Question about Kenmore 63942 Dryer
Dryer wont stay on... it appears to have intermittent heat.
Dryer willl not stay on I have taped the on button switch down with duct tape and the time will go thru in minutes. Based on which setting if air or perm. press it doesnt seem to always get hot enough. then 2 hours later it works perfect.
help. i have a kenmore elite type ddot-ele-2406028-eh54.
model # 110.62932100.
any information would be soooo appreciated. Ive tried level issues, vent cleaning, changing the selections from air to hot heavy duty.
im running out of things to try.
thanks so much,
liz
  • Anonymous Jan 11, 2009
    Same frickin problem! Trying to fix it now!!!! Will let you know!
  • Bill Dickerson
    Bill Dickerson May 11, 2010
    Have the hi limit switch checked. It may be bad. Is this a gas or electric?
  • Kenmore Master
  • 8,220 Answers
You have a broken belt. This dryer is complimacated but here goes.Remove the console screwsand flip the control panel upwards simular to what they do on washers. Remove the 3 screw in the rear that hold the top and get the top off. Pop the bottom panel and back off the screws holding the front on then remove the screws from inside the top. You can get the front off now. Get the drum out and clean out the dryer. Oil all 4 wheels and idler. You will note the micro switch below the idler. that stops the drum from turning when the belt breaks. You will be a pro if you can fix this one.
Posted on Feb 07, 2009
Replacing the LED strips on my Vizio TV and the reflective shield got a couple of tears in it while removing. How can I repair without replacing?
Are you talking about the metalized tape that they put on? If so its not a huge deal, its there as a RFI shield, just try to smooth it down the best you can and if it wont stick just use a little tape over the top of it to hold it down. Another thing i use a lot to fix the shielding tape is the aluminum heating duct seam tape, its not duct tape, its an actual metal aluminum tape with adhesive on it for sealing up heating ducts. Most home repair stores sell it as premium aluminum duct sealing tape.
Jan 01, 2018 | Vizio Televison & Video
How to fix the heating element on kenmore 90 series
you will need a test meter set on ohms, duct tape and metal tape,
nut drivers 1/4 in and a 5/16 in nut driver , you might need new duct pipe most of the time it air flow that got you in this , un plug dryer
remove duct pipe remove back. watch this video he is good at making help videos check you tube for more help videos good luck
Jul 11, 2014 | Kenmore 63942 Dryer
On button wont stay in
Replace the switch. It is defective.
Apr 29, 2012 | Hoover Washing Machines
Dryer is turning without heat and will stop intermittently
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
Check to make sure you are getting full 220 Volt power to the dryer, if you are then:
Sounds like your problem may be with the heating coil. Remove the back/or front just under the door of the machine and try to locate the air duct going from the blower to the drum. Normally inside/outside the air duct you will find the heating coil and the thermostats/thermistors. Once you have located the heating coil, remove the two wires from it and check the coil with an ohm meter across the two terminals of the coil.
You should read continuity across the terminals, if not you will need to replace the coil as it is faulty.
If the heating coil is ok, then:
You can check the thermostat/thermistor one at a time by removing the two wires and taping them together with electrical tape or with an ohm meter to test the thermostat/thermistor. (Should have/show continuity)
If the coil heats up then replace the thermostat/thermistor.
DO NOT LEAVE THE WIRES TAPED TOGETHER AFTER THE TEST.
This could cause a FIRE, as you have removed the safety of overheat from the machine.
Please rate me
Sep 14, 2010 | Speed Queen AGS28AWF Gas Dryer
My dryer wont heat up
You can check the thermostat/thermistor by removing the two wires and taping them together with electrical tape or with an ohm meter. (Should have/show continuity)
Please rate me
Aug 25, 2010 | Kenmore 66862 Dryer
Its an electric dryer. It spends but wont heat up
Sounds like your problem may be with the heating coil. Remove the back of the machine and try to locate the air duct going from the blower to the drum. Normally inside the air duct you will find the heating coil and the thermostats/thermistor. Once you have located the heating coil, remove the two wires from it and check the coil with an ohm meter across the two terminals of the coil.
You can check the thermostat/thermistor by removing the two wires and taping them together with electrical tape. If the coil heats up then replace the thermostat/thermistor.
Good Luck, Hope this helps
Please rate me,
Thank you
Aug 14, 2010 | Kenmore 64742 Electric Dryer
Maytag Performa Pye2000ayw won't turn on-tried taping wires
If your dyrer has a thermal fuse, it will be on the blower housing (front), not on the heat element. It will be either white plastic os a button about half the size of other thermos. The fuse on the heat element will shut down the haet only. Hope this helps!
Jan 04, 2009 | Maytag HYE3658AY Electric Dryer
Dyer wont stay on... intermittent heat
I would bet it is one of the safety switches...Tom
Dec 21, 2008 | Kenmore 63942 Dryer
DRYER ONLY WORKS BY HOLDING DOWN THE TIMER BUTTON
You need to replace or repair the timer control, this is not a faulty motor control unit.
You find parts by entering model number here.
Dec 15, 2008 | Dryers
Dryer doesn't run on it's own or heat
remove end caps on console by pulling top part forward remove the screws under each end of console and roll console back AFTER UNPLUGGING POWER under console next to timer is a control bd to right are 2 black relays 1 with blue wires 1 with red try switching the relays if dryer stays running replace relay if not most likely the control bd especially if you see burnt spots on bd
Sep 04, 2008 | Kenmore 62602 Electric Dryer
Kenmore 63942 Dryer Logo
263 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
