i can't get my lg adr-620 to record i don't know what i'm do wrong it just keeps saying no audio could you tell me what leads i need and where they go thanks matt
-   I HAVE LOST MY MANUAL. i HAVE FORGOTTON WHAT TO DO TO RECORD PLEASE CAN YOU TAKE ME THROUGH IT FROM THE START AND TO THE END WHERE YOU FINlize it please-   andiwarren
Best Solution
posted on Apr 04, 2007
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Check your wire they could be damage
Solution #2
posted on May 10, 2008
Guest
Rank: Apprentice
Rating: 0%, 0 votes
you need to use blank AUDIO cd-r's as they are different to standard cd rs.insert the blank disc, have the input on analogue,press record and then play and the clock should start counting.when recording is finished press the finalize button it will flash on the display,then press play again and the finalize display will stay red till its finished.you must do this or will not play.
Solution #3
posted on Oct 14, 2007
Guest
Rank: Apprentice
Rating: 0%, 0 votes
you are not using the wrong type of disk..you need cd-audio disks not just blank cds : http://www.srtl.co.uk/srtl/tdk/cdrxg.html
left on it comes on after approx 1hour
while on can play cd change stations etc.
after...
(More)
after disconnecting from mains problem starts
Radio is ok for 20 or so minutes, then cuts out, no sound, still shows display, when I check and...
(More)
Radio is ok for 20 or so minutes, then cuts out, no sound, still shows display, when I check and press volume limit the display freezes and still no sound. I have to press stand by button...V.annoying!
Logik LOGCRC168D DAB CD Clock Radio Manual - Please can you tell where to get a download or hard...
(More)
Logik LOGCRC168D DAB CD Clock Radio Manual - Please can you tell where to get a download or hard copy of the manual (instruction book) for the CD/DAB.
Even when there is no disc in the playback side of the player I get a disc error message.The other...
(More)
Even when there is no disc in the playback side of the player I get a disc error message.The other side works perfectly.
