hope it will help to u
Jul 08, 2008 | ASUS SiS Chipset CUSI-FX Motherboard
No not compatible! Your system is obsolete, almost impossible to upgrade anything. Socket 478, P4 cpu stuff, is the oldest system with any chance of upgrading or maintenance.Get a 'barebones' new system for $250/300 from the Inet [ ebay or simillar ]/ You will then get some value from the cost of the windows Xp if it is the full version or alternatively you have both original OS disc and windows Xp ugrade disc. If what you buy has an IDE hard drive. you can also install your current hard drive too, keeping what you have on it, as a slave drive after you have put your OS on your new machine plus any cd or dvd on your old machine.All this is simple and within widows framework and tools, no tech skill needed, just a screwdriver and a manual with your new barebones motherboard. Plug the old ide drive into the right socket from the conncecting braid, set the jumpers as per hard drive diagram on the back plate on both drives. One master, one slave.Remember NOT to format your old drive/ LOL/
Jun 25, 2008 | VIA Computers & Internet
Ibm t30 2366
hi ye check your ram and cpu is 100% if the cpu is disloged it will not come on..try this for starters..
Nov 20, 2007 | IBM ThinkPad T30 2366 Notebook
Computers & Internet Logo
947 people viewed this question
David Payne
David Payne
