Question about Daewoo KOR-630A Microwave Oven
Oven is not starting
Timer is working
  • jiwankumarva Dec 28, 2008
    Microwave oven Model is DAEWOO KOG-26.I have checked all door switches (electrically) and door mountings,they are all o.k.
  • William Miller
    William Miller May 11, 2010
    This
    is usually caused by either a bad door switch, a loose door switch
    mount (which are pretty simple problems to fix) or
    occasionally a
    problem on the control panel.
    Please reply back with your brand and model number so we can help you.
  • Daewoo Master
  • 9,098 Answers
Sorry I missed your model number the first time around.
This is usually caused by either a bad door switch, a loose door switch mount (which are pretty simple problems to fix) or occasionally a problem on the control panel.
Even though a door switch clicks, it may still be bad inside.
Door switch or mount trouble is usually caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
One test that sometimes helps is to gently lift up (and/or push down) on the door or handle as you try to start it. If it works or tries to work, then it's a door switch mount or door alignment issue.
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa:.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
If you only need a switch, you can order a universal type here for $5 postpaid.
If you think the problem is on the control panel, we repair these nationwide by mail for $39.95 postpaid in most cases in about a week or so.
Posted on Dec 28, 2008
Will not start but timer works
Yes indeed it could have a blown fuse but be careful your dealing with 120 volts.
Good luck
Apr 06, 2014 | GE JES1344SK Microwave Oven
Oven will not start timer works but oven will not run
If the timer counts down but nothing else works, it usually is a bad secondary interlock switch. Opening the door while the unit is in cook will ALWAYS cause this failure. Switch needs to be verified as bad and replaced.
Aug 29, 2013 | Frigidaire Microwave Ovens
I have maytag advance cooking system(electric) and the oven will not work.The timer to set the oven and the time is not lighting up but the stove is working.any sugestion
try resetting the clock. If it is digital, push the clock button and then the number buttons untill you have the proper time displayed...then push the clock button again. If your clock and timer are manual, try pushing in the clock lever and turning it 1/4 turn. If this works it would indicate that your timer has a start and finish time and that the oven is not working because the clock has rotated around to the finish time.
Sep 09, 2011 | Microwave Ovens
Microwave timer works, light works, but heating mechanism will not engage-- no "sound" or "heating" when I hit start (although the timer mechanism sets & counts down, even when...
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic Microwave Oven Troubleshooting Tips
heatman101
Nov 06, 2010 | Hotpoint RVM1535MMSA Microwave Oven
Hums, does not heat when started. Display, timer,
The problem could be the high voltage fuse or the magnatron assembly. replace both to be safe. good luck.
Nov 12, 2009 | Sharp R-1610 Microwave Oven
Help used micro as timer but pushed start instead now wont work
Unplug it and try it again, may just need power on off reset
Aug 22, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave Oven EM-804T
You need to trace the power feeding the high voltage transfomer. Because the table doesn't turn, it implies that a door switch or safety interlock is the problem.
Jan 01, 2008 | Microwave Ovens
Neff oven timer
Normally you enter the time digits, then hit power level then zero or hit the timer button (if so equipped) then enter the time digits and hit start.
Nov 12, 2007 | Neff H7871N2GB Convection / Microwave Oven
Daewoo KOR-630A Microwave Oven Logo
103 people viewed this question
Top Daewoo Microwave Ovens Experts
William Miller
William Miller
Ian Summerfield
Ian Summerfield
Are you a Daewoo Microwave Oven Expert? Answer questions, earn points and help others
