Laptop screen partially blank
I have an HP NC8000 laptop and the screen has gone blank on the left hand quarter. Everything seem to work but I am travelling blind trying to get anything to work as I cannot see many of my icons or indeed any thing on the left side of my task bar.
Does anyone have a fix for this
  • 30 Answers
It may happen that ur screen became idle
because of less connectivity by cable residing at the bending position of ur laptop.
So u have to immedietly meet ur laptop's vendor.
Posted on Aug 03, 2009
HP Pavalian laptop screen gone black and blank.
It seems like the lcd back light may have failed can you see a faint image on the screen when you look really close, try it with a torch. If you dont see even the faintest image the inverter has failed and needs to be replaced. If you look on youtube again and search for videos of replacing both the back light and the inverter it will give you some info on how to change them. Do a google search for hp spares and you will probably find what you are looking, i think the inverter is about £30 and the back light is bit cheaper. hope this helps.
Feb 11, 2010 | Computers & Internet
Hi, I have an HP Pavilion DV7 laptop. When I turn on the computer everything seems to be working but the screen is blank. Blank meaning black and/or colorless without light. Thanks!
Borrow a monitor and plug it into the side of the notebook to verify that the computer still works. If it does then the screen has gone out.
Jan 28, 2010 | HP Pavilion dv6000z Notebook
HP Pavilion laptop screen has gone black/blank
You can either use an external monitor for working with the laptop or talk to HP for replacement.
The best option is to use external monitor to backup data before sending it to replacement.
Good luck
Jun 22, 2009 | HP Pavilion dv6835nr Notebook
No it suggests you have a bad screen and it needs replaced
Jun 22, 2009 | HP Pavilion F1503 15" LCD Flat Panel...
Generally, the LCD is a pass or Fail device, with a few exceptions. You can try reseating the LCD cable to the video card and see if that makes any difference in the display.
If video looks normal on an external monitor, then LCD replacement is in order (Arround $200 to 400 depending on display) if issue is the same on external monitor then the video card is failing
Dec 21, 2008 | HP Compaq nc6000 Notebook
Laptop shuts off, and wont turn back on.
when power off, push compressed air through vent.
If you can reach fan and remove dirt,
Insist on compressed air to clean every vent.
Install temp monitor to check if CPU is getting hot.
Dec 17, 2008 | HP Compaq nc8000 Notebook
Red and Blue vertical lines top to bottom on LCD Screen
yes it looks like its going bad..must be pixel burnout or will have to contact HP for repair/replacement
Nov 23, 2008 | HP Compaq nc8000 Notebook
HP nc8000 shuts down after 10 seconds
try pushing on the upper right corner of your laptop, above the home key, does it start up again?
If so its the maxim chip
if not take one so dimm out and dissable wireless.
Could also be your battery not charging because a battery or power cord malfunction.
Oct 21, 2008 | HP Business Notebook NC8000
My nc8000 shuts down after few seconds and starts after power plugged in or battery inserted
Hi Turecki, It's a moderately easy fix for this common issue with HP/Compaq Laptops. Simply go to ebay, purchase an "inverter" board built for a NC8000 laptop can range from $10-$50 just purchase one with a minimum 6 month warranty. Its about a 0.5 inch by 15 inches. Unscrew all of the tiny phillips screws located and hidden behind black rubber covers on the LCD screen. Pop off the plastic LCD cover and replace the inverter board located at the bottom of the LCD (plug & play). Put it all back together and voila...problem fixed.
Have fun and practice some repair skills.
Sep 13, 2008 | HP Compaq Business nc8000 Notebook
Hp nc8000 power issue
Many of the power jacks also contain switch contacts that allow the adapter to power both the laptop and the "charging" system. I would suspect that one of the leads had either been broken or at least detached from the pc board. This laptop needs to be dis-assembled and the power jack repaired. Worse case will result in the replacement of the jack or the repair of the board if that part has been cracked.
May 13, 2008 | HP NC8000 (DE503AV) DVD+RW Burner
Computers & Internet Logo
183 people viewed this question
David Payne
David Payne
